Question about HP PSC 1410 All-In-One InkJet Printer
Hello i tried to print certain files the printer is not operating at all. the lights are on however it would not accept the order print..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 93 Answers
Perform power cycle and semi-full reset.
Posted on May 27, 2008
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Mar 25, 2012 | Computers & Internet
Print is encrypted, nothing is readable.
If you are printing it from online, try copy and pasting the content to Word or Excel and print from there.
Oct 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
How can it set the printer up so that I have preferences i.e selection or number of copies or certain pages only?
This is done through the print software. Depending upon what program you are using, there may be more than one way to start a print job:
1) Click a print icon within the application - this will usually print with the default settings, (prints entire document, 1 copy)
2) Click the "File" menu, then select "Print..."
This brings up the print job with options for printing, for example number of copies, certain pages, order of printing etc.
If you found this advice helpful, please vote.
Jan 14, 2010 | HP Officejet J3680 Multifunction Printer...
I cannot print. When I order a print I get the question PRINT TO FILE (OUTPUT FILE NAME) I give a name but will still not print
this problem coming due to one option called print to file is selected in the printer dialog box ....to solve this problem open your document and give printer it will open one window to select the printer where you want to print in that window you can find a option (print to file ) unchecked the option and give print ..... it will print ( print to file option comes near to preferences option button )
Dec 31, 2009 | Epson STYLUS CX3900 All-In-One InkJet...
I have an Epson CX9400Fax all in one printer, fax, scanner. Yesterday it quit accepting print commands from the computer. It still copies, scans and saves scan files from the unit to the computer so I am...
Reinstalling the software is great, but did you first remove your printer usb cable, uninstall the printer and then re-install your software?
If not, do those 3 steps in that order and try printing again.
Best wishes,
Graemevm
Dec 17, 2009 | Epson Stylus CX9400Fax InkJet Photo...
Overheat message comes on.
First, you need to make sure that you are using the best settings for your printer. Here are a few things to consider:
1) Environment - If this printer is stored in a cabinet, under a desk, on the floor, etc., it is likely that any heat created by the fuser doesn't have room to escape properly. Be sure to give at least an 1.5" clearance on all sides.
2) Power - The parts inside of a printer are all rated to operate using certain voltages. That being the case, you need to use unregulated power (i.e. - wall outlet) to make sure the parts are given as much (and only as much) power as necessary to operate. Using powerstrips rated at different voltages can create either not enough or too much power which could mean the fuser operates at too low or too high of temperatures.
3) Media - Make sure the paper you're using is rated properly for the printer. Most printers accept a certain paper weight (found in the owners manual). Contact Dell if you've misplaced this.
4) This particular printer isn't rated for too high a speed, which means the fuser shouldn't have to run as hot. If you still get overheat messages, you could try updating the firmware on the printer at support.dell.com or even contact their technical support.
May 29, 2009 | Dell 1600n All-In-One Laser Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Problem with deskjet 810
In order to better assist you, I need to know your operating system, the amount of ram you have on your system, and what connection you have your printer hooked up with... (i.e. LPT port, USB etc.)
Nov 21, 2008 | HP DeskJet 810c InkJet Printer
Unable to install software ''PDF Pro Converter 5.11''
Most likely you are connected to a domain which is prohibiting you from installing new printer.
The problem with these kindda software like pdf Pro is that in order to convert files to pdf it creates a virtual printer and by printing to that printer you actually converting files.
Try loging in with an administrator account or try not to connect to the domain but to the local computer.
Thank you for choosing agadycom.
Nov 20, 2008 | Computers & Internet
HP 4350 ERROR MESSAGE: 49.2F90
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
HP PSC 1410 All-In-One InkJet Printer Logo
85 people viewed this question
Ben Johnson
