Question about Panasonic PT-47WX53 47" Rear Projection HDTV
No power...light just blinks
When I power on the TV is comes on for a second, then shuts off...the power then blinks steady. Any solutions on how to fix this? Thanks
  • shawnandshy May 19, 2008
    It blinks 3 times.
  • shawnandshy May 23, 2008
    Thanks so much!!! I hope it's an easy fix.
  • Panasonic Master
  • 8,617 Answers
Can you tell me how many times its blinking before pausing for a second as thats an error code function of that model set.
Posted on May 18, 2008
  • Sonny Berry
    Sonny Berry May 19, 2008
    3 blinks means the set is shutting down due to the convergence. You will need to replace both convergence ICs they are STK392-110 you can get new replacement ICs at the following link and they come with instalation instructions with pictures so you can do the repair which takes about 30 minutes and saves about 400 dollars by doing it yourself. Requires basic soldering skills. Heres the link.
  • Sonny Berry
    Sonny Berry May 23, 2008
    Yes its a very easy fix, and if you get the parts from the link I posted they will even provide free instant messageing with a tech if you need it during the repair in addition to the free instalation instructions
First blinking green light tv would turn on for a few minutes then turn off, pushed reset button and unpluged but problem would continue now theres no sound no picture and just a steady red light. Please...
The red light is indicating the set has shut down for a specific reason. You can dtermine the reason by going to the sets front panel and pressing the menu button and the device/input button both in together and hold for 6 seconds. The light will switch and begin to blink a series of blinks( First number) and pause briefly then blink another number of blinks (second number) then it will repeat that same two digit blink code. Let me know the code and I will let you know what happened to shut the set down. Respond to this same post for assistance.
Aug 12, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Tv cycles on and off
Sounds like bad capacitors in nthe power supply, or maybe a regulator in the power supply. Have a tech take a look at this TV set for you, as there are no user replacable parts available in the TV set. Good Luck
Jun 09, 2007 | Panasonic PT-52DL52 52" Rear Projection...
The power light is just blinking red on my panasonic 1080i hdtv. cant even switch it off using the power button. picture and sound come on for about a second when the tv is switched on after power cord...
The power light keeps flashing and the tv won't turn on. If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old.
Jan 01, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
Mitzubishi projection tv power shut down and won't power back up. green light comes on for a second then it shuts down immeditately
MOST Mitsubishi sets have a self check feature:
When power light goes off: On the front of the set press and hold MENU and INPUT (device) BOTH FOR 5 SECONDS OR LONGER AND RELEASE.
POWER light should blink a two digit code: for example:
2 blinks, a pause and 2 blinks----it will repeat the error code several times.
2,2 is the most common and the least expensive to fix.
LET ME KNOW EXACT MODEL NUMBER and the blink code and I will tell you what it means and if 2,2 how to fix it.
If this information helped you, rate this solution as I do this here for FREE.
Nov 14, 2009 | Televison & Video
Panasonic PT-51HX41 51 inch
the blinking power indicator is actually a error code. How many times does it blink as I can assist you if you let me know how many times the led blinks
May 28, 2009 | Panasonic PT-51HX41 51" Rear Projection...
I have a mitsubishi 1080 projection tv. I wont turn on, the green light just keeps blinking.
Check the manual...blinking green light is normal. The unit is powering down cooling the lamp. It could have been a shut down command through pressing the off button by accident. If problem continues I would unplug tv and power on/off. Steady green. Next to the lights is a small indentation where you can reset the TV to the defaults. Take a paper clip ...power on..and put in the center. The green light will blink for a minute or two then go dark. THen power up.
Dec 10, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Tv shutting off
it sounds like it may be a capacitor problem and it may be linked to the electricity you receive adding a battery back up of sufficient quality will smooth out the electric current and also **** up the spikes from the power and light company. I have seen many aquas suffer from capacitor failure but it may be an expensive fix.
check your electric output and see if it can handle the load for this tv.
Apr 28, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Lamp will not come on
try pressing and holding the enter button on the projector for about 30 seconds - this resets it. It worked for me!!
Feb 10, 2008 | NEC VT460 Multimedia Projector
Tv shutting off
How many times per second does the POWER led blink? (dont worry about the OPC).
1x per second (constant, steady blink) = bad inverter/lamps
2x per second = bad power supply
3x per second = bad main board
You can buy the parts online and fix if yourself!!
Dec 02, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic PT-47WX53 47" Rear Projection HDTV Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
