Question about Whirlpool Duet GHW9150P Front Load Washer
F/02 HI, My friend bought the Duet washer and it is giving the F/02 error after the first use.. Any suggestions? Can't return it to the store, bought it brand new off of craigslist. -Sarah
  • 5,911 Answers
"F02" is a Long Drain error. This usually is an indication of either a drain pump malfunction or something clogging the drain pump or drain line. You need to check the electrical connections to the drain pump and inspect the pump filter and drain lines for obstructions. If everything checks out, it is recommended that you replace the drain pump. Click on the following link for instructions on how to check the drain pump:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
If you diagnose the pump as defective, a replacement can be purchased at searspartsdirect.com. Just type in your model number in the "Search by Model Number" block and the part can be located as item 10 under the "Pump & Motor Parts" heading (part #8181684). If you do not wish to purchase on line, use the part number provided and go to your nearest appliance repair retailer. I hope you find this information helpful. Post back if you have any questions and/or need further assistance.
Posted on May 20, 2008
F- code 02
How to fix a Whirlpool Duet & Duet sport error code F02. Repairing your F02 error code can usually be done without ordering parts. Tools needed to repair your Duet F02 error code are towels and a quarter inch socket.
Tip the washer back at a 45 degree angle. On the bottom panel there are three or four screws, with the screws removed the panel will slide down and off. With the lower access panel now removed you will have access to the washers drain pump clean out.
With the water already bailed from the washer you can twist the filter head counter-clockwise to remove. Twisting the filter head counter-clockwise will loosen filter so it can be pulled out. With the filter out, clean and install back into washer.
Run a quick cycle to ensure the washer is back up and running and the F02 error has disappeared. If the error comes back it may require you to clean the drain pump filter again.
Dec 03, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does F-02 flashing on the display of my Whirlpool Duet washer mean?
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jun 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F 02 WARNING KEEPS COMING UP.. i FOLLOW THE MANUAL AND HIT THE CANCEL BUTTON TWICE AND UNPLUG THE MACHINE. I CHECK TO SEE IF THE LINE IS CLOGGED AND I CANT FIND ANYTHING.. THEN AFTER A WHILE IT STARTS BUT...
F02 is a drain error in your whirlpool Duet washer, if the unit is unable to drain then after 4 minutes it will display sud and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F-02 error code on whirlpool front loader duet
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loader
May 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F/02 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Mar 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet gives me an error code of F 02
"F02" is a Long Drain error code. This is an indication that there's an obstruction in the drainage system somewhere. Most commonly, the drain pump reservoir needs to be checked and cleaned. The access screws are on the lower toe panel directly below the door in the FRONT of the washer. They are located under the bottom front edge of the panel. You may need to prop up the two front feet of the washer to access them (a 2x4 works well for this). The following link explains:
It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
Replacements can be purchased online at any of the following websites:
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare.
If you have any questions about this repair, or need additional assistance, please let me know. I hope this helps you.
Feb 05, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My washer show error(f-02
F-02 means that it had a long drain. if the drain exceeds 8 minutes the water valves tuen off. sheck to see if there is a sud error. some of the cuases would be drain pump might be clogged, the drian hose might be kinked, there are foreign objects in the pump.
Oct 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F 02 Error Message
Hi!
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed.
Potential Causes
If still the problem persists then you need to replace the pump.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet whirlpool washer codes
post your email i will send you out the service manual What code are you getting??
Apr 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
69 people viewed this question
Dan Webster
Dan Webster
Sal De
