Question about HP OfficeJet 7310 All-In-One InkJet Printer
HP 7310xi: "Remove and Check Printer Cartridge on the right"
I bought a new black ink cartridge twice to no avail. I still get the same error message. What can I do to get the error message to stop. I even tried the alcohol and cotton swap suggestion. Please help..Up to now this has been a great machine.
  • 5 more comments
  • ltl220 May 23, 2008
  • Anonymous May 26, 2008
    I have a HP 7310 Officejet All in One Printer. I having the same problem as Ralph. After replacing an empty black cartridge, the one on the right side, I get an error message that says " remove and check the right cartridge". I did that, inspected the cart. and found no problems. Thinking that the cart. is faulty I exchanged it for a new one and got the same error msg. Then I went to HPs on trouble shooting page and did everything suggested to no avail. I then went online and chatted with a HP tech for an hour and a half going through different trouble shooting procedures. At the end of that I still have the same problem. I do not see any damage to the carriage contacts and the bias wire is in its proper place. Can you assist with this problem.
  • thoolman Aug 10, 2008
    I could tell that the ink was gettig low in my cartridges. I replaced the color cartridge with no problem. The black cartridge always has an error with it that says to remove the cartridge and check it.
  • chicagocemo Nov 11, 2008
    I just replaced color cartridge and got the error. I do see the small wire off to the right but it also is in the black cartridge side so it doesn't appear to be broken. Anyone have a picture of what it is supposed to look like
  • ltyndall286 Feb 02, 2009
    I found the same problem with the wire punching a hole in the cable.
  • Anonymous Feb 05, 2009
    can not remove ink cardrage
  • Anonymous Feb 10, 2009
    hp 7310xi remove & check black cartrige
  • 87 Answers
Sounds like the carriage is broken on the black side. Pull the cartridge out and take a look at the silver metal piece. Is it loose from the side and if so did it punch a hole in the circuitry that cartridge comes in contact with. If I were a betting man this is probably your problem. You have to replace the whole carriage. This is a pretty common problem with the carriages that use the #96 and #97 cartridges.
Posted on May 21, 2008
I conduct RESET for the Army and have had the same thing many times on the HP7310. There is a small plastic tab that holds the tensioner wire on the side of the ink tank carriage. That breaks off and when you insert the ink tank the tank pushes the wire into the circuit board/ribbon cable and makes a hole breaking contact. I have had good results with removing the circuit and with a fine soldering gun repairing the broken trace. Once done, I use a small plastic wire tie to hold the tensioner in place. Hopefully the solder job is a good one and you do not have to replace the entire carraige assembly. NOTE: Be very careful when removing the back ribbon cable. It is connected by a very thin slice of ribbon to the "reader" on the carriage. Move slowly and keep track of what screws go where. You will need a #6 and #9 Torx to remove the holding screws.
Posted on Feb 09, 2010
This is the exact same issue that I have. After looking at the carriage with a flashlight I determined the wire on the right side of the carriage has come loose and small pieces of plastic that holds it in place has broken off. When that happened the end of the wire pearced the ribbon behind it.
The carriage and ribbon have to be replaced.
Posted on Oct 02, 2008
  • 4 Answers
This is something simple to try...
Try removing both cartridges. When reinserting, install the black cartridge first and then the color. Have had customers with similar issues and this does seem to work 85% or so of the time. If it doesn't, then you have a lot bigger issue. Could be the whole carriage.
Posted on Oct 01, 2008
    New Friend:
No solution, but same problem, but my symptoms were different. I replaced the color cartridge and aligned it successfully. I printed one page and it printed REALLY slow, like 30 minutes. I had not power cycled the printer and then got the error with the Black cartridge (cartridge on the right). Replacing the black cartridge resolved the problem, however the black cartridge was no more than 5-10% used. I almost wonder if this isn't some sort of cartridge compatibility ploy. I've only bought new genuine HP cartidges, so something is surely off!
Posted on Dec 24, 2013
Error message says "Remove and check cartridge on right" Its a new cartridge I've been using for a few weeks and it has been working fine. I have removed cartridge several times and even cleaned contacts....
