Question about Dell Dimension 4600 PC Desktop
Slow computer I have a Dell Dimension 4600i and it runs VERY slowly even with cable internet. It has a total physical memory 256mb; avail. physical memory 42.27mb; total virtual memory 2 gb; avail. virtual memory 1.96 gb; page file space 750.20 mb. What can I do to speed it up? Kent
    Problem Solver:
  • 15 Answers
Id do the same thing as wayne said.
Posted on Aug 04, 2008
  • 300 Answers
Add more memory and run an anti virus and anti spyware scan
Posted on May 18, 2008
Dell Precision 530 with dual Xeon CPUs. Uses Rambus memory. (4) 256mb ECC modules are installed. It should be a total of 1 gb. However, BIOS only shows 256mb total even though it shows all 4 rambus...
It sounds like like you have multiple issues. When all memory slots are filled with 256 sticks the computer boots but only sees 256 MB instead of 1 gig.
When you install the Crimms it won't boot at all.
You may have an open circuit on one of the Crimms.
As for the computer seeing only 256 MB you may have a bad memory slot on the motherboard.
Here's a link regarding Direct Rambus DRAM or DRDRAM (sometimes just called Rambus DRAM or RDRAM: http://en.wikipedia.org/wiki/RDRAM
May 15, 2011 | Dell Precision 530 PC Desktop
Changed some things on BIOS to remove McAfee virus protection program because the computer was running slow. Now even my internet program (Mozilla Firefox) will not even download updates. I am not sure...
A slow running computer can be fixed by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Anyway, what are those things you have changed w.r.t BIOS? Make sure that you have removed McAfee completely through control panel.
Oct 16, 2010 | Dell DIMENSION 3000 CELERON 2.4GHZ...
My laptop is running slow? when im in the internet my computer runs slow
Available RAM is very important for speeding up your laptop while surfing. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Jul 14, 2010 | Toshiba Satellite A135-S2276 Notebook
My system says, (RAM) radon access memory low cpu intel (r) pentium 4 cpu, version 2.80 ghz. RAM 256 mb. What can I do to resolve this problem. Dell 4700 dimension
Windows XP requires a "bare-minimum" of 128MB of RAM, works "OK" with your 256MB of RAM, if you don't open too many programs at the same time, and if you close/re-open Internet Explorer about once an hour of usage.
But, Windows XP would be _much_ "happier" if you added 256MB or 512MB of RAM, because it is telling you ("available random access memory is low") that it is using all the RAM.
Add more RAM -- your computer will run much better.
Jun 15, 2010 | Dell Dimension 4700 PC Desktop
Very slow also to increas memory
You need more memory. If you have windows xp you need at least 512 memory.
Jul 03, 2009 | Dell Dimension 2400 PC Desktop
Slow System
Upgrade your system RAM.It will improve your system performance.
Apr 03, 2009 | Dell OptiPlex GX110 PC Desktop
Total newbie here - how do I add more memory to my DELL Dimension 2300? I have my cpu open and i am replacing my fan also.
Well your Dell 2300 has a total max. memory of 1 GB from both slot.
If you already have (2) 512MB RAM in the slot then thats the max it can handle.
Dell 2300 only has 2 memory slots. Memory comes in 1- 128MB, 256MB and 512MB PC-133 DIMM modules. So if you want to max it out get (2) 512 MB PC-133 DIMM.
Note:
You must wear a static strap or ground yourself first on the computer chassis before you touch any thing inside your computer
to discharge any static electricity
For further instruction check this out:
http://support.dell.com/support/edocs/systems/dim2300/replace.htm#1101964
Jan 11, 2009 | Dell Dimension 2350 PC Desktop
COMPUTER DOESN'T RECOGNIZE ADDED MEMORY
Are the memory cards the same? Try swapping the memory cards inside the computer. It is also important to go into the Setup (F2) once the new memory has been added. The setup keeps track of the hardware changes to your computer, and the additional memory needs to be saved in the Setup configuration. Please let me know what happens and thank you. Binary Bob
Dec 27, 2008 | Dell Dimension 1100 PC Desktop
CHILL WILL'S (motherboard E210882) WOES!!!
It seems like you have done everything right but im not 100% sure that your memory is correct. read through the description here carefully and you will see that this memory comes in two different packages. One of them is the 400 (the ones you bought) and another in the 333 flavor. I am hoping they did not make a mistake and gave you the wrong ones. Look directly at the memory and make sure. I am also including the system manual for your computer. Hope this helps.
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm
Kingston's ValueRAM KVR400/1GR is a 128M x 64-bit (1GB) DDR400 CL3 SDRAM (Synchronous DRAM) memory module. The components on the module include sixteen 64M x 8-bit (16M x 8-bit x 4 Bank) DDR333 SDRAM in TSOP packages. This 184-pin DIMM uses gold contact fingers and requires +2.6V. The product is shipped in retail packaging and includes installation instructions.
Apr 27, 2008 | Dell (E210882) Motherboard
Dell Dimension 4600 PC Desktop Logo
141 people viewed this question
Alun Cox
