Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint wd62 Hi I have a problem with the above, it will do any wash cycle however it does not drain at the end, if you put it on a spin cycle it will drain and spin an ideas? Nigel
The most likely culprit here is a the pump, which may either be blocked, or broken.
You should be able to get access to the inside of the pump through a small hatch on the front panel of the machine at floor level. Beware - as you open this, really quite a lot of water is going to come out, so you'll need tomething to catch it, and you may need to shut the cover a few times if your container fills up before the machine is empty.
Once you've got into this space, remove all the loose coins which have accumulated there. If you think you found enough to block the pump and stop it working, put things back together and see if the machine is fixed.
If not, turn off the cold water supply, and run the machine in tumble-dry mode for a few seconds at a time while watching the pump impeller (looks like little fan) in the back of this cavity.
If it doesn't start whizzing round of it's own accord every time, then you need a new pump motor. These are cheap, readily available on the net, and straightforward to fit.
If the pump appears to start and run OK, then check for kinks and blockages in the hose that goes from the drum down to the pump, and in the drain hose that goes from the pump out the back of the machine. Finally, make sure that where the drain hose plugs into the standpipe (of whatever fitting is used in your part of the world to connect to the domestic drains), air can get in freely.
Posted on Jul 21, 2008
Machine will not completely drain. Always leaves about 2" of water.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
Sep 02, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Will not go onto final spin on its own
check drain hose lid switch ....plugged pump or drain hose last timer
Aug 14, 2009 | Hotpoint WMA48 Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
hi, this model is notorious for programme faults and i would suggest you change the controller, hope this helps
Feb 09, 2009 | Hotpoint WD62 Front Load Washer / Dryer
Noisy spin on hotpoint wd62
comon fault on hotpoints is drum bearings put ya hand in the drum and give it a quick flick if it soundslike it rumbles buy a new washer.since merloni bought hotpoint you prob have to buy a whole drum not just bearings
Oct 03, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 leaks heavily during spin cycle
hiya m8 check the door seal first you'll need to pull the seal slightly out to see under the flappy part they usually go there this will be the most likest leak u don't have to undue anything to do any of this and when u find the hole it will only be around £15 to get a new door seal u might have to run your fingers around under the flap to find it aswell m8 let me know if it is and ill tell u how to replace it m8
May 25, 2008 | Hotpoint WD62 Front Load Washer / Dryer
My Hotpoint Aqaurius WD62 is filling but wont drain or spin
try replacing the interlock first then check the the continuity in the interlock lead
Mar 06, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WD62 Front Load Washer / Dryer Logo
78 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