The electronics on the cartridge have gone bad. Sometimes cartridges short. Take the cartridge back to where you bought it (they should give you credit for any remaining ink) and buy a new cartridge.
Aug 10, 2010 | HP Photosmart C4180 All-In-One InkJet...
Printer does not recognize ink cartridge.
Remove the black cartridge and gently wipe the contacts on it with a dry cloth. Put the cartridge back in. If the error message is still there, I think you should buy a new black cartridge.
Apr 01, 2010 | HP Officejet 5610 All-In-One InkJet...
4110 officejet series all-in-one error message saying i installed incorrect ink cartridge? what do i do? it is the correct one
Supported HP Inkjet cartridge part numbers The HP Officejet 4100 all-in-one series products use the ink cartridges listed in the table below. HP Inkjet cartridges HP 56 black cartridge (19 ml) HP 57 tri-color cartridge (17 ml) HP 28 tri-color cartridge (8 ml) Replacing the ink cartridgesThe power must be turned ON to the all-in-one or the print carriage will not move to the right.
  1. Locate and open the print cartridge access door on the right side of the all-in-one. The print cartridge carriage will move to the right for access. Figure 1: Opening the HP Officejet 4100 seriesc00121089.jpg
  2. Press down gently on the top of the old ink cartridge to release it from the print carriage. Figure 2: Removing an ink cartridgec00121090.jpg
  3. Remove the new print cartridge from its packaging and remove the protective tape from the cartridge as shown in Figure 3. Do not touch the gold-colored contacts. Figure 3: Removing the cartridge tapec00121091.jpg
  4. Holding the ink cartridge with the printed label up, slide the cartridges one at a time into the print carriage and press them into position as shown in Figure 4. If the cartridge does not snap easily into position, it is not aligned correctly. Remove the cartridge and reposition it. Do not try to force the cartridge into position. The black ink cartridge (HP #56) goes on the right side and the color cartridge (HP #57 or HP #28) goes on the left side. Close the ink cartridge access door when the ink cartridge has been installed. Figure 4: Installing the ink cartridgesc00121092.jpg
  5. A message will appear on the front panel requesting that the ink cartridges be aligned. Follow the steps below to align the ink cartridges:
    1. Press Enter on the all-in-one front panel to start the ink cartridge alignment process.
    2. After the Alignment page prints, place the page into the ADF upside down and with the printed side down as is shown in Figure 5.
    3. Press Enter. The all-in-one will scan the alignment page and finish aligning the cartridges.
    Figure 5: Aligning the ink cartridgesc00121093.jpg
Correcting error messages that appear after changing a cartridgeAfter inserting the cartridge, the Check Print Cartridge light flashes or one of the following messages appears on the computer monitor:
  • Check the black (or color) cartridge
  • Replace the black (or color) cartridge
  • The wrong black (or color) cartridge is installed
These messages indicate that the ink cartridge is not making good electrical contact, is bad, or is the wrong cartridge. Complete the following steps to diagnose and correct the condition:
  1. Open the front of the unit to access the print cartridges (as shown in Figure 1).
  2. Remove the ink cartridge and inspect it.
  3. Verify that it is the correct part number and if it is, reinsert it.
  4. Close the lid to see if the problem is corrected.
  5. If the message is still displayed after a few seconds, remove the ink cartridge again.
  6. Unplug the power cord from the back of the unit.
  7. Clean the electrical contacts on the ink cartridge with a soft clean cloth slightly dampened (not wet) with clean water. (See Figure 6) Each contact is very small and shaped like a rounded square. Figure 6: Cleaning the cartridge contactsc00121094.jpg
  8. Allow the ink cartridge to dry for a few minutes before reinserting the cartridge(s) and turning on the printer.
  9. If the problem remains, replace the ink cartridge.
  10. If the problem still exists after trying all of the steps above, the unit may need to be serviced. Contact HP for further troubleshooting or to arrange to have the unit serviced.
Make sure what ur using isn't a refilled cartridge and if it is check the expiration date, if nothing is wrong then you need to get urself a new printer or an upgrade so call up hp at 1800-474-6836 and get help of them,they'll guide you to a new /upgrade printer.
it's not a nice way of saying it but someone has to give you the bad news
Feb 01, 2010 | HP Office Equipment & Supplies
Hp j6450 all lights flashing will not reset! attempted to reset the machine. it is only used on a fax/copier
how do I reset the error message reading remove cartridge on the right , On the HP o FFICEJET 7310XI All- in - one ????
