Question about Hotpoint Ultima WF860 Front Load Washer
WF 860 F-05 Fault
I had a F-11 fault which then led onto a F-05 fault, I have cleared the blockage under the plastic ball - £1.85 and a house key!! - but the F-05 fault still happens when I run a wash program. How do I get to the pump (where abouts is it !!) to rectify the problem, your help would be greatfully appreciated as "her indoors" is giving me serious earache. Many thanks in anticipation
  • Anonymous Jun 10, 2008
    same prob as tim17's
    Genius:
  • 1,224 Answers
The pump is under neathe in the casing
you will have to turn machine on side for this to get at pump make sure to disconnect everything first
i will drop a picture what it closley resembles you have naterial stuck in this or your drain hose kinked if you have something stuck in this pull it out the way it went in threw inlet with large needle nose pliars
Posted on May 30, 2008
Why does a fisher and paykel DD-603 randomly gives f1 code even when not in use
Fault code F1 can come from a number of different sources and can remain on as long as the machine has power (does not need to be operating). Once a fault is repaired it can be cleared by pressing the Power button. If the fault is still present then it will not
clear. The service manual says: The faults are displayed in the LCD as one of 5 F (fatal) faults or 1 U (user) fault along with the symbol of a spanner. A fatal fault will usually require the assistance of a qualified service person...
Fault Code Description:
Fault Code: F1
LED Display: Rinse LED
Fault: The flood switch has been activated for more than six seconds
Possible Causes
_ Inlet hose to inlet valve connection loose
_ Inlet valve body leak
_ Damage to the fill or drain hoses
_ Heater plate damage (chipped enamel)
_ Seals/O Rings (pinched, contaminated or poor join)
_ Dispenser (seal, diverter valve or weld leak)
_ Lid area (lid motors not functioning correctly, lid off yoke or foreign object interfering with lid seal)
Fault Code Problem Solving:
    1.Question: Is there a F1 on both displays? Yes: Go to Question 2. No: If power fails to the bottom tub it will cause thetop tub to go F1. Test heater plate.
    2.Question: Has a flood occurred? (N.B. The flood may have dried up) Yes: Go to Question 3. No: Go to Question 13
    3.Is the lid sealing on the tub correctly? Yes: Go to Question 5. No: Go to Question 4
    4.Question: Are the lid actuators functioning correctly? Yes: Go to Question 5. No: Check the lid actuators are assembled correctly on the slides and yokes. Check the plugs on the RFI board and the terminals on the lid motors. If the lid actuators look slow replace them.
    5.Question: Is the water level in the tub high? Yes: Go to Question 6. No: Go to Question 8
    6.Question: Is the water inlet valve leaking? Yes: Replace inlet valve. No: Go to Question 7
    7.Question: Is the DishDrawer priming correctly? Yes: Go to Question 12. Go to Question 8
    8.Question: Is the spray arm split? Yes: Replace spray arm. No: Go to Question 9
    9.Question: Is the spray arm running freely? Yes: Go to Question 10. No: Check the rotor is running freely, clear of foreign objects and fitted correctly. Make sure the wash impeller is not slipping off the rotor shaft.
    10.Question: Is water leaking from a split inlet or drain hose? Yes: Replace split inlet or drain hose. No: Go to Question 11
    11.Question: Is water leaking around the heater plate 'O' rings? Yes: Replace or refit 'O' rings. No: Go to Question 12
    12.Question: Is the drain hose blocked? Yes: Clear drain hose of blockage. No:Go to Question 13
    13.Question: Is there condensation or foreign matter around the flood switch PCB? Yes: Clear flood sensor of condensation or foreign matter. No: Go to Question 14
    14.After clearing water does the F1 fault code still activate? Yes: Replace Chassis RFI board. No: Go to Question 15
    15.Refer to Bulletin DW028 DW025, 028, 031, 040
Sep 06, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Miele dishwasher G2870 scm. There is an F14 fault. I have cleaned the arms removed the waste basket from the bottom of the dishwasher and removed the two parts one with the large metal ball to expose the...
F14 on your model of dishwasher is indicating a blockage, poor water pressure or could be a fault with the pump pressure level switch or circulation pump.
Filter and non return valve is cleaned of any blockages and if the fault persists have it service..
hope this help.
Apr 23, 2008 | Dishwashers
The temperature light is blinking in my side by side samsung refrigirator. Can you tell me why?
Hi and welcome to FixYa. I am Kelly.
Your display is showing that a fault has been detected.
Take a look at this link to determine what fault you have under
Step One diagnostics..
http://www.ukwhitegoods.co.uk/modules.php?name=Content&pa=showpage&pid=209
There are 13 different faults than can be displayed. Each one of the LEDs in the picture under step one indicate what that fault is by the DIGIT position of the flashing LED. (Legend to the left of picture) Usually that fault is either a component or wiring problem.
Note that the Power Cool and Power Freeze buttons are depressed for 8 seconds to clear any faults. It the fault remains it will reappear again.
Thanks for choosing FixYa.
Kelly
Sep 25, 2010 | Samsung SRS20DTD Side by Side Refrigerator
Top loading intuitive washer says fault code 37
This machine calls this error number for most faults.
So first let us know what stage it stops at.
The most common fault is blockage in the pump.
Remove the power plug, disconnect the 2 water hoses and tilt the machine onto its front.
It is simple to remove and replace. Disconnect the 2 sockets from the pump The pump is held in position by a latch on the left hand side. Depress the latch and twist the pump anti clockwise. Clean out , add a smear of vaseline to the rubber ring.
Reassemble in reverse
Mar 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Will not pump out
check water pump for blockage or fault
Jan 17, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hotpoint Ultima Super Silent WF865. I'm getting error code F04 there's water in the machine and it's stopped.
Error code F04 indicates pressure switch jammed on empty.
Remove the lower rear panel of washer.
Remove the large black hose fastened to bottom of drum.
Remove and clean the plastic filter inside hose.
Remove the hose onto the pump, and check for blockage or obstruction here.
This should clear the fault
please leave feedback for my solution.
Thanks.
Dec 14, 2009 | Hotpoint Ultima WF865 Front Load Washer
Shifter under hood pops of the little ball wat is
the ball is not bad, the arm needs replacing the socket's on the arm, it's loose
No repair, just replace it (Fairly cheap, dealership part only)
When you put the new arm on fill the new plastic ssocket (Both ends) with silicone grease (White or clear) do NOT use petroleum grease
Aug 31, 2009 | 1986 Oldsmobile Delta 88
Dear ladies and gentlemen, our problem is, that we have a full mashine stopp with e20 accuring on the led before the detenser enters the toumble. our mashine is an aeg 16809 e20 thanks for your fast reply
You've answered your own question. E20 is a draining failure. Blockage in the sump hose, pump, drain hose or faulty pump. Clear the blockage or replace the pump if faulty and you'll clear the fault.
May 16, 2009 | AEG Lavamat 16810 Front Load Washer/Dryer
I have Model WF-S6607?WF-S6607TC. Washing Machine. Loaded the clothes, pressed the POWER button, pressed the WATER LEVEL button, pressed the PROCESS button, and pressed the START/PAUSE button, But few...
This might be Lid cover open protection. There is a small magnet at the edge of the lid cover, housed in some sort of a catch.
If the plastic housing cracked, the magnet might have dropped into the washing drum. To overcome this, place a magnet on the position where the plastic catch will contact the washer when the lid is close.
Apr 04, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hotpoint Ultima WF860 Front Load Washer Logo
200 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
