Question about NetGear MR814 Wireless Router
My computer is unable to deyect the wireless router
My name is Jacinta. I need to set up my wireless connection through my router. It is Netgear MR814 V3. Can you help
    Problem Solver:
  • 11 Answers
Jacinta,
If you follow the directions included with your router, it should be fairly easy. I assume you tried this and are having problems ? If so, can you elaborate on the nature of the problems you are experiencing ?
Thank You
Posted on May 18, 2008
How do i reset or changed the password of my router (netgear wireless router MR8v2)?
to configure the netgear router and to secure its network. . . .1, first make sure that your laptop is connected directly to the netgear router via ethernet cable.2. after securing step 1, on your computer, open browser, ( internet explorer or firefox )3. go to the address bar, the one with the http:\\ and erase everything inside it.4. type in there, 192.168.1.1 or www.routerlogin.net.5. username is " admin "password is " password "6. you would see netgear set up wizard. 7. for wireless configuration, click wireless settings on the left side of the set up wizard.8. you can edit network name, and get your network security key under security options. make sure to choose WPA PSK TKIP. so that you can have a personalize network key9. the network security key is the " passphrase "then click apply.then your all set for wireless connectivity.
Sep 16, 2011 | NetGear MR814 Wireless Router
When I connect my computer to Netgear MR814v3 router via wire, I can get internet on my computer. However, when I try to connect wireless internet, I can see my router's SSIP (the name I gave for my...
You have to enter the router password on every wireless device you want to connect to the internet. You usually only have to do it once per device, but it won't connect without the password. The password it's looking for may be on the label on the router or in the wireless setup page of the router.
May 09, 2017 | NetGear MR814 Wireless Router
I need to set up a password on my net gear MR814 .. What do I do?
How to secure the wireless network
You want to secure the wireless network.
Is there any computer connected to the router with the Ethernet cable?
If not then you will need to connect the computer to the router with the cable.
Check the IP address on the computer. Open the router set up page.
Once you open the set up page, you will find the option to make it secured
Click Here for step by step instructions
Jul 20, 2010 | NetGear MR814 Wireless Router
Using Windows XP. can't remember NETGEAR DG632
Is there any computer online using the router.
check the IP address on that computer.
If yes then you can open the router set up page on
that computer.
router set up page is the page where you can check
all the router settings.
Click Here for more information about the routers
and network
Feb 13, 2010 | NetGear MR814 Wireless Router
How to setup a password for a vify of netgear
Jan 26, 2010 | NetGear MR814 Wireless Router
My wired connection to the router works fine but the wireless connection is not working
What have you tried?
Is this a new router? (Some Netgear have wifi turned off by default)
do you see the SSID name on your computer?
Has it ever worked?
It does happen that the output transistors fry so it works wired but not wireless
JOAT
Oct 10, 2009 | NetGear MR814 Wireless Router
I have a netgear MR814 and i am wondering if you can tell me how to connect it with my home system and my Mac OSX laptop?
For you to be able to connect to your router wirelessly, the first thing that you should know is the wireless settings on your router. You should know the ssid and if wireless security is enabled. To access the router setup wizard go to http://routerlogin.com admin is the username and password is the password. Click the wireless settings tab and there you will see the wireless settings. Once you know those settings you can check the available network that your laptop is seeing and then connect to your network.
Jun 28, 2009 | NetGear MR814 Wireless Router
Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Mar 31, 2009 | NetGear MR814 Wireless Router
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Can't set it up
first time you have to connect the modem into the router and the router into the computer. run the setup and then remove the cable between the router and computer.
Aug 31, 2008 | NetGear MR814 Wireless Router
NetGear MR814 Wireless Router Logo
65 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
