Question about RCA RT2500 System
RE: RCA RT2500 Receiver
I am an owner of an RCA RT2500 Receiver and my unit had been working perfectly until a year ago. I am getting a very light static sound from one side of my speaker (left side). Although - I have sent my receiver in for repair to Radio Shack but they claimed that they had repaired it. Well I tried using my Home theatre system one week ago and I am still having the same problem. Now I just called the local Radio Shack Store (where I had sent it in) and they claimed that it may be my speakers and not my receiver and recommended I get a 9 volt battery to test each speaker (wire). They claimed that if I hear a very light popping sound that the speaker was OK and if I did't hear anything - then I've got problems with my speaker(s). What do you think could be wrong? Thanking you in avance for your suggestions. GS
  • 682 Answers
Take the cable of right speaker(which is ok)and put it instead of the left cable if it is ok-your problem will be in your left speaker or its cable-if it is not working the problem in your receiver output stage.(left channel path problem)
Posted on May 18, 2008
Receiver doesn't play sound until it's warmed up 5 - 10 minutes
Unfortunately, your question has too many variables. Try this. Unplug the unit. Plug it back in. When you first push the power button, you should immediately hear one mechanical click from the unit, followed by a second click with 5-10 seconds. If you don't hear the second click, the unit may have a condition known as DC Offset. It would be unusual to have DC Offset only within the first 5-10 minutes. It's possible that power supply has an issue where both the positive and negative voltages are not coming up at the same time.
If you are interested in having your RCA repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
May 22, 2015 | RCA RT2500 System
How come I don't get any sound from my RCA rt2500 audio receiver?
I've owned this receiver since the Summer 2001 and it worked well until the audio became intermittent several years later. Eventually, the unit was ON but all sound was dead. It turns out that there are solder joints that developed tiny solder breaks. These were found in the main power board on the large electrolytic capacitors and on the 7 power tab transistors that share a large square heat sink. Thermal cycling can cause microscopic solder joint breaks over years of use. After I re-soldered the broken joints the unit worked properly and is still in use in 2017. Consult a qualified electronics repair technician for the repair, which can be accessed via the removable panel on the bottom of the cabinet. Of course, be sure the unit is unplugged from AC power before starting your inspection and repair.
Aug 21, 2014 | RCA RT2500 System
Lost my remote for my RCA RT2500 Audio/Video Receiver and i cant turn it on because the power button is stuck on standby. I purchased another remote model CRK76 but it wont turn unit on. I also unplugged...
You need to confirm if the power switch is working as the button is stuck . So it is best to get this part corrected before we move to the remote as the power switch or the button aligment can be corrected if you open to check the continuity.
Next the remote controller must be checked for the IR outputs. please check this link below for tips to repair or find a link for a universal type remote.
http://www.fixya.com/support/r6178946-tips_repair_remote_controller
http://www.espares.co.uk/search/remote-controls/p/1090
Oct 06, 2011 | RCA RT2500 System
A few weeks ago i would not get any sound then after the unit would warm up i would get a static sound for a while then it would clear up and be fine. Now no sound when i turn it on but after it warms up i...
Check all you wire connections to speakers and in the back of the receiver.If one is lose especially behind the amp it will create static noise..Did you move it around recently?It might have pulled a wire.Another thing that could cause that is build up of dust on the circuit board..Blow the inside out with a can of compressed air threw the holes in the side..Also check to make sure that in the wall outlet that you have it plugged into that its the only one there because that will also pick up static noise from the other accessories that you have plugged into it.Hope this helps you and have a great day...
Dec 07, 2009 | RCA RT2500 System
I have an RCA RT2500 audio-video surround sound receiver about 10 years old. For the second time in its life, a power fluctuation has knocked it out of service. The standby light comes on, but no power to...
Hold down the power button and unplug the unit. Now release the power button. Plug the unit back into the wall. Now press the button. The system should power up.
Oct 22, 2009 | RCA RT2500 System
What is the remote conrol code for an RCA A/V Receiver?
If you are looking for a code to program a universal remote, you probably won't find one. Universal remotes are for TV DVD VCR and Cable boxes. A replacement remote might be found at MCMelectronics or Vance Baldwin. I would guess $40-$60
Jan 14, 2009 | RCA RT2500 System
RCA RTD315W Receiver/DVD LED display
If you are referring to the information display, it doesn't activate until you take the system out of standby (the bright blue LED at the corner is shining). When you hit the OFF button (on the system or the remote) and the blue LED shuts off, your info display comes on and says WELCOME.
Dec 27, 2008 | RCA RT2500 System
RCA Home Theater Receiver won't work
I had the same problem but it happened 2 years ago. i went out and bought a new receiver for $200. The RCA receiver has flaws and isn't worth fixing
Jan 24, 2008 | Audio Players & Recorders
No Sound
Maybe the speakers are no good. Have you tried hooking up a different set of speakers?
Oct 11, 2007 | RCA RT2500 System
RT2500 speaker hum buzz until unit warms up
i have the same system that i bought new and after about 3 yaers it did the same thing for no reason. i think you get what you paid for!!!
Oct 20, 2005 | RCA RT2500 System
RCA RT2500 System Logo
266 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
