Question about Dell 3100cn Laser Printer
Printing problems in a 3100 colour lazer printer
Our 3100 Dell laser printer doesn't print at the end (right hand side) of the A4 page.What should we check?
  • chewietong May 23, 2008
    I have a similar problem. But my DELL 31000 will print yellow and red but not cyan or black on a bar on the right hand side. I have changed the drum. What could it be?
  • eric moirez Jun 12, 2008
    Printer will print Black, Yellow & magenta fine on test sheet. But, will miss Cyan color 1.5 inches from right margin. Is this a developer unit?
  • 300 Answers
This could be caused by the scanner(printhead) image drum or fuser.
Posted on May 18, 2008
Epson PX650 not printing the full A4 page of my receipts, cutting off on right hand side
COULD BE THAT THE PAPER IS BIGGER SIZE THEREFORE CUTTING.NEED TO SAY FIT TO PAGE ON YOUR PRINTER DRIVER
Nov 18, 2013 | Epson Aculaser C1100 Printer
All printing on my Dell 3010 CN does not print about 2cm all the way down the right side of A4 paper this includes all colours and black
check your print settings and margin settings on the document. this should work ..
Thanks If this helps then kindly rate me.
Oct 30, 2010 | Dell 3010cn Laser Printer
The printer is printing everything small, on the right hand side and in black and white (its a colour printer.. I have never printed in black and white with it..)
This usually happens if the print settings are wrong, open up the properties of the printer and check all the settings (make sure its set to A4 if thats what you're printing on, and see that colour is selected)
Oct 29, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Toner is printing on right hand side of each page printed
Most likely it is the drum cartridge. The other causes such as toner on the laser optics would not produce an on again off again print area. It would be blank the entire way down the page. Since the toner prints in patches down the right side it means it is coming from something that is "rotating" and that narrows it down to the drum.
Good Luck and Thank You for using Fixya.
Mar 31, 2010 | Dell 1700 Laser Printer
1/2" white line appearing down right side of page
Try replacing the toner cartridge. This seems to be a problem with the photo-sensitive drum, which is located in the cartridge.
Jan 05, 2010 | Dell 3100cn Laser Printer
Vertical stripes
It sould be the print heads have gone bad.
I just had a Dell color laser that would print a 1" wide yellow line down the right side of the paper.
Replaced the print head unit, and problem solved.
Jul 29, 2008 | OKI C5100n Laser Printer
Not printing extreme right side of page
It is either your drum or open front cover see blue handle @ right hand side pull it out look at rignt hand side of printer and a door has opened (only small) pull the blue lever out and move the pad back andforwards a few times this cleans the glass.
It worked for me but I have to do it fairly often but it samve buying a new drum etc
Jan 08, 2008 | Dell 3010cn Laser Printer
Dell 3100cn Printer will not print
I had to actually change the settings in Microsoft Word to resolve this problem.
If you go to page setup > paper source > there should be lists for "first page" and "other pages".
You can set this to "as per printer settings" and hopefully it should work.
childofsai
Jan 08, 2008 | Dell 3100cn Laser Printer
DELL 3000cn Printing Problems
switch off the printer then switch on again whilst holding the UP and DOWN menu scroll buttons simultaneously.
Then you can go to a TEST PRINT area and print off pages of idividual colour.
If the streaks appear on ALL prints its likely to be the laser unit. If the streaks only print on the COLOUR sheets ( not BLACK) then the problem lies with the drum or the transfer belt.
Remove the drum and turn it manually with the gog at the side and give it a clean with a soft LINT FREE cloth, do the same for the transfer belt and then you may have to run a few test prints to get it all reprimed but you should be OK.
Oct 18, 2007 | Dell 3000cn Color Laser Printer
Printing Both Sides with LBP5100
my Cannon lpb 5100 colours are out of allignment (black OK) - error is "out of Register colours correction"
NOt sure how to solve this problem - calibration does not work?
Oct 12, 2007 | Canon LBP 1120 Laser Printer
Dell 3100cn Laser Printer Logo
108 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
