Question about Sony PlayStation Portable (PSP) Console
My power switch
  • its loose
  • when I go to turn it on it doesn't start
    Scholar:
  • 102 Answers
You either have a broke power button or a bloew fuse on your psp. if its just the power botton you can buy a new one on ebay for about 10.00 and install it your self. if that dont work then u have a blew fuse and inlease you know how to solder on motherboards then your going to have to buy a new mother board which will cost you about 90-110 or buy a new psp which is about 170.00
Posted on May 20, 2008
Mk4 gti vr6 has power but doesn't start, runs with pop start
Could be a number of things but may want to begin by checking wiring to starter, battery, or even the ignition switch. These components may not turn your engine light on.
Jun 17, 2017 | 2003 Volkswagen GTI
88 s10 2.5 is getting spark and fuel but will not start with key switch
so it starts if you pop start it?if the engine turns over but doesn't start then its a bad ignition switch if it does not crank over see if you have power going to the small wire on the solenoid if no check the safety switch and wires at the switch if there is power to the small wire but doesn't turn over then the starter is bad
Aug 31, 2012 | Chevrolet S 10 Cars & Trucks
Cub cadet riding mower wont start... parking brake feels loose wont turn over
see if the rod fell off there is a safety switch on the clutch/brake pedals if the rod doesn't move all the way the switch will not make the connection
Jun 03, 2012 | Cub Cadet 42 And 54 Inch Blade Operator's...
Start button doesn't work
test the switch.
see the diagram below. God bless you
if the switch is o.k 2) test for continuity the wires 3) Test the motor input voltage motor. 4) Test the power cord for break or loose wires with VOM
May 24, 2012 | iRobot Roomba 530 Robotic Vacuum
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
Car wont start, NOT battery
sometimes a rubber mallet doesn't work on the stater, you actually have to hit it with something stronger, like a hammer while turning it over. If not check to see if you have a pro lock on your vehicle because if that becomes just a little loose it won't start.
Apr 23, 2012 | 2004 Chrysler PT Cruiser
My 1996 Olds LSS doesn't idle properly,idling surges sometimes,the temp. gauge doesn't work and sometimes the heater doesn't work.It may stall while driving.If I get in and the power seats...
Your first problem is to find out why the intermittent no-power problem. Honestly, that sounds like a loose conmnection somewhere. check all your grounds for clean and tight conditions Also, battery connections and alternator connections. Double check your power distribution center for any loose wires or poor connections. Once you solve that problem, then you can diagnose the other problems with poor idle and temp. gauge.
Oct 17, 2011 | 1996 Oldsmobile LSS
Brake lights don't work on my 2010 FXDWG and my right turn signal doesn't work either. There is a key icon on my speedo that is on in red.
Hi Ed, always check fuses and bulbs first for broken filaments. Then check the connection at the rear fender wiring harness, inspect for corroded, broken or loose pins. Use a dab of dielectric grease and repair as necessary. Check your brake relay if you have one , check your brake light switches for continuity, some models rear turn signals were single filament bulbs only, no running light. If all else fails get out your test light and start tracking the power wire from the harness connection. You could have a faulty turn signal module or a bad turn signal button/switch, remove it from the switch housing and check for continuity, check your wiring and connections from the turn signal switch to the turn signal module with a testlite. Make sure all wires are not worn or pinched and connector pins are not corroded, broken, or loose. For a free wiring diagram please visit the website below. You may also need an alarm reset. Harley Davidson Wiring Diagrams and Schematics
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Oct 07, 2011 | Harley Davidson FXDWG - FXDWGI Dyna Wide...
The starter doesn't start right away, the battery is good but no clicking sound is made, then after 10 - 15 minutes, it will start. what is wrong with the starter?
it may not be the starter motor it could be that the power isn't getting to the solenoid from the ignition switch, check all the wires & connections on the ignition switch to see if any are loose.........hope this helps.......cheers.
Sep 03, 2011 | Toyota Previa Cars & Trucks
The LED in my motherboard is on, but if i turn on the switch, their is no response. the power connection is correct. but it doesn't work
Try swapping the power button connection with the reset button connection. Then to turn on your computer you will need to press the reset button. If that works you have a faulty power button. Otherwise try using a different PSU. One that you know works. If that doesn't help the motherboard will have to be replaced.
Jun 18, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
