The CD-ROM setup disc for my new PIXMA MP210 is not functioning. My computer is HP Pavilion 7310 Slimline. My Windows is 2000. How should I proceed?
  • hotmama_644 May 06, 2009
    I need a cd for my all in one printer-scanner-copier 1410v
  • 300 Answers
Download the software from www.canon.com
Posted on May 18, 2008
Replaced motherboard &hard drive in hp pavilion, now it will not recognize reovery cd
Replacing major hardware in a computer makes it a whole new computer. The motherboard is the operative part here that is causing your problem. When you replace a motherboard it becomes a new machine entirely. It won't recognize the recovery CD because it doesn't recognize your computer as the same machine it was loaded on. You will have to buy a new copy of windows to put on your computer.
Feb 13, 2013 | HP Pavilion Slimline S3020N PC Desktop
I NEVER HAD A CD ROM FOR MY PRINTER PIXMA MP 210 How do I install it on to my Laptop windows 7
You can download the Canon printer drivers from their supportWEB site. Please click on this link and select your model printer to download :-http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Feb 25, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Replace the disc drive on hp pavilion notebook
1. First of all, you need to shut off your computer . To do this press the power button on the front of the computer after you have shut it down from Start> Shutdown on your start menu.
2. Unplug the power cord from your computer. This is the big black/white/grey plug that plugs into the power supply on the back of your PC.
3. Unplug the rest of the wires from the back of the computer.
4. Find a sturdy flat surface on which to work on.
5. Unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
6. Open your computer up by taking the side panel off, or sliding the cover off. It might be difficult but it will come off if you have taken all the screws out.
5. Now before touching anything inside, it is a good idea to hook up to an anti-static wrist strap. If you dont have an anti-static wrist strap, just touch the side of the computer where it is metal to deshock yourself. Then when you touch the inner components you wont risk damaging any of them.
7. Find the CD-Rom drive, it should be about 1.5 inch thick 5 inches wide, and 6 inches long. Unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
8. Once you find the CD-Rom drive, find the screws holding it onto the chassis. unscrew those screws on both sides of the Cd-rom drive. Be careful not to unscrew any screws holding the cd-rom drive together.
9. Now, you just have to remove the cd-rom drive, carefully by sliding it either forward or backward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
10. Now that you've removed the cd-rom drive the next step is to install your new CD-rom drive. To do this, simply slide the cd-rom drive in from the front of the computer, controls facing forward. Plug all the plugs back into the cd-rom and screw everything back into place.
Jan 17, 2010 | HP Pavilion TX2000Z Notebook
My HP s123w Slimline Pavilion will not start up. Every time I turn it on, it goes to a black screen stating "DISC BOOT FAILURE, INSERT SYSTEM DISC AND PRESS ENTER" and I do not have the system disc. Any...
Take the floppy disk out of the drive... this sounds like the classic error when the boot order includes the floppy disk first, and a blank or data (not bootable) floppy diskette gets left in the drive.
There could be another type of drive set as bootable. CD's and DVD's don't normally do this - they usually cause a prompt "press any key to boot from CD..." or similar.
You could go in the computer setup and set the hard disc drive to be the 1st in the boot order and also solve this problem.
Otherwise could be your C: drive got damaged somehow. Virus or otherwise.
Jul 07, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
I need to reset the ram on a hp pavillion slimline but the cd tra
Just unscrew, remove the entire CD ROM, fix the RAM properly and while connecting the CD ROM ensure that all connections are snug tight...sodeep
Mar 19, 2009 | HP Pavilion Slimline S3123W Desktop PC -...
Software
Drivers and other files available for download here.
Apr 20, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
New printer not installing
The iP1800 is not compatible with any Windows OS older than Windows XP/2000. See here.
Apr 15, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Hp computer
You can repair that by booting your system using the CD ROM and the select to repair windows.
If ever this will not solve then;
You should backup your files and reinstall the windows operating system.
In installing operating system you need the following:
1 windows bootable disc/ Operating System REcovery Disc
2.Cd /DVD rom
Boot your system any of this CD/DVD disc and then follow the on screen instruction.
After installation, don,t forget to install the drivers of your system that was enlosed in your system.
If ever there problem arising this solution please notify me for further support.
Jan 22, 2008 | HP Pavilion Media Center a1330n - AMD...
296 people viewed this question
jasbo
jasbo
