Question about Pentax Optio E10 Digital Camera
Pentax E10 -
Installed new batteries 2 times. Camera turns on to start up page, then 2 or 3 seconds later it shuts off. What's causing this please?
Thank you,
Julie Ray
rays_of_gold@ msn.com
  • scouse m Jun 18, 2008
    When camera is pressed on, it comes on for 1/2 seconds then goes off
  • jysegovia Aug 12, 2008
    The same problem, first I thought my old batteries were drained but when I bought new ones, still the camera shuts off easily.
I just got mine to working again!!!!! (After about a year of not working.) I held down the green button while I was turning it on. Something happened... you could hear things going on. I did this several times and eventually, it worked.
Mine sounded like the shutter was getting stuck. I also sprayed a very small amount of wd40 on the lens rings, being careful not to get it on the lens itself.
Posted on Nov 07, 2008
Are you using lithium aa batteries?
Posted on Jul 21, 2008
After i turn on my Optio E10, it shuts off right away even after i put in new batteries.
Sounds like a memory card problem. Try using A 512mb San Disk SD Card. Not a San Disk SDHC card. see if that doesn;t help you out. Good-Luck
Mar 21, 2011 | Pentax Optio E10 Digital Camera
THe flash of my Optio E10 gone. What should I do?
Make sure the battery is fresh or new.
Make sure to check all your menu settings.
These settings can affect the flash.
You can reset to default...then see what happens.
You can always sell the camera as a parts camera on a site such as Ebay.
Aug 30, 2009 | Pentax Optio E10 Digital Camera
What type of rechargeable batteries are the best. batteries even when fully charged can only take 2 pictures .
The problem is not in the batteries....
I have the same problem, after two pictures the camera shuts off even when new batteries have been installed...
Aug 26, 2009 | Pentax Optio E10 Digital Camera
E10 and s45 same problem
the batteries needed for the cameras are quite high powered
though the batteries show that they are fuly charged most times they have lost their actual capacity of power storage in them so not being able to supply enough to start the camera best way to test this is to start the camera on preview mode if this works then you will need to buy a new set of rechargable batteries, i would suggest to take batteries in the range of 2000MAh to 2500MAh and
the normal batteries will not be able to sustain long even for normal lens open and retract functions, instead of normal batteries try LR6 varieties (eg: Duracell, Energizer, etc)
Jul 25, 2009 | Pentax Optio S45 Digital Camera
Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Jul 12, 2009 | Pentax Optio E10 Digital Camera
Digital camera
I had almost similar problems with my A10 from day one. The camera shuts down before the battery is depleted, most of the time while I was operating the zoomlens. I bought a new battery, but that didn't solve it. Later I decided to take it apart as a last option. As my suspicion was the zoomlens I took out two crews of the motor that operates it. Now the motor has a bit more space to move. It seemed to be too tight against the gears so it could cause an overload. After that it worked perfectly. I made pictures for hours without having the same fault again. Be carefull too make notes where all the tiny screws belong of the casing. And maybe it will be enough to just loosen the motorscrews, but leaving them out will not make it fall out of it's place. I hope someone can use this information.
Greetings, Ron Timmermans.
Jun 03, 2008 | Pentax Optio A10 Digital Camera
Pentax optio E10
Put a quality battery and start it.....
Mar 22, 2008 | Pentax Cameras
Pentax E10 6.0
This depends on the operating system1.gif. Only Win98 and Win98SE need software
Review quick start guide for how to download2.gif pages 10 and 11 seem to be of interest.
Quick Start Guide
http://www.pentaximaging.com/files/manual/Optio%20E10_QuickGuide_01.pdf
Manual
http://www.pentaximaging.com/files/manual/Optio%20E10_web.pdf
Nov 27, 2007 | Pentax Optio E10 Digital Camera
Pentax Optio E10
Do not interfere with the lens as it is out -dont try to push it back- this will wreck it. Take the batteries out and with the eraser at the end of a pencil polish the contacts at the bottom the the battery chamber. Do the same with the contacts in the lid Try a further new set of batteries. Insert them. close the lid switch on What happened? Nothing Then switch on again and this time gently push ther battery compartment lid. What happened?
Jun 07, 2007 | Pentax Optio E10 Digital Camera
Pentax E10 will not power up ( w/ fresh batteries) !!
hi. me again. flicked the gray lens thing sticking out hard enough with my finger as i got pissy with it and WALLA! it works now. just thought id let you know.
Apr 09, 2007 | Pentax Optio E10 Digital Camera
Pentax Optio E10 Digital Camera Logo
159 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
