Question about RCA D52W19 52" Rear Projection Television
On and Off Problem
The capcitor you said was near the H. Is that on the same board as the FLYBACK transformer? or somewhere else
  • Buddy8 May 25, 2008
    i'm having the same problem. I looked inside the tv and have no clue as to what the H output is or what it loks like. Can you anyone steer me in the right direction.
  • RCA Master
  • 5,138 Answers
Hori out put transistor nte2324 ,not knowing your real problem check the second ribbon connector on power supply broad if not in good set will shut off.
Posted on May 31, 2008
Power on problem
this is hardware problem - replace flyback transformer & big transisitor fixed near flyback (replacing these two parts is compulsory ) - also check all small size transistors ( 6 to 10 transistors will be there on main board - see picture ) - below shown picture is only to get an idea as how these parts looks like & roughly where they are situated on main board ... that means this picture is not that of your monitor's main board - in your monitor there will slight difference & also that bigsize transistor's number will be different ....... for more details about flyback transformer check this link http://www.fixya.com/support/t10123898-panasonic_ct_36hl43g_tv_just_turned
Oct 30, 2011 | IBM E74 17" CRT Monitor
Hello, I have an old Sony Trinitron KY L34CF1 32" tv that has just developed a problem. When I push the main power button, nothing happens except that the little red led flashes. I f I push the...
turn (only by 2 to 5 degrees ) all the knobs on flyback transformer in clockwise direction & then switch on tv .............you will get picture atleast for 1 or 2 mins ............ this confirms only flyback transformer is defective ........ so it has to be replaced by new one .................otherwise transistor (big in size fixed near flyback with its back clamped or screewed to aluminium metal ) has to be checked ......if that is also fine then complete main board has to be checked ...... but flyback replacement is a must ........in your case iam 100 % sure only flyback is deffective ...........vishnuswamy_26.jpg
Sep 15, 2011 | Sony FD Trinitron WEGA KV-32FS210 32" TV
Standby mode 7 red brinks Check with sears ,estimate $218.00 board replacement, Tech charge $105.00 to tell me whats wrong, labor extra. Chucks repair estiment $400.00 . I have repaired TVs years ago....
turn (only by 2 degrees ) all the knobs on flyback transformer in clockwise direction & then switch on tv .............you will get picture atleast for 1 or 2 mins ............ this confirms only flyback transformer is defective ........ so it has to be replaced by new one .................otherwise transistor (big in size fixed near flyback with its back clamped or screewed to aluminium metal ) has to be checked ......if that is also fine then complete main board has to be checked ...... but flyback replacement is a must ........in your case iam 100 % sure only flyback is deffective ...........vishnuswamy_22.jpg
Aug 24, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
We replaced the transformer for our RCA F27650. It was sparking and now it is not, but now the screen won't turn on. It is just black. We hookd all the wires up like they were. we can hear sound, but...
Hello
Along with the flyback transofrmer, its horizontal output transistor also must be replaced. I don't know whether you have replaced it or not. If not, replace it too. It can be located very near to the flyback transformer, a three terminal component, black in colour, usually screwed to a metal heatsink. Then switch on the TV and measure the video output voltage at the video output card pluged directly to the picture tube neck. The collector of the video aoutput transistors must come around 145VDC. If it also is there, advance the screen control on the flyback transformer to get a raster. If that voltage is not there, it means that the flyback transformer is not working, and horizontal oscillator stage should be checked for oscillation, check the lined drive transformer for its primary winding open, Check the entire horizontal oscillator section. The collector point of the line drive transistor, the transistor that drives the line drive transformer, a small transformer soldered diretly to the printed circuit board; should be checked with frequency meter. The frequency at that point should come around 15525HZ approx: OK.
Mar 19, 2011 | RCA F27650 27" TV
I have 37MF321 we replaced the capcitors and everything. However when we put the power into it. We have a Chirping Noise.
Ur high voltage it dead.The FBT is dead,it the Flyback Transformer.The big black block of plastic with a red wire with a cap plug to ur CRT(Tv tube).The "H" Transistor might be dead also.The "H" transistor is to left side steel side wall cage that surounded the FBT.
Mar 15, 2010 | Philips Magnavox 27MS343S 27" TV
I cant figure out how to ge the deflection board
This should be a 400mA brown fuse beside the flyback (gray and black Transformer with 2 thicker wires comming from it.
Once the back cover is removed the deflection board is the board on the left (as your facing the rear of the set) Remove/unplug (deflection board side) all the wires (label or mark them first).This includesBP010,BP011, BP150 etc. The board is held by plastic clips around the perimiter of the board. you have to release the clips while raising the board working from the front to back from the left side tilting the board to the right.There are 2 clips that go through the board- one beside the flyback (right side) and one near the other transformer on the board (left hand side).
Sep 27, 2009 | RCA Televison & Video
RCA HD52w67 Started making a hissing , buzzing sound accompanied
The flyback transformer is super high voltage. Have it checked out by a shop, don't go near it. TV's can hold a charge for days.
May 03, 2009 | RCA HD52W59 HDTV Projection Television
Computer monitor
disconnect the flyback transformer B+ POINT. if the tick sound goes the problem may be in the flyback transformer. replace the transformer.
Apr 07, 2008 | SAMTRON 55V 15" CRT Monitor
RCA D40W20YX1 unknown chassis numbers
The flyback transformer is probably bad...it has a large red
power lead coming out that goes to the HV divider....need
drawing # s off the body of transformer to confirm correct
part #.....................T.
Mar 12, 2008 | RCA Scenium D40W20 40" Rear Projection...
Monitor repair
the neck board of the monitor needs tube replace it is corroded with carbon if you cannot get a replacementbuy a new monitor.but also check the flyback also it could be faulty replace it check www.dalbani.com for your monitor parts or repairworld.com,good luck.
Apr 26, 2007 | LG Flatron Ez T710BH 17" CRT Monitor
RCA D52W19 52" Rear Projection Television Logo
16 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
