Question about Crock Pots & Slow Cookers
Slow cooker not hot
Hi, This is my first slow cooker. Even at high the temperature of the water is luke warm. I expec this is not normal but I have never used one before. Is this normal?
  • 3 Answers
If you only have High and Low on the slow cooker this will be normal until it reaches correct temp, the trick is Do not remove the lid once you have started the process, you lose 20 minutes cooking time every time you lift the lid during cooking, if you have timed ex,4,6,or8 hours just set to required cooking time and leave until done. hope this helps clarabella
Posted on May 18, 2008
It seems that my Rival crock pot is cooking too slow even on high setting. It has not been used excessively. A smaller one I used years ago cooked whatever in the stated amount of time per high/low...
Hello, Calexander58 -
The heating element for your crock pot may have failed.
You can test it to determine if it comes up the to the proper heat.
Follow these steps:
* Make sure you have the kind of cooking thermometer which can be used to take the temperature of liquids, like one for candy making. If you do not have one, you may be able to borrow one from a relative or friend. Otherwise, you will have to purchase one.
* Fill your slow cooker with water halfway to the top
* Turn it on to the lowest setting and cover for 8 hours
* Do not remove the lid during the full 8 hours
* Remove the lid and immediately take the water temperature
The water temperature should be 185 degrees Farhenheit.
Information source:
How To Test Your Slow Cooker
https://www.spendwithpennies.com/how-to-test-your-slow-cooker/
If the water temperature is less than 185 degrees F, it is time to replace the slow cooker, if it is no longer covered by the manufacturer's warranty.
Jan 13, 2018 | Rival Crock Pots & Slow Cookers
I have inherited a west bend slow cooker model 84624 and dont have a manuel for it. I am concerned with the 300 watt is this normal? Or is that very low? I dont know how long to cook in this or amounts...
  • 1 Use setting 1 (warm #1) only to warm rolls and muffins. At 140 degrees Fahrenheit, this setting should not be used for cooking.
  • 2 Use setting 2 (warm #2) to keep cooked foods warm until they're ready to be served.
  • 3 Use settings 3, 4 and 5 (low, medium high) for cooking. The setting you choose determines the length of time the food will cook. A typical meal with meat and vegetables needs 7 to 10 hours to cook at the low or #3 setting, 4 to 6 hours at the medium or #4 setting, and 2 to 3 hours at the high or #5 setting.
  • All West Bend slow cooker models eventually simmer at the boiling point, or 212 degrees. The setting simply determines how quickly the cooker will reach that temperature.
    300 watt is not a huge consumption of electricity, depending of course on, how often, how long and how high temperature.
    Regards
    Sep 28, 2011 | West Bend 84624
    Cracks in slow cookers. what causes that and how can it be fixed?
    Cracks caused normally in slow cookers is normally caused from the unit being real hot, and then put under facet cold water. When the unit is very hot, and then is put under cold water before it has cooled down on its on to a warm temperature the dramatic change of hot to cold, cracks it. When its hot, its expanded, and then when it goes that fast to cold, it retracts to fast and causing cracks over a period of time, like stress cracks on air planes, when they go up they expand with cabin pressure, and when they come down to land they retract, over a period of time they get worn and cracks develop , same as a crock pot, except yours is with heat, the planes are with air pressure.You can't really fix the cracks. Well, you could have a shop fix them. but the cost would be way more than the crock pot. The only way you can help this from happening in the future, is after using it,before you wash it out let the crock pot cool down on its own for a while. Thanks Mike
    Sep 14, 2011 | Crock Pots & Slow Cookers
    Slow cooker will only stay on warm. How do I put
    This slow cooker has 3 settings LOW, HIGH, & WARM
    When you plug the slow cooker in the display should show a "0". When you press the "COOK TIME" button, the display should go to 1 then 2 then 3 etc. each time the "COOK TIME" button is pressed. If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on the "HIGH" setting. If 7,8,9, or 10 hours are selected, then the slow cooker will operate on the "LOW" setting. To start the cooking cycle press the "ON/OFF" button. To interrupt the cooking cycle at any time, press the "ON/OFF" button. When the cooking cycle is complete, your slow cooker will automatically switch to the "WARM" setting. If the "ON/OFF" button is pressed when the the digital display shows "0", then the slow cooker will automatically start on the "WARM" setting.
    If the "COOK TIME" button does not change the display numbers then unplug the slow cooker and hold both buttons down as you plug the slow cooker in. Keep the buttons pressed for a count of ten, then release them and the slow cooker should work correctly
    Feb 11, 2010 | CorningWare SC60 Slow Cooker
    Heat settings on enheat slow cookers
    Generally, the lowest number is the lowest temperature setting and the highest number is the hottest temperature setting
    Jan 02, 2010 | CorningWare SC60 Slow Cooker
    How do I start the cooker on low?
    The manual says "When your corningware slow cooker is initially plugged into a wall outlet, the display will show"0". This display indicates the programmed number of hours for which a meal will cook.
    The slow cooker can be programmed in one hour increments from 1 to 10 on your digital display. The number of hours may be selected by pushing the COOK TIME button until the desired cooking time appears.
    If 1,2,3,4,5 or 6 hours are selected, then the slow cooker will operate on HIGH setting. If 7,8,9 or 10 hours are selected, then the slow cooker will operate on the low setting.
    To start the cooking cycle press the ON/OFF button. To interrupt the cooking cycle at anytime, press the ON/OFF button. If the ON/OFF button is pressed when the digital display shows "0", then the slow cooker will automatically start on the WARM setting.
    When the full cooking cycle is complete, your corningware slow cooker will automatically switch to the warm setting, to keep food at a warm serving temperature."
    If, after you plug the slow cooker into the outlet, the COOK TIME button does not work, unplug the cooker, hold both ON/OFF and COOK TIME buttons down, plug into wall socket and wait till the display flashes. Release both buttons and the slow cooker buttons should both work.
    Dec 18, 2009 | CorningWare SC60 Slow Cooker
    The outside of my slow cooker gets very hot, is that normal? Also, on the low setting the ingredients seem to at a pretty high boil.
    Yes, many models have hot outsides. To check temp, fill with water, put on low for 1 hour, check with an instant read thermometer. If it is over about 200 (normal low temp), your pot is running very hot.
    Nov 24, 2009 | WeatherWorks CH-9350 Slow Cooker
    Can't change temperature-stays on "warm"
    Push the COOK TIME button, if the time changes then if you leave the number of hours between 1 and 6, and press the ON/OFF button, it will cook on high that many hours. If you leave the number between 7 and 10, and press the ON/OFF button, it will cook on low that many hours. If you leave the number at "0" then the slow cooker will cook on WARM. If the COOK TIME button does not work, unplug the slow cooker, hold both the ON/OFF button and the COOK TIME buttons down and plug it into a wall socket. After the lights flash a few times, release the buttons. the switches should work.
    May 19, 2009 | CorningWare SC60 Slow Cooker
    Rival 7 qt slow cooker
    O-is OFF I= is low II= is high WARM= is real low or keep warm
    Aug 28, 2008 | Rival 5070 7-Quart
    Crock Pots & Slow Cookers Logo
    169 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
