My honeywell st7100 CH &
My honeywell st7100 CH & HW controller has suddenly stopped working and fails to respond when i try to swith on either the CH or HW via the 'manual switch-on' or 'extra hour' options by pressing the buttons. The unit is approx 18 years old. Does anyone have any ideas what may be causing the problem ??
  • 3 more comments
  • Anonymous Jul 22, 2008
    Have changed batteries. Unit still fails to work.
  • mkmkmkmk Sep 13, 2008
    in set mode buttons work and screen lite once i press run it goes off any ideas on how to fix this fault
  • not a spark Nov 06, 2008
    All the readings had gone off, I changed the batteries reset the times, pressed run and the readings have dissapeared again. can anyone help or is this unit beyond repair. Its very cold and I would like to fix this unit this evening?
  • ppnpnp Nov 15, 2008
    Exactly the same problem as 'not a spark'. Help.
  • Anonymous Nov 19, 2008
    I have the same problem!!!!!!!!!!!!!!!!!!!!!!!!!
co7196
  • 3433 Answers
SOURCE: how to change battery on honeywell st7100 and what
Pull the unit straight out and away from the wall. It is plugged into the baseplate. The batteries are behind or among the 30 pieces in your hand and on the floor,,,, AH! Just kiddng, you wil see the batteries on the backside.
When pulling off use gentle rocking as you pull. You will see why when it is off. To reinstall, just line up the oinds and press in place.
Posted on Oct 27, 2009
  • 38 Answers
SOURCE: Volume and mute buttons suddenly stopped working
Try changing the batteries. Most times the "tivo" buttons will work but the "tv" buttons will stop working when the batteries are low.
If you have done that, go back into settings and program the remote again for your tv, then give it a shot.
Posted on Nov 28, 2007
SOURCE: Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
Posted on Nov 19, 2008
Dutch7773
  • 31 Answers
SOURCE: Ecoquest Freshair unit; fan is intermittent.
Hi Susan,
I have not experienced it but I know that if you bought your FreshAir from a dealer with EcoQuest you are entitled to a 3 year warranty.
Contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
If you are not in contact with your EcoQuest dealer anymore and the unit has never been registered with the company you need a purchase receipt with the date on it.
Hope this helps!
Eric
Posted on Feb 06, 2009
  • 4 Answers
SOURCE: Stopped Running - Control Panel CH 01
All, I had this same problem as well. I called the LG Support Line and they told me the unit needed to be serviced. I went through the motions of getting the service providers and what have you, but I wasn't going to go through with it because the closes service provider was a 45 minute drive. I posted how disappointed I was because I had only had the unit for a year, but could not find my earlier post.
Anyay, I am glad I went through the motions, because a few days later LG called and told me they would be shipping me a refurbished replacement. Wow. That was a treat. They shipped me a refurbished unit and had me send the old one back. I did not have to pay a dime. The sent me the Fedex shipping label via email and I called Fedex and they came by and picked it up.
I cannot remember if I had registered the unit when I initially purchased it. Sometimes I won't do that because it seems only to serve as a license to sell me stuff. They took down all my contact information and sent me the unit so I don't know. I would simply encourage everyone with the CH 01 error code to give LG a call via the support number from their website at lgappliances.com. Good luck!
Posted on Sep 28, 2009
Correct signal does not seem to be sent from the controler to the boiler,either CH comes on or HW but not necessarily when they are supposed to. Boiler engineers have been out twice and both times advise...
we had one of these and found out the battery inside had failed. the battery is none replaceable. did try to replace it but it lost its memory and was only good as a switch. think when the battery fails it loses it memory and things start going wrong. so would say change it. now thinking on it should of changed the battery why having the old one on and taken the old one off after installing the new one.
Mar 03, 2014 | Honeywell Programmable Thermostat Heater
Hw and ch not coming on auto , will come on if reset but following day will not come on again until reset , there is no red light on , on the time guard does this have any thing to do with it?
Hw & ch in my vocabulary means Hot Water & Chiller. I have never seen this on a thermostat. I'm also assuming by time guard, your saying time delay. The time delay only goes into effect if there is a power interruption.
Dec 02, 2013 | Honeywell Programmable Thermostat Heater
Heating and hot worker work separately but not together
If this a honeywell valve you may need to change the motor in side the valve , sounds like its lost some of it power to move the inside of the valve to y postion .
Nov 04, 2012 | Honeywell Programmable Thermostat Heater
Hi. We recently moved to a rented property. We have a ST7100 Central heating and a Potterton Profile 50e boiler. However even though I have set the times on the ST7100, the heating ligth comes on, but the...
You definetly have a control issue. However trying to diagnose the exact problems that you have would be very difficult without actually seeing the wiring. You defintely have a wiring/control issue but I cannot tell you exactly what it is without more info. Sorry, I would love to help you more...
Nov 13, 2009 | Honeywell Electronic Programmable...
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
My daughters honeywell ch/hw digital control resets to zero
have the batteries died have you got the programmer set back to timer control or is it still in the set mode
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
Honeywell junction Box and QE2 Programmer
Hi check the wiring to the cylinder stat is there power to it then is it going to the valve
May 15, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
649 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
