Question about ViewSonic VX900 19" LCD Monitor
VX900, Backlight Works, But no picture.
I got it basically for $5 because it doesn't work, so I figured it was worth it if it can't be fixed.
• The unit powers on fine, power led stays green.
• Without a cable plugged in, it says no signal then goes blank and power led turns amber.
• When I plug in a VGA cable (have not tried DVI-D as they are $35 around Toledo) the power led turns green, the screen lights up, but it is a black picture.
•I have taken it apart and visually inspected all the boards, and everything looks fine.(such as the caps, resistors, fuses "Look" okay, coils, wires, everything)
I don't have a multi-meter, so I can't check things as well as I could.
If anyone has any ideas, please let me know and thank you in advance.
Simon.
  • Bruce Smith
    Bruce Smith Feb 15, 2009
    When I turn the monitor on, the screen comes up all white and displays "BURN IN ON" for about fifteen seconds, then goes away leaving the screen still all white. No buttons do anything except the on/off switch. The power supply measures 12.03 volts. Sorry, I haven't opened it up yet. I fix medical equipment for a living, not monitors, but am willing to give it a shot. Have scope, DVM and plenty-o-tools.
    Any ideas/suggestions?
    Genius:
  • ViewSonic Master
  • 1,689 Answers
It is impossible to see defective components visualy, unless there was a serious burn-up or something like that.
Without at least a DVM you cannot even verify if the power supply is functioning properly!!!
There is no support at the component level service for these monitors. The service tech will change the main input board to solve the fault that you have. If the back plane lamps are failed, he will change the power supply for the back plane lamps. In some of these models, the back plane lamps are not replaceable. This means that the screen would have to be replaced.
If you want to service the monitor the non supported way, call Viewsonic and see if they will sell you a copy of the detailed schematics, and engineering data for the boards. Most monitor companies will not sell any schematics or service information to no authorized contractors for their service.
If you can have the details, get a digital scope, a DVM, a logic analyser, and start troubleshooting according to the service manual. This can involve hours of work to figure out the fault. Then you will have the task of seeing if Viewsonic will sell any of their proprietory EPROM's or processor type parts.
This is why when the warranty is finished on these monitors, they are not worth to send back for service. The shipping cost, plus the parts and labour can come out to more than the monitor is worth!
Jerry G.
Posted on May 19, 2008
No picture on lcd tv.. What parts do I need to replace to fix the picture?
Hi John,
From what you have described, it seems that the tv is going in protection after 5 secs.
Though the backlight is there, but are you sure that all the cfls are glowing.
If one of the cfls is not working, the set will go off in the same manner.
If this is the case, disconnect the defective cfl and solder a 4700mf/2000v capacitor in its place. If this works, you either keep the set running like this or replace the defective cfl.
Otherwise, If all the cfls are ok and working, your inverter card if suspected to be defective.
Good luck
Feb 06, 2015 | Vizio Televison & Video
Lost remote for ViewSonic 19" VX900 Monitor.
Please verify the model number since VX900 is just a monitor, it does not have any remote function, http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VX900/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Apr 13, 2011 | ViewSonic VX900 19" LCD Monitor
VX900 19 in. Flat Panel LCD Monitor: when i turn it on the screen is black....
You may have backlight inverter failure, check the fuse as shown in my pictures, you can also have bad backlight assemblies also, but check the fuse on the inverter bd first, verify that you do have 12v at the fuse.
May 16, 2010 | ViewSonic VX900 19" Flat Panel LCD Monitor
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Lcd monitor goes black
Try a different monitor (a friend's) on your computer, if it works OK the problem may be with your monitor. If it does the same as on your monitor, the computer video card may be defective.
Try your monitor on a different computer (a friend's) etc. You will figure if anything or what is defective. Then you can decide to repair or replace.
May 31, 2009 | Apple Multiple Scan 1705 Monitor
Viewsonic VX900 LCD Monitor No Display.Bcklt and Screen Menu Work
It looks like you have to replace mainboard (it doesn't take input signals)
Mar 26, 2017 | ViewSonic VX910 19" LCD Monitor
I noticed a post you made about the Viesonic VX900 and fuses
I think you have bad CCFLs, (Cold cathode fluorescent lamps) they look like small flourescent lights and are used to light the screen. On smaller than 17" screens there are two, one on top and one on the bottom. 17" and larger monitors have 4 with real big ones having 6. If you attempt to change them be very careful not to crack the screen and remember the order of all the layers of the screen. The cost of the CCFLs along with the difficulty in doing this repair makes it not worth most peoples trouble....good luck
Aug 10, 2008 | ViewSonic VX900 19" LCD Monitor
Viewsonic VX900 blank screen
Here is a pic of the fuses on the inverter board for a Viewsonic vx900, you can visually inspect them as well if you do not have a volt meter. While visual inspection is not 100% reliable, usually when these are popped you will see the red line across them is black or broken.
Dec 06, 2007 | ViewSonic VX900 19" LCD Monitor
ViewSonic VX900 19" LCD Monitor Logo
289 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
