Question about D-Link Computers & Internet
How to put dsl-320T in full bridge mode?
I have a DSL-320T and need it to run in Full Bridge Mode so that my firewall router (netgear FVS338) can get a public IP address and gateway.
I've tried the bridge mode available through the admin console but this appears to be some form of half bridge mode.
Any ideas?
Thanks in advance.
You could install Router Techs firmware on your modem www.routertech.org and it would give you the option to put the modem in full bridge mode. However I'm not sure the hardware on the modem fully supports it. You might have to use half bridge mode and let your router do the DHCP.
Posted on Dec 05, 2010
Access to bridge mode
What do you want to know? How to put it into bridge mode or how to get it out of bridge mode?
It depends on what driver you install for this device. The WAN driver gives you PPPoE/A and the LAN driver gives you bridged mode, Dlink appear to have a tool for removing drivers which I see as a very bad sign.
This is a pretty old device - the drivers I'm seeing go back to Windows 98 and Mac OS9...
Apr 05, 2012 | D-Link DSL 200 (DSL-200) Modem
Just got wpn824 and having problrms with pppoe login and pass. Using att dsl ...but that login isn't working
You'll need to set your DSL modem up for "bridge mode". Right now it's acting as a router as well and that's keeping your new router from making the connection. In bridge mode, the modem acts only as a modem to connect to AT&T. Then your router will provide your login information and your computers will connect through it correctly.
You don't give your modem model so I can't give you any specific directions. A Google search for "bridge mode" and your modem's make and model should turn up the information you need. Or you can call AT&T's technical support number and ask them how to configure your modem. (Sometimes these big ISPs aren't too keen on helping you, though. They'd rather supply you with a wireless router/modem at an extra charge.)
Hope this has helped. Thanks for using Fixya!
Feb 15, 2010 | NetGear RangeMax WPN824 Router
Belkin F5D8236-4 won't connect to the internet.
this issue mostly comes with dsl connections..
check whether the dsl modem is in bridge mode or pppoe method
if it is in bridge mode ask the isp vendor to change the modem into bridge mode which prompts you for username & password
try this it resolves the issue..
Apr 19, 2009 | Belkin (F5D5231-4) Router
Hi! I use bellsouth dsl on my Medion desktop. Got a small Acer notebook id ike to add to the dsl network but - do not know how to do it. Can two wires (cables) run from one modem to both computrs? Can iT...
You will need to connect a router to the Westell in order to use more than one computer with your dsl. That modem will need to be put in bridge mode in order to allow it to work with the router.
Call ATT/Bellsouth support and tell them you need to setup your modem for bridge mode and connect your Linksys router.
Mar 15, 2009 | Computers & Internet
Ip problem
It is common to have this as the default IP to connect to equipment.
I suggest you unplug your modem while you set up your router. You can also change the default IP for the router while in the settings. be sure to remember the new IP or you will have to do a factory reset to get it back to default
Jul 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Can't get Trendnet TEW-432 router to connect to internet with motorola modem
I had this same problem. I was going to go ahead and call ATT and ask them to put my modem into bridge mode, but I messed around a bit more....
I went ahead and turn on PPPoE...tried to run the set up again. Well it worked. Not the internet connection is working through the modem. For some reason, the setup changed PPPoE back to DHCP Client, but it's working now. Give this a shot before calling ATT if you like. Good luck.
May 13, 2008 | Trendware TEW-432BRP Wireless Router...
Slow Internet
upgraded the latest firmware in the router, reset your router and reconfigure it, check if your dsl modem is configured in a bridge mode if not configure your modem in bridge mode and reconfig your links router accordingly, that will fix your problem
Nov 26, 2007 | Computers & Internet
Speedstream modem 4200
put the modem in bridge mode and then connect a DSL/cable router to it...you'll have to configure the PPOE if its DSL... Cable is a little easier because there usually is a MAC authientication not username and password...plug dsl/cable router into cable modem...turn both off for about aminute then turn modem on first then router... Be careful most routers with wireless have it enable with no security by default...turn it off or set securty (wirelss that is)
Aug 27, 2007 | Siemens SpeedStream 4200 (13A4200001)...
Computers & Internet Logo
1,419 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
