Question about Maytag Neptune MAH5500B Front Load Washer
Washer door locked
How hard do i need to pull the lime green string? it seems to be pretty hard to pull i dont wanna break it. and how and what do i need to do to have this fixed and is it gonna be xpensive to repair thanks
  • 868 Answers
Replace the door latch kit,Its not very expensive and your door will open fine again.
Posted on May 24, 2008
Door will not open on hotpoint bwd 129 catch may be broken
Your door lock assembly needs to be replaced to open the door try the following procedure.
To open the door, get a piece of string and feed it into the door recess, work it around until both ends come out opposite the door handle.
Pull the string to the side and with your other hand pull the door open.
You will need to get a replacement lock assembly for the machine which isn't too hard to fit if you are a bit handy with tools.
Mar 07, 2012 | Hotpoint Washing Machines
Door locked
Hi sometimes they become stiff dont worry about breaking it they are pretty sturdy just try giving it a hard pull their should be no reason why its locked as their isnt an electronic lock keeping it closed maybe their is a air vacume and its just stuck with air so try giving it hard pull let me know what happens.
Maybe the seal has become stuck to the door but it still should open ok
Jan 22, 2008 | GE Profile JGS968 Gas Kitchen Range
I completed a wash. I am unable to open the door.
hi best way round that is too get some strong string ..put round door were lock is and pull hard so it will undo the door ..u then need to change door lock ..its behind rubber door seal held in with x2 screws..
Feb 25, 2011 | Bosch Axxis WFL 2060 Front Load Washer
How to reset the break Sensor on vw touareg
Hi, You need to open the tailgate (liftgait). Pop off the two screw covers on the light assambly. Take out the two screws, then comes the hard part. You can either pull strait out and hope you dont break the locking pin or use a 2mm flat rope or string, slide it around the outside of the assembly then give a great pull to pop the pin. Be careful and good luck!
Apr 08, 2010 | 2005 Volkswagen Touareg
My washer will not drain, the door is locked and wont open and d5 keeps coming up on the panel. I unplugged, but nothing will open the door.
if you take the 4 screws out of the dispenser lid you can remove it and find a small green nylon string (looks like weed eater line) pull that and that will release the door. you will need to drain the unit and clear the drain pump as something is likely caught in it
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door locked
Lid lock failure Replace switch, linkage, lock solenoid or control board.
This is what you will need to check and replace
Feb 07, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag MAH6700AWW I need to release the door lock--machine is stuck in the middle of a cycle likely overloaded. Will not unlock when i pause or complete the cycle. I have pulled out dispensing...
open the dispenser door you will see a green piece of plastic,pull on it and the door will may be in a little you will have to reach for it it looks like heavy string.
Dec 10, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
