Question about Miele H147-2MB Convection/Microwave Oven
Miele H147 MB light cover
The glass cover of the interior light suddenly expoded into pieces. I wonder if I should contact a technician, the machine is still working.
  • 45 Answers
Is your machine still under warranty. If so then contact them and tell them what has happened.
Posted on May 19, 2008
What does F01 Code mean
I couldn't find the answer on the Miele web site, but here is a link to their contact page:
Contact Us
Nov 08, 2014 | Miele Classic Design H4084BMSS 24" Speed...
Tip
Change light bulb GE MOnogram Advantium Microwave oven
I have included a schematic of the interior of the built in Monogram Advantium Microwave oven Model KSC1001. The interior halogen light burned out and had to be replaced. GE service wanted $138 to come out & service it. I tried to find instructions on how to take it apart and remove the bulb & replace it on the WEB but had no luck with the Monogram series so I went to the dealer in Denver, CO and talked with their technicians and they gave me the schematic and sold me 2 bulbs for $11.00. The halogen bulbs can be purchased at Home Depot for about the same price. They are 35 watt with wide metal connectors.
Mine has 2 side trim pieces so these have to be removed first. They have latches on the top that slide behind the sides of the microwave and attach at the top. After removing the 4 screws holding the trim pieces, slide these upwards and then pull out to the sides. 2.) pull the microwave out and set it on a solid surface. 3.) there are approximately 23 screws that need to come out before you can slide & life the cover off the microwave 4.) Then look inside towards the front and left side (looking from the rear forward) for a small metal cover. There are 2 screws that hold it down. 5). Unscrew the 2 screws and gently lift the metal container up. This is the housing for the light bulb. 6.) gently pull the old bulb out and using gloves or a cloth insert the new bulb.You need to keep oils from your fingers from getting on the bulbs. The oils make the bulbs burn out quicker 7.) Put the container back and screw in the 2 screws being careful not to dislodge any wiring 8.) Slide the cover back on and replace all the screws 9.) plug it into an outlet and open the door to make sure the light works 10.) replace the microwave, plug it in and put the trim pieces back on. 11.) go to a movie with the money you just saved
on Feb 17, 2009 | GE Monogram ZE2160SF Convection /...
Tip
Change Light Bulb Monogram zsc1001kss01
on Feb 17, 2009 | GE Monogram ZE1660SA Microwave Oven
Need Glass that covers bulb lpool microwave
no plastic shield is required most of microwave oven comes with open light
Mar 29, 2014 | Whirlpool MH2155XP Microwave Oven
I need to change the interior light bulb in my Frigidaire over the counter microwave. The model # is FMV156DCA.
Good Morning Evelyn, thank you for allowing me to assist you!
Here are some simple troubleshooting tips to help replace the light bulb on your Frigidaire microwave, FMV156DCA.
    ·First, disconnect power to your microwave. This can be done by either unplugging it or at the circuit breaker panel.
    ·To release cover, remove the screw on the light cover (light cover may become very hot, do not touch glass when light is on).
    ·Remove old light bulb and replace only with equivalent watt bulb available from parts distributor or the manufacturer directly. Bulbs are also available at most hardware stores or lighting centers. Bulbs larger than 30 watts are NOT recommended.
    ·Close light cover and secure with screw removed in step 2.
    I hope this information proves to be helpful. If you have further questions, please do not hesitate to reconnect.
Nov 25, 2013 | Frigidaire FMV156DC Microwave Oven
Miele H147-2mb not heat when microwave other function OK
Check the door safety interlock switch. More than 90% of problems like this are due to failed safety switch. Switch fails because people open the door when the oven is operating.
Mar 17, 2013 | Miele H147-2MB Convection/Microwave Oven
Hi, our Miele Classic H147-2MB, we have had for about six years. The oven and grilll aspectys still work fine, but the microwave function has stopped working. Any ideas? Also, as an aside, the markings...
Hi - it can be repaired - there are a few things that may have gone AWOL with the machine - there is the Magnetron (specially made), the door interlock, HV transformer, HV diode.
The only way is to have it inspected and the above components tested for failure - it could any of these or a combination of two - there is a control fuse also which is likely to be blown as well. The magnetron would be the expensive component and Miele units are unque design where other brands would not be compatible.
Jun 23, 2011 | Miele H147-2MB Convection/Microwave Oven
Hi, our Miele microwave doesnt seem to be microwaving !!! It is a H4060BM combination oven Everything is operating normal and no faults etc showing but when we are trying to microwave if turns on and...
Hi - the most likely problem is the HV Diode or the Magnetron, other possible one is the capacitor & door interlock, its counting down so the interlock has to be ok.
The control fuse (8A) is likely to have blown and if its the case then the magnetron unit is highly likely to be the cause. The HV Diode can be tested with a Insulation tester conducts one way only, more accurate than a multi meter to see if this has blown as well. One other component is HV fuse has a white casing fixed between the high voltage transformer windings - u wont miss this one.
Then again perhaps a serviceman is your best option - be prepared for the cost of repairs.
Jun 05, 2011 | Miele H147-2MB Convection/Microwave Oven
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
Miele H147-2MB Convection/Microwave Oven Logo
206 people viewed this question
Top Miele Microwave Ovens Experts
William Miller
William Miller
Naveen Sistla
Naveen Sistla
Level 1 Expert
Are you a Miele Microwave Oven Expert? Answer questions, earn points and help others
