Question about Frigidaire FEQ1442ES Electric Dryer
Dryer will not turn
My dryer will only turn when I have a light load in it. It starts and gets hot, but it will not turn around unless if I lighten the load.
  • 868 Answers
You have a Bad motor and it should be replaced by a Service Tech only.
Posted on May 21, 2008
Dryer not getting hot / washer won't run unless dryer on.
If these are separate units, you might have an electrical wiring problem in your house or apartment. If one unit (washer with dryer above), check to make sure the power cord is firmly attached to the terminals. Many other possible causes, too.
Apr 02, 2016 | GE Spacemaker GTUN275EMWW 27" Electric...
The dryer makes a scraping noise when it has a full wet load. if you lighten the load by about half the noise goes away, except when it first starts up.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Kenmore 600 6965 Electric Dryer
My dryer wed5300sq0 starts off slowly before the drum rotates correctly. sometimes i have to lighten the load before it will turn at all. It's not making any noise.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 01, 2011 | Whirlpool Dryers
My white night wont turn with full load,but if we lighten load it turns?
these are the items/parts:
1) belt may be stretched, examine belt for cracking and if it looking old replace
2) idler arm/pulley may be wore out, examine
3) drum rollers/glides may be wore out (second link)
4) motor may be going out
for the belt,idler arm/pulley and motor:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
drum roller/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 16, 2011 | Zanussi TD4100W Electric Dryer
Dryer won't start unless I take some clothes out
The motor is going bad...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer Repair ? The dryer will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 04, 2010 | Fisher and Paykel DE08 Gas Dryer
Unexpectedly stops
Lighten the loads.
Clean the lint from around and in the motor.
Replace the belt.
Check the rear drum support and front support guides.
If that does not correct the problem you have a bad motor.
Apr 12, 2009 | Dryers
Whirlpool dryer LGR7646EQ3. Burner lights before pushing start.
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot ignitor and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly.
more here
Dec 15, 2008 | Whirlpool LGR7646E Dryer
Strong ozone-like burning smell
Sounds to me like the motherboard inside the unit is on it's way to thermal overload. This is a common problem with this particular model. You'll smell electronics burning and one day it'll quit altogether with a burst of smoke. I had this happen to me and I traced the problem back to a faulty triac (transistor-like device) that overheated and caused the circuit board and wiring harness to burn up from excessive current draw. I repaired my motherboard with a new triac ($6) and rewired the harnesses. A cooling fan on the heatsink of the board would solve this problem.
Nov 12, 2007 | Equator EZ 3612 CEE Front Load...
Frigidaire FEQ1442ES Electric Dryer Logo
48 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
