Question about HP f2105 21" LCD Monitor
No power...no light at all at the power button
Our approximately 2 yr old f2105 monitor just up and quit...my wife went to power up the pc the other day and the monitor never came on and there is no light at all on the off/on button...I have checked the power cable and put my meter on the cable and there is 120 volts going to the monitor...any help would be appreciated...thanks
  • Anonymous May 20, 2008
    Mine died on the same day. I went back to the Circuit City store where I bought it and they said that nothing could be done about it. I had to buy a new monitor.
  • Anonymous Mar 07, 2009
    my also went black i opened it up looked for fuse but can't find it can any body identify it if it had any fuse ?
Hi, have the same problem. But I have found the fault with the screen. The power supply unit in the screen has broken. 3 components damaged. One is identified but the other two has burned so well that they are beyond recognition. Wondering if someone have any pictures on the electronics inside the screen? Kind of sure that it's only the PSU that has broken. So doesn't feel good to throw away the screen, because I loved the picture. Thankful for any help. Best regards,
Posted on Jan 24, 2009
    Master:
    Sergeant:
  • 462 Answers
You will need to check your cable as well as fuse inseide the monitor. Checking the cable will reuire certain electronics equipments.
Thankyou
Posted on Jun 17, 2008
Maintaining functioning of Hp f2105 monitor
I would suspect the monitors internal power supply has issues. If you are capable of soldering and know some electronics replacing bad capacitors is doable at home. Try joining badcaps.net and posting your monitor problems there as that is how I found the info I needed to repair my HP W2207 monitor.
Apr 21, 2013 | HP Pavilion Computers & Internet
My hp f2105 monitor stays on for only 2 seconds and blacks out again how can i fix it?
The light comes from 4 luminiscent tubes. They are empowered by high-voltage power suppy. There is a circuit, that continuously monitor the lamps and the quality of the power from the low-voltage power supply. Either there is a faulty light tube, or there are inflated capacitors on the LVPS. First one is hard to repair due to need to open the LCD itself, which is hard and dangerous, the light tubes are hard to find and LCD is hard to clean perfectly when closing and appear dirty spots on the screen. The second one is easy - visually inspect the capacitors and if their top is not flat, then replace all of them with the relevant capacitance. I suggest to use capacitors for higher voltage (35V) thus making the PS lasting forever.
Apr 07, 2012 | HP f2105 21" LCD Monitor
On off button is broken on flat screen monitor f2105
Beverly, F2105 unit will need to be disassembled and new momentary tactile switch soldered in. Check out ALL the different styles and sizes to choose from at digikey.com !!! at least 16 pages of switches to choose from. Then you will need a soldering iron, solder wick, solder, and know how to disassemble unit to replace a $2 to $6 switch. If contracting out the work to competent technician your looking at minimum $45.
Forget fixing the plastic button. Crazy-glue only option there.
12fixlouie
Sep 20, 2010 | HP f2105 21" LCD Monitor
F2105 hp monitor went to sleep and cannot wake.
i cannot help you its either your moniter or the vga port at the back of you tower there the only things i can figue out
Jun 01, 2010 | HP f2105 21" LCD Monitor
HP f2105 monitor going into sleep mode on it's own
Does it do the same when you use this monitor with other PC, new VGA cable, just need to narrow down the problem first before start taking the monitor apart.
See pictures of what usually goes bad (mostly failed capacitors) with monitors:
http://s807.photobucket.com/home/budm/allalbums
Post back what you find so we can guide you further
Apr 03, 2010 | HP f2105 21" LCD Monitor
Sony ps 3 won't show initial screen. turns on/grn light is on indicating but nothing happens/ have chgd the rca cables/ chgd tv's/made sure not dusty chgd all inputs/still no resp//any ideas? also, no...
Turn off the PS3. Press the power on button (the system will beep) and hold it down for approximately 5 seconds until you hear a second beep. This will reset the video to the default. You should get a low resolution screen and be able to log on and reset the display to the desired settings.
Aug 23, 2009 | Sony Playstation 3 (PS3) Console
Hp f2105 only stays of for 2 seconds
Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
Jan 13, 2009 | HP f2105 21" LCD Monitor
HP F2105 2" LCD Monitor
it will be better you give it to shop
May 13, 2008 | HP f2105 21" LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
HP f2105 21" LCD Monitor Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
