Question about Denon Audio Players & Recorders
Denon dra 1025ra seems to be stuck in standby mode. How do I release standby to power up
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
Posted on Jul 09, 2008
I have a Denon DRA 397 receiver and when I power it up the standby light goes on but nothing else powers up?
If you are not pressing the power button on the remote that may be the problem
Apr 11, 2012 | Denon DRA-397
I need a 2621217005 for a Denon DRA-1025RA receiver.
http://www.vancebaldwin.com/products/?DEN2621217005
Jun 24, 2008 | Denon Audio Players & Recorders
My denon DRA-295 does not remember stations I set to memory when completely turned off. If on standby all goes well. A month after the problem mentioned above the tuner started to modulate reception and...
My better guess is a CMOS chip is either bad or there is a cold solder connection in the vicinity. If the power supply is bad, the receiver would not power up.
Nov 23, 2010 | Denon DRA-295 2 Channels Receiver
The scren says panel lock on. how do i get out of this mode
Denon panel lock was not supposed to be supported on this model, somehow yours is. We need to reset the microprossessor.
as denon manual states:
switch off the unit by pressing power.
keep both speaker a and b pressed and turn on the unit by pressing power.
check that the entire display is flashin at 1 sec intervals and release buttons.
the mircoprossor has been reset.
if step 3 does not work start over again.
the receiver will go back to factory defaults.
let us know if further troubleshooting is needed.
Cheers!
Feb 15, 2010 | Denon DRA-397
Denon DRA-37 Receiver-Remote lock on. Need to unlock.
Refer to the "Initialization of the Microprocessor" section of the manual (page 16 of the PDF version of the manual).
1) Turn the unit OFF using the On/Off switch (not the standby switch).
2) Depress both the Speaker A and B switches, and turn the Power ON.
3) The entire display should flash at 1-second intervals. The microprocessor should be reset, and the remote should be unlocked.
Jan 23, 2010 | Denon DRA-37
I have a Denon DRA-397 Receiver. It was stuck with the "Panel Lock" but I followed the instructions here to hold the "B" and "Mode" buttons while powering on. It unlocked the panel. Now the Reciever is...
Check for a reset of the receiver. If no mention in manual you might want to check with the manufacturer for a code . If nada then the electronics are fubar and you are SOL.
Aug 31, 2017 | Denon DRA-397
Standby light stays red and will not turn unit on.
Try to reset the macroprocessor. Unplug the unit from AC, hold both buttons SPEAKER A and SPEAKER B and plug the cord in outlet. After display flashes several times release the buttons. No result? - repair shop.
Apr 05, 2009 | Denon AVR-1906 Receiver
That's fine DonMoody, it can be a little confusing at times. The options are very clearly stated as to what they really mean. Rejecting a solution means, the solution does not help you, or you tried and it did not work, something like that.
I am kinda new here to, about a week. Be very careful who you listen to here, some "guru"'s are not what they seem. But I am sure you can tell by some answers you get.
Is that unit an older stereo reciever? I recognize the "DRA" but not the 1025RA part.
What is tis part you need, sometimes a generic part will do the trick. Depends on just what the generic number is. That should be the number that is printed right on the part if it is an IC
I will see what I can come up with when I get to work in about 6 hours. I go to the doctors in a few minutes and then I go to work.
let's see if we can't solve this for you. If I go thru my sources and can not get the part, it is just not available. sometimes that happens, even with newer equipment.
Jun 25, 2008 | Audio Players & Recorders
Stereo receiver is in a Panel Lock On mode and will not stay on
Hi, Press the B and the Mode buttons and then hit the power button.  This should unlock the panel....it worked for me.
Apr 12, 2008 | Denon DRA-397
Panel lock on dra 397
Speaker B and Mode buttons held down simultaneously while engaging master power, unlocked my DRA-397. Thanks!!!!
Dec 02, 2007 | Denon DRA-397
422 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
