When printing from the computer a piece of paper became jammed inside the printer; this has been removed but the printer still won't print even though the USB cable is securely in place.
  • 67 Answers
The printer maybe still jammed. try to turn off the printer and disconnect it from the pc.
then turn on and connect it again.
if this not work, you can reset the printer somewhere.
CS.
Posted on May 18, 2008
I have a piece of paper stuck in the top of my hp 1012 printer and I cannot get at the area where the paper is.
Follow these steps to remove jammed paper from the printer
1.Open the print cartridge door, and then remove the print cartridge.
NOTE:  Opening the print cartridge door and removing the print cartridge relieves tension on the product rollers, which prevents damage to the product and makes the removal of jammed pages easier.
Figure 1: Open the print cartridge door and remove the print cartridge
CAUTION:  To prevent damage to the print cartridge, cover it with a sheet of paper to minimize exposure to direct light.
2.With both hands, grasp the paper where it is most visible, including the middle, and then carefully pull the paper straight out of the product.
Figure 2: Remove the jammed paper
3.Look inside the product for any torn pieces of paper or labels, and then remove them.
4.If any jammed paper remains in the input tray or the output tray, grasp it with both hands and gently remove it.
5.Reinstall the print cartridge, and then close the print cartridge door.
Figure 3: Reinstall print cartridge and close print cartridge door
1.Press the Power switch to turn off the product.
2.Wait 30 seconds, and then press the Power switch to turn on the product.
Happy printing.
Regards,
Shrey
Jun 02, 2011 | Office Equipment & Supplies
My printer got jammed with the paper. i took the paper out and clicked print again. the printer is still not printing. i restarted my computer but it still doesn't work. what do i do??
Power off your printers and remove the cartidge and power on.the printer will re-alligned itself and check if it work.If even some small piece of paper is stuck inside the printer roller,it will still give you paper jam message.If that is the case try to print test print from the printer itself.
Dec 22, 2009 | HP LaserJet 1000 Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
My hp laserjet 1150 series stops printing after a paper jam
you probably have a piece of paper inside printer or you have damage a paper sensor path while removing jammed paper.
Jun 22, 2009 | HP LaserJet 1150 Printer
MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
Open the paper jam cover at the back of the printer and remove the jammed papers, be sure you return properly the cover afterwards. Re-start your machine.
Mar 02, 2009 | HP DeskJet 3745 Printer
Paper Jam in HP4385
Paper can jam inside the printer for a number of reasons.
  • Open the cover to the printer and look inside to see if there are any pieces of paper or debris that may be blocking the print path.
  • Be sure to unplug the printer before touching anything internal to avoid electric shock. If there is something blocking the print path, remove it, close the printer, and try printing again.
  • You can also check inside the printer to see if any components have come loose.
Oct 29, 2008 | HP Photosmart C3180 All-In-One InkJet...
Paper jam
hi,
try to easily pull the paper out even if is a "tight stuck"
you have to firm grab the piece of paper and gently pull it out millimeter by millimeter
Sep 08, 2017 | Brother HL-2040 Laser Printer
Paper jam!!
Please perform the below steps.
1. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
put the cables back and switch on
Aug 25, 2008 | Brother HL-2070N Laser Printer
Paper jam
I have had this problem, and have became very furiated.
Clear the Jam by removing and paper you see in from the rear access door.
If you are printing something from a PDF website....... make sure to have it still in the printer schedule.... It will still say printer jam..... but have it there regardless if its something you dont want to have to retype into the pdf form........ After that simply restart your computer. It should resume printer as soon as your computer boots up.....
Worked for me..... Hope this helps everyone else whos probably cursing your printer at the moment!!!!
Mar 22, 2008 | HP Deskjet F335 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
