Question about Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum
Can't get the case off the beater bar assembly
I sucked up a shoelace which jammed the beater bar and broke the belt.
I can not seem to get the unit apart to fix it. No screws or anything and it seems like it will break if I force the edges out any further. How do you get these things apart?
My email is bob@rewindshow.com
Thank you
    President:
  • 1,673 Answers
Wish I had the complete model number, but you can go to sears.com and click on the parts link and enter your model number, a parts list and a picture diagram showing the breakdown will come up.
On some of the powerheads, you take out 2 screws, then there are tabs holding it together on the back and on each side, release them and the top comes off.
On some othere, the cover over the light comes off, depress te sides and back to release it, then there will be 2 screws to take out. Then using a flat blade, you will see slots from the bottom edge of the top cover, pry out from these slots and the top will come off.
Posted on May 20, 2008
I was told by a previous repair man that there is a fuse in the beater bar that needed to be replaced.
Up to my experience in my Panasonic vacuum cleaner, if the beater bar is not working this could be because the 'Carpet/Floor' selector switch is in the 'OFF' or 'FLOOR' position. In both of these positions the beater bar will not rotate. Move the selector switch to the 'CARPET' position. When in this position the beater bar will rotate once the foot pedal is pressed.
If the selector switch is in the 'CARPET' position and the beater bar is still not rotating it could be that there is something entangled in the beater bar, or the belt is worn or broken.
To check this first unplug the vacuum cleaner
Inspect the beater bar and belts to ensure that there is nothing entangled in the beater bar and that the belts are intact and are not excessively worn. If the belts are excessively worn they may slip resulting in the beater bar not rotating.
The vacuum cleaners often have an overload protection system inside the nozzle, which stops the nozzle motor when the beater bar jams to prevent belt breakage. After clearing any lint build up or jamming you may need to reset the overload protection, by pressing the reset button on the top of the floor nozzle.
May 04, 2015 | Vacuums
I have an Eureka Altima Model 2961AVZ vacuum that suddenly stopped picking up. I have taken it apart, checked the belt which was fine, replaced the hepa filter, and checked for clogs in all the hoses
Is the beater bar actually turning when the power is turned on? Sometimes the belt is fine, but something is jammed and keeping the beater bar from turning. What about the section behind the beater bar, but before the hose upright. I've found large pieces of paper jammed in here and then hair gets caught, ultimately blocking the whole system. Usually you have to turn it over, remove some screws and disconnect the belt and beater bar to get underneath. Just reassemble it in the reverse order to how you took it apart. Double check the hoses and run a "unwound" metal coat hanger through to unclog anything. Does the vacuum " suck" with the hose or tube up to it disconnected? If not you may have a motor that somehow got junk pulled into it. You can open this up as well and clean this out. Of course unplug it all before doing anything.
Nov 03, 2014 | Vacuums
Beater bar stopped after sucking up shoe lace
Hi choward40,
Yah, vacuums don't particularly care for shoelaces! :>)
Did you get the shoelace taken out of the beater brush?
Did the shoelace go all the way into the machine?
Please reply back. Thanks,
Handie Andie
Apr 16, 2011 | Dyson Vacuums
I am not sure of the part name but on the bottom there is a brush/sweeper that should turn and mine no longer turns.
The beater bar is either jammed with string or threads inbetween the housing or the belt inside of it is off or broke.Turn the beater bar upside down, remove the screws and seperate the housing.Please let me knowif this helps or if you need further assistance
Jan 19, 2011 | Kirby G6 Bagged Upright Vacuum
When using my hoover wind tunnel the last few times it has emitted a burnt rubber smell so my husband checked the belt and is wasn't broken or off but now when I use the vacuum the beater bar doesn't seem...
i take it the belt was put back on !! i would say hubbi forgot the tension arm a little black striker that can go in two ways but put in back wards it will not tension the arm
Jan 03, 2011 | Hoover Self-Propelled WindTunnel Bagless...
Smelled like it was burning and the bar stopped spinning
Bar/beater jammed up broke/ burned belt...Fix bar...Fit new belt
Apr 09, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I sucked up a piece of fabric and turned it off ASAP. Now the beater bar won't work, but the beater bar does turn. Help!
If the clothe is jammed in the power head you will need to clear it. Have the unit unplugged and manually rotate the beater bar to work the jammed material out. Sometimes a pair of pliers helps to grip the material while turning the beater bar. If there is no longer a jam then the drive belt may have been damaged and needs to be replaced. Usually when this happens the brush does not rotate. You can get a belt often at hardware stores such as ACE, or as a last resort, the dealer.
Nov 25, 2009 | Vacuums
Unit powers up but beater bar does not rotate
Have you checked the belt that drives the beater bar?
Oct 01, 2009 | Kenmore 22812 Bagged Canister Vacuum
DC 17 Beater Brush won't turn
You need to replace the belt. Here is the belt you need and a manual you can view which has instructions:
Dyson DC17 Belt and Manual
Jan 22, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Power brush SEB234/236
Hi Clyde,
Before you start, unplug the vacuum from the wall socket.
First remove all the shoe laces from the beater brush. Then make sure the belt in installed correctly. If this doesn't correct the problem, open the unit and find any fuses that it may have and replace any that are blown. That sould correct your problem. It sure seems that vacuums get hungry for more than dirt at times. lol Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vacuums
Kenmore 23612 Progressive PowerMate Bagged Canister Vacuum Logo
82 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
