I am trying to add a program by cd to my harddrive for later use
  • 67 Answers
If you just want to copy the program and not install it, do this.
op the cd. choose everything and rightclick + copy.
then go to the destination folder a rightclick + paste.
Hope I helped you problem.
CS.
Posted on May 18, 2008
Need scsi/raid drivers on floppy to install winxp pro (at f6 prompt)
Hello the drivers can be downloaded here:
http://www.tyan.com/support_download_drivers.aspx?model=S.S2865
You need to unzip the file before you install the driver.
It should not be nessesary to install drivers before installing the windows system.
Check your bios boot settings to boot from the cdrom or dvd drive.
The cd or dvd drive must be the first boot device in order to boot from the windows disk.
Install windows with only one harddrive.
You can also add a harddrive later, when the installation is done and all drivers is installed.
Good luck
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
Cant install server 2012
Hello download a manual from the homepage:
http://www.supermicro.com/products/motherboard/xeon3000/3210/x7sbe.cfm
Check the settings in the bios.
Try to reset the bios to factory default.
And setup basic boot settings for the drives.
First boot device: cd/dvd
Second: the harddrive.
Try installing with only one harddrive (you can always add more later)
Check also the cd/dvd drive for fault.
The Os server 2012 is supported.
Good luck
Nov 22, 2012 | SuperMicro X7SBE Server Board -...
Slow start with home edition of xp
The HP Pavilion a350n Desktop PC, came out in late 2003.
This suggests to me, that you may have had the computer a long time.
You need to clean the harddrive of,
A) Unnecessary files,
B) Fragmented files,
C) Unused programs, and applications,
D) Plus frequently defragment the harddrive.
A, and B.
The best method is to use a Registry Cleaner. I recommend a Free one.
Why?
A) It is Free.
B) It works as well, or better than the paid fore versions.
CCleaner.
This is Wikipedia, and the article on Ccleaner,
http://en.wikipedia.org/wiki/Ccleaner
The home page for Ccleaner is on the upper right, underneath the illustration.
Should you wish to download, install, and use this free program, come back with a comment, and I'll walk you through using it.
After you know how you'll find out it's really easy.
Every time you go to a website, you pick up cookies. These are harmless, but after a given time they take up space on your harddrive.
Whenever your harddrive is more than 50 percent full, your computer starts to slow down. You really start noticing it, when your harddrive is more than 70 percent full.
30 percent Free Space.
With Windows running, Left-click on Start, then Left-click on My Computer.
Look at Local Disk (C:)
This is your harddrive.
What percentage of Free Space do you have?
Don't see this? It could be the type of View you are using.
Go to the top header. Look for the icon that looks like a rectangle with 6 colored squares in it, and has a black triangle pointing down.
(To the right of the yellow Folders icon)
Click on the Black triangle. It's a Down Arrow. There will be a drop down list. Left-click on - Details
Now what percentage of Free Space do you have?
Whenever you have a program, or application that you have deleted, there will be file fragments left behind. These take up space on the harddrive.
When your harddrive has about 5 to 10 percent left of Free Space, your computer will crawl like a Snail.
You can't defragment your harddrive if you do not have enough Free Space left on your harddrive.
Go to Start>Control Panel>Add/Remove Programs.
After the Add/Remove Programs list has populated, look for programs, or applications you may have installed, and rarely, If ever use anymore.
Get rid of the one's you don't need.
DO NOT Remove any Windows programs!
Unused programs/applications take up harddrive free space.
After you have removed all programs/applications that are unused, run Ccleaner.
Clean the Windows registry.
D) After you have enough Fee Space on the harddrive, you can run defragment.
(Start>Control Panel>Performance and Maintenance>Rearrange Items on Your Computer to Make Programs Run Faster.
If you do not see Performance and Maintenance, you are in the Classic view.
If you go up to the top left corner, you will see the Control Panel heading, and underneath it -
'Switch to Category View'
Left-click on it. If you desire the Classic View again, you can always switch back)
You may get a comment about using your restoration CD disk, to restore your computer.
1) IF, you still have the Restoration CD disk, you have my respect! Very few of us still have this disk after 3 years, much less almost 7.
2) BE AWARE, that you will restore the computer back to the way it was, when it came from the factory.
Back to Day 1.
FROM THE FACTORY
This means any Programs, or Applications you have installed, or downloaded, will be GONE!
This means any personal documents you have will be GONE!
My Photos, My Videos, My Music, and any saved documents, or documents you have made. (My Documents folder)
GONE!
Just wanted you to be aware of that.