Jan 29, 2010 | HP OfficeJet 7310 All-In-One InkJet...
I keep getting the message "remove and check cartridge on right. I do this, but it doesn't solve the problem. The printer worked fine until I installed a new black ink cartridge. After so many times of...
The cartridge on the right is the black ink cartridge. The one on the left is the color.
Make sure you have pushed the cartridge in all of the way and that you have removed the tape cover from the cartridge before you insert it.
If you bought aftermarker or third party cartridges, you have a cartridge that is not filled properly. If you purchased it from a local retailer, return it and try another cartridge.
The Hp reads the levels from the gold connectors on the cartridge. If they are blocked, or damaged or the cartridge is not full, you will get this message.
Jan 14, 2010 | HP Photosmart 4180 All-in-One Printer
Ink cart error
Is there a metal wire (clip) hooked on black plastic in the ink carriage? If not, these are notorious for breaking the small plastic hook....when broken, the cartridge is not held in proper postion so printer won't recognize that the ink cartridge is replacement parts are available for this series of printers.
Jun 03, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Problem of incompatible cartridge occure in my new J 4580
i had the same problem with the hp 4580. i needed to replace the black ink which i did. then the error message appeared "incompatible print cartridge tri color"...chatted with hp customer support, wasted a hour. claimed its a hardware problem need to have it fixed. i asked would i be charge he said yes but the printer was under warranty. he asked other questions...bottom line i left the chat box....bought another hp 4580, used same cartridges, same message...THEN finally i replaced the color cartridge...and BAM! it worked on both printers. solution...replace the color cartridge...cons..if this happens again its a waste of money to keep buying the colored ink...
Feb 03, 2009 | HP J4680 Office Jet All-In-One Printer
Dell printer model# A940 50c error
Test your cartridges.
Remove the color ink cartridge then lower the cover of your printer. If the error message displays again, replace the black cartridge with a new one (or return the new one). Reinstall the color cartridge and remove the black ink cartridge then lower the cover. If the error message displays again, replace the color cartridge with a new color cartridge.
Note: My manual indicated that the printer might have detected a short circuit in a cartridge. I returned a month old black cartridge got a new one and my printer is working fine now. Good luck.
Nov 10, 2008 | Dell A940 All-In-One InkJet Printer
Hp psc2410xi
The following error message appears on the color graphics display after you insert a cartridge: Remove and Check Print Cartridges . The printer will not print. The message does not specify which cartridge has caused the error. Solution This error message indicates that the printer cannot determine which cartridge is causing the error. Follow the steps below to solve the problem.
  1. Remove the color cartridge from the left stall (which has a blue latch) and refasten the latch. Leave the other cartridge in place.
  2. Close the printer, wait 10 to 15 seconds, then look at the LCD display.
    • If the LCD display reads Insert Color Cartridge in Left Stall , the color cartridge may be causing the problem. Follow the steps below:
      1. Clean the color cartridge contacts.
      2. Reinsert the color cartridge into the carriage and close the blue latch.
      3. Close the printer and wait 10 to 15 seconds.
      4. If the LCD display reads Remove and Check Print Cartridges , replace the color cartridge.
    • If the LCD display reads Remove and Check Print Cartridges , follow the steps below:
      1. Reinsert the color cartridge.
      2. Remove the black or photo cartridge, depending on which one is installed in the right stall. The right stall has the gray latch. Be sure to refasten the latch on the empty stall.
      3. Clean the black or photo cartridge contacts.
      4. Reinsert the black or photo cartridge.
      5. Close the printer and wait 10 to 15 seconds.
      6. If the LCD display reads Remove and Check Print Cartridges , replace the black or photo cartridge.
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts.
    1. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
    1. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty
    Aug 12, 2008 | HP LaserJet 5L Printer
    HP OfficeJet 7310 All-In-One InkJet Printer Logo
    1,527 people viewed this question
    Ben Johnson
