Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Mr.Slim Mitsubishi dual zone system
Our Mr.Slim dual zone system has two 15,000btu indoor units with matching outdoor compressor. I can turn both on and it cools well but after a little bit one or the other will continue blowing but not cooling even though it has not reached the temperature (for instance 75 degrees) while the other continues cooling well below the temperature requested. It feels like we're chilling milk in one room and way too warm in the other. I tried resetting the remotes but it didn't change anything. It seems that whichever indoor unit comes on first is the one to stay on and keep cooling and the second one turned on is the first to stop cooling. The fans work great and dampers etc is top notch but it seems like the refrigerant stops passing in one or the other for some reason. Any fixes that can be done? Surely both can be run at the same time! Thanks for giving this a think.
  • laforice Jun 08, 2008
    have the same problem. In addition, I have a third unit in a location not far from one of the problem units. When that one is on, it seems that the temperature of the problem one is regulated by how cool that one gets. Bottomline - it seems that when the working one begins cooling off the zone it's in, the problem one starts cooling as well. The zones for both the working unit, and one of the problem units are in an open space similar to a loft.
We had that problem with two units that we just had installed. Both are hooked up to one compressor. After several calls and the service person coming out twice, it turned out that they had two wires mixed up when they did the installation. Once they switched the wires the units ran ok.
BUT...now we are having another problem with the units/compressor not working after losing power in our house. We lose power on a regular basis here. Does anybody know if that means we will constantly need to call the service people to come to get the compressor working again? Or is there anything we can do to reset it? The service person that came today was not very helpful and didn't have a lot of answers for us.
Thanks
Posted on Jul 23, 2008
Icing up outside. no heat inside
Isolate unit to defrost out door unit,
Once defrosted run unit ensuring heat from unit inside and fans are running outside,
if fans and compressor are running and there is next to no heat inside coming from indoor unit this is a common sign of a refrigerant shortage in system and this may cause outdoor unit to freeze up
Jan 24, 2016 | Mitsubishi Electric Mr Slim E12C26426...
There is a bad smell coming from the indoor unit of my Mitsubishi Mr Slim split-type a.c.
Mitsubishi MSZ-GE06NA Mr.... Repair Questions - Fixya
www.fixya.com/.../p3677512-mitsubishi_msz_ge06na_mr_slim_wall_m...
Recent Mitsubishi MSZ-GE06NA Mr. Slim Wall Mounted Indoor Unit Air Handlerquestions, problems & answers. Free expert DIY tips, support, troubleshooting ..
Jul 26, 2015 | Mitsubishi MSZ-GE06NA Mr. Slim Wall...
Mitsubishi mr slim compressor fan won't turn off
The outdoor fan is supposed to be on almost all the time if the indoor unit is on. It is designed to do this due to energy consumption is from the start of motors. These fans use nearly no electric about as much as a light bulb. If your unit is cooling and no problems have occurred then its probably doing what is supposed to
Jul 26, 2013 | Heating & Cooling
What does error code E6 mean? On a Mitsubishi Mr. Slim A/C
Code E6
Error detail Indoor/outdoor unit transmission error (signal receiving error).
Inspected unit Indoor.
Air Conditioning Fault Codes
Aug 01, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
P8 showing on air cond and air con is not working
P8-Abnormality in outdoor unit.
Solution:
1) Check the indoor/outdoor connecting wire in proper point.
2) Change the connection of electric wiring, if reversed phase.
3) Check the protection device, if malfunction, replace it.
4) Measure the resistance of the outdoor coil thermistor.
If the resistance is normal, replace the
outdoor controller board
Thanks.
Feb 05, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Its not working and flashing P6. Its a Mr Slim
dear sir/madam i think.... mr Slim A control R407c & R410a systems.
P6 = indoor coil frost protection in cooling or indoor coil overheat protection in heating.
Cooling
One of the 2 indoor coil sensors reads minus 15 deg C for 3 mins.
Heating
One of the indoor coil sensors reads over 70 deg C.
If you are sure the refrigerant charge is correct & system operation is correct then it could be a coil temperature sensor reading wrong temperature.
If you have one of those little monitor things which plug into the outdoor circuit board you can monitor the indoor coil temperature.
On later type remote controllers you can get all operating data like temp sensor data but you will need a service manual to do this.
Or you can measure the ohms resistance of the temp sensors & compare with the chart in the service manual. if you can do it by yourself do if not then contatct ot mitsubishi maintenance personnnel for furhter action, thank you hope answer the question please vote!
Sep 23, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Coils stop feeding intermittenly not always the same circuit
You could have a solenoid prblem or just low of refrigerant. Need a qualified service tech to check charge. Rusty
Jun 03, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
828 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
