Question about JVC GR D370US camcorder Mini DV
RECORD VOULUME HOW DO I SET THE RECORD VOULUME. WHEN I RECORD THE VOLUME IS SET SO LOUD WHEN I GO TO MAKE A MOVIE THERE IS A LOT OF HISSING BECAUSE THE VOLUME IS SO HIGH IN ORDER TO HEAR THE FOREGROUND NOISE. EXAMPLE I WAS RECORDING MY SON PLAYING THE PIANO AT A CONCERT. I HEAR THE PIANO JUST FINE BUT THERE IS A LOT OF AMBIENT HISS.
    Problem Solver:
  • 5 Answers
Put the camera into manual mode from there get into the menu options and adjust the recording volume level.
Posted on Nov 15, 2008
The sound on all the movies on our tv is soft voice and loud music. How can I set the volume to be the same for both?
Some TV's have sound settings to empathies voice. If the TV has a centre speaker you can increase the sound output on that. That will make voices louder.
However many people do complain about loud music drowning out voices on TV. The problem is that movies were meant to be seen in cinemas and TV sound systems don't match up to that. If you can't find a solution consider a surround sound system as this will correct the sound problems on movies.
Nov 21, 2017 | The Audio Players & Recorders
Audio works, but lots of noise (hiss) in the audio
Some lifecams need additional software or specific browsers according to your OS
Visit the microsoft website - enter the details of your cam and check out the 'readme' link also 'breaking and known issues link'
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
It may even be feedback from the incoming voice being picked up on your mic - headphones would prove that.
Finally you may have a laptop with a built in mic - check this
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make the test call
Click 'Save'
Jan 14, 2010 | Microsoft LifeCam VX-3000 Web Camera
I am getting a lot of hiss when I record low
it is not a problem there are many problem
Aug 23, 2009 | PreSonus Computers & Internet
The volume is not loud enough on my i-pod classic
There is a volume limiter under "settings", check to be sure its turned all the way up (you actually have to click the center button to save). Also you will find "Sound Check" being turned on greatly reduces volume.
Dec 31, 2008 | Apple iPod classic MP3 Player
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
How do you set sound and volume on movie mode on model sp-560uz
Page 33 of your user manual explains how to turn on the microphone to make sure that sound is recorded when taking movie clips. You cannot adjust the recording volume. Page 35 discusses how to adjust the volume during movie playback only.
Nov 07, 2008 | Olympus Cameras
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
DISTORTION
1) if you are using the PC sound card to record this is where your hiss is coming from. you need to get a recording card that has low noise or some other recording USB input device to get CD quality recordings
OR
2) if you have to use your PC sound card check your PC volume level for line in, don't let it get high or it will distort. you will have to experiment with the MD4 levels and PC sound card level to find a good middle ground with low hiss and no distortion
and a singer that sings away from the mic to reduce distortion.
hope this helps
thanks for your rating
Jan 09, 2008 | Shure SM87 Professional Microphone
Video Cameras Logo
131 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
