Question about Sony KP-53V85 53" Rear Projection Television
No picture, no sound
I have a Sony KP-53V85 does not power up. The fuse inside is okay. Perhaps it is the power supply. Can I check this myself with a voltmeter ? Where would I test it and what should I expect ? I may need to get repair person eventually, but I would like to diagnose the problem myself. Any help/hints will be most appreciated. Thanks.
  • AAgrawal May 26, 2008
    No, LED is not lit or blinking when I press Power. I am very sure that there is power in the outlet.
  • AAgrawal May 27, 2008
    Thanks for the tip. How can I get circuit diagram/schematics so I can identify the right part and number. Also where would I get replacement parts from ?
  • Sony Master
  • 8,617 Answers
Is the led blinking when you press power? If so let me know the number of blinks its making.
Posted on May 18, 2008
  • Sonny Berry
    Sonny Berry May 26, 2008
    check the fuses if the fuse is blown it could be something as simple as a low volatage regulator or horizontal output tarnsistor that is shorted. Which is easy to test with an ohms meter.
  • Sonny Berry
    Sonny Berry May 27, 2008
    you can get your service manual emailed to you from the following link and they also have any parts you would need plus they give free tech support. I am one of their support techs. I have moved the manual to the front page so its easy for you to find, they email it out right after purchase within minutes,
    http://servicemanuals.vstore.ca/
KP-53V85 SONY PIC DOESNT LOOK AS CLEAR AS BEFORE.
Clean mirror and lamp lenses with a good glass cleaner (mild) but never put glass cleaner on your screen! dust can be the simple cause also focus it
Dec 08, 2008 | Sony KP-53V85 53" Rear Projection...
I HAVE 4 FLASHES
4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
Sep 24, 2008 | Sony KP-53V85 53" Rear Projection...
Sony KP-53V85
I need the model number to give you exact answer..i suspect power supply it is probably a sony tv common problem regulators go bad and cold solder joints or samsung.
thanks DOCTOR VIDEO
Apr 25, 2008 | Sony KP-53V85 53" Rear Projection...
Herringbone pattern
Herringbone (and other patterns) can be caused my many faults, the obvious one the tech was looking for was a tuner/interference fault.
Another common cause is a faulty power supply.
Difficult to say without having the TV on the bench.
I'm a bit suspect about the $400 - $500 repair cost though.
Perhaps try another tech?
I doubt it's a DIY repair though.
Let's know how you get on.
Jan 20, 2008 | Sony KP-61V85 61" Rear Projection...
SONY REAR PROJECTION TELEVISION TV KP-53V85 53 IN
When the set turns off, does the red timer LED blink on the front of the set? If so, how many times does it blink? The number of blinks corresponds to the reason the set shut down.
Jul 05, 2007 | Sony KP-53V85 53" Rear Projection...
Sony KP-61HS10 61 in. Rear Projection Television
plug it out to reset itself and if that does not work,you will have to call a tech as the tv has a problem in its power supply an its related circuit good luck.
Apr 06, 2007 | Sony KP-61HS10 61" Rear Projection...
Sony KP-53V85 53" Rear Projection Television Logo
213 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
