Astar LTV-3201 32 in. LCD Television Logo
Posted on May 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Astar LTV-3001 I have one of these sets and I just heard a high pitch noise and then smoke came outof the top bak. It won't turn on now. Is this a symptom of a failed power supply?
Jaime Hernandez
Level 3:
  • Master 2,351 Answers
  • Posted on May 18, 2008
Jaime Hernandez
Master
Level 3:
Answers
2351
Questions
Helped
782923
Points
6681
That was the power supply failing on yout TV.
You will need to change it or get it repair.
Have to turn tv on and off multiple times to get it to start without distorted picture and high pitched sound.
Same thing happened to my astar tv. Your power supply is going bad, or at least some of the capacitors are going bad. Eventually it will go bad altogether and you won't be able to turn it on at all. You need a new power supply.
I need a replacement circuit board for my Astar LTV-3001.. Mine began to smoke... and I don't allow smoking in my house...
The failures on these LCD's are due to defective capacitors in the power supply. There are about 23 capacitors that will need to be replaced to restore the LCD power supply functionality. Check the picture to see where the capacitors are located, the power supply on your LCD is not the same but similar to the one on the picture just the capacitors are place in a different order.
Let me know if you required further assistance.
No sound when tv switched to dvi Astar model LTV 3001
There is no audio in DVI connector, you need to run separet cable for audio signal.
1helpful
Power supply burned
These power supplies are not longer being manufactured and very hard to find. The defective power supply can be repair.
If you need further assistance, write to [email protected]
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to [email protected]
I have a Astar LTV-3001 and can't turn on. and I have other LTV-30MA This one have sound , no picture, can you please guive me sam help, I use to repair, Tvs. a time a go
I repair these power supplies. Write to [email protected] if you require further assistance.
1helpful
3answers
Astar LTV-2701 27
1helpful
Astar ltv 2601
Try call my friend Ivan at 323-767-6030 he know where to get the original Astar parts.
Astar Plasma
I had the same problem... Astar 30" LTV 3001 ....These TV's have a cooling problem that causes premature electrolytic capacitor failure. De-solder and Test all the 2200uF-25v, 3300uF-35v and 1000uF-10v caps in the power supply (center board, back of TV). Use a good LCR meter that will read 3300uF or better, Replace all bad caps with 105c rated caps. If you don't have an LCR meter, replace all the mentioned caps on the PS. If fuse on board is blown, also replace the F9222L regulator IC chip. Mounting a small cooling fan on rear of TV over the PS will help keep your new caps from failing again. This requires holes in the stand bracket and the rear of the TV, power can be supplied from a 14V source near the bottom of the PS board.
Top Astar Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
