Question about Zenith B36A24Z 36" TV
Is this model DTV compatible?
I am having a hard time determining if any of my 3 TV's are DTV compatible. Does anyone know if this zenith model is B36A24Z?
Thanks.
  • Zenith Master
  • 8,457 Answers
It easy to determins just plug in the rabitears or outside door antena u get a signal then u can.If u can't just statics.U find out right away.
If u have cable or satalite or ect.. u don't care if it is or not.
Posted on Aug 17, 2009
  • 4,234 Answers
This set does NOT have the over-air digital tuner. If you use an external antenna or "rabbit ears", the set will require a converter box.
Dan
Posted on Oct 08, 2008
  • 69 Answers
I believe it is.
Posted on Oct 07, 2008
Samsung AK59-00123A remote to a M261VP vizio tv
Hello
[1] Switch your television on
[2] Point the remote control towards the
television
[3] Press and hold the TV POWER button, and
then enter the two-figure code in the table
to the right that corresponds to the brand of
your television by pressing the appropriate
number buttons.
If your television is compatible with the remote
control, it will switch off.
The remote is now programmed to operate
the TV.
The code for Zenith TV is [TV POWER + 63]
Sep 20, 2011 | Zenith ZEN700 Remote Control
I need the 3 digit device code for Zenith TV Model Z19A11S, to program universal remote.
Hi mwhaken,
You didn't mentioned the brand and model of your remote control, anyway you may try the code below.
ZENITH Codes: 000/ 001/ 004/ 023/ 038/ 058/ 059/ 064/ 121/ 135/ 136/ 153
Let me know the brand and model of the remote if the codes above does not compatible with the unit.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 09, 2011 | Zenith Z19A11S TV
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Is my Zenith TV HD compatable?
i dont think so your model number say thats not an hd tv the maximum resolution is the same as a normal tv so mean 4:3 format.....
if you got a warped picture thats mean you youu have an sync problem or so that is difficult to
say from here..
have a nice day,hoping that will hell you
Mar 29, 2010 | Zenith B50M88W 50" Rear Projection...
Need remote code for Zenith tv model no tvbr1942z
I got code 21479 to control power and channel up/down but it won't manage volume. That code also pulls up the menu for the TV too. Could not determine VCR compatibility since the VCR died ages ago.
Sep 22, 2009 | Zenith TVBR1924 19 in. Combo
Analog Pass-Through DTV Converter Box with Remote Control (3 digit code for the Remote Control
i can not get my tv to pick up a signal.I know my antena works i have tried it on other tvs.Has anyone else had this problem or know how to fix it?
Aug 04, 2008 | Philips Magnavox 20MT133S 20" TV
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Zenith B36A24Z 36" TV Logo
65 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