Back up your personal documents to CD, or DVD disks. (DVD-R, or RW for videos)
You need the program, or application CD disks, to put them back on the computer.
You cannot copy them to a disk.
I await your questions.
joecoolvette
Dec 20, 2009 | HP Pavilion a350n PC Desktop
Hello
Then you need to decide if there are any downloaded programs, or programs you have installed, that you can live without. You need to make space on your harddrive, for the software from the webcam CD disk.
Suggest you go to Add/Remove Programs, and see if there are programs YOU have downloaded, or installed, that can go Bye-Bye.
Start>Control Panel>Add/Remove Programs. After the list has populated look through the list. Be CAREFUL of what you are removing! (You click on Remove)
Make sure the program you are deleting is one you don't need, and haven't used for a long time.
Aug 15, 2009 | Creative Labs WebCam Live!
Camera wont connect to computer anymore, use to but now not working. 1st says its in use try again later and then says not connected check cables..
Did you try uninstalling program by going to Control Panel > Add or Remove Programs > look for Fuji FinePix and click on Remove, then re-install with CD Disc provided with camera.
Jul 26, 2009 | Fuji FinePix Z10fd Digital Camera
Windows xp will not boot
If you just installed windows then take the cd out and let the computer reboot on its own. Windows will ask you to replace the OS disk later.
So just restart the computer with nothing in the CD drive.
Also make sure in BIOS that the Hard drive is the first boot device. Don't need the CD drive as first anymore.
See if that helps.
Brian
Jul 09, 2009 | Intel Computers & Internet
My problem is my mainboard being a m2n mx se plus [replacement board] is only a two days old.When I ripped a cd to my 2nd harddrive it came up with following Delayed Write Failure and then later on this...
Check your second harddrive. First check its connection try to reseat it. Secondly, maybe its failing and somehow messing your CPU to boot up. You could try to disconnect your second harddrive for the meantime its power connector and interface cable. Then boot up with only your 1st drive where your OS is installed I suppossed.
Boot up, if this boot with no problem, 2nd harddrive is failing.
Apr 04, 2009 | ASUS P4V8X-X Motherboard
How do I burn a CD with my pictures, then show them on my computer? Can and how do I delete the pictures on the computer?
Your question was not quite clear "then show them on my computer"
1.) You can use a third program software like nero.
To use nero, you have to "purchase" it first, then install nero, then open "Nero burning ROM" application usually either under
"program files\Ahead\Nero\Nero Burning Rom\nero.exe"
or
Program Files\Nero\...\Nero Burning Rom\Nero.exe
Select the option CD-ROM Iso, then select multi session(if you want to add pictures later) or no multisession (if you dont want to add pictures later)::: For example, your CD takes abour 700MB of data, but you only have 10 pictures @ 30MB or so then you most likely to use multisession.::: Then click on the "new" button to start compiling your cd.
Then you can add your files into your compilation. You can give your CD a name by either double clicking on the little disk icon to your right in the first nero and changing the name OR by selecting "File" from the menu, then selecting the "Compilation properties" option, then click on the "Label" tab, and change your cd's name there.
All you have to do now, after you have given your cd a name and added files to the compilation is to find and click on the "burn" icon located in the nero bar below the "file, edit, new menus".
2.)If you have installed nero, you can also use Nero smart start 2 complile your CD. Benefis: Much quicker and easier to use.
Apr 16, 2008 | Computers & Internet
Before installing Windows XP Upgrade
In order to update your system from the current Windows operating system to Windows XP Home, there are several steps that need to be taken prior to upgrading. Please follow the items listed below in order to prepare for Windows XP. Uninstall Trend PC-cillin2000 Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click install/Uninstall tab, select "Trend PC-cillin 2000". Click the Add/Remove button to uninstall "Trend PC-cillin 2000". Uninstall NTI CD-Maker 2000* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the Install/Uninstall tab, select "NTI CD-Maker 2000". Click the Add/Remove button to uninstall "NTI CD-Maker 2000". Uninstall Intel LANDesk Client Manager* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "Intel LANDesk Client Manager 6". Click the Add/Remove button to uninstall "Intel LANDesk Client Manager". Uninstall PowerDVD* Click the Start button located on the Windows taskbar. Choose Control Panel, highlight Settings and select Control Panel. Double-click the Add/Remove Programs icon. Click the install/Uninstall tab, select "PowerDVD". Click the Add/Remove button to uninstall "PowerDVD". * This software is optional. If this software is not installed previously, please skip the step.
Sep 11, 2005 | Acer n10 Pocket PC
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
