Question about Microwave Ovens
Microwave LMV1976ST - broken clips to hold vent hood
Where can I purchase a new hood only?
  • Microwave Ovens Master
  • 8,865 Answers
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 05, 2008
Why is my brand new Kenmore microwave hood combination 790.8035 making a whirring sound in the vent area when the lower two speeds are activated.
Ok it's brand new, so check if you left any wrapping on it or there could be something inside the vent, loose screws, connection on your hood is not well made if not take it back.
Jul 07, 2015 | Kenmore Microwave Ovens
Microwave VENT fan keeps running
I would say you replaced a good hood thermostat (or "TCO" / thermal cutout) with a new thermostat of the wrong type.
The oven cavity TCO and the magnetron TCO will read zero ohms continuity when tested.
They are "normally closed" devices.
But the hood vent exhaust fan's TCO is a "normally open" TCO or thermostat, so it should read open or "infinity" on a continuity check.
If the temperature under the microwave gets too high, the hood TCO opens, which turns on the vent fan until it cools back down.
I would bet that only your fuse was blown.
May 18, 2013 | Microwave Ovens
Jvm1750sm1ss
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It's actually a pretty easy do it yourself job.
A video is available here showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
Next, disconnect the keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
The part number to order is WB07X11054 and you can get it from the Pros here.
You can also find helpful exploded view diagrams at that link.
Apr 23, 2013 | Microwave Ovens
My GE PVM2070 microwave is stuck in DEMO mode. Nothing heats up. Unplugging it, even for an hour, did not resolve the problem.
This would be a controller issue, and sadly, on the 2070-series ovens, GE does not make separate parts available.
So you would have to replace the "control panel subassembly".
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Disconnect the keypad strip as shown in the photo below, remove your smart board, then insert it into the new subassembly.
Dec 31, 2010 | GE JVM2070 Microwave Oven
Cannot remove the grill on my ge JVM1750 according to manual. Found and took out both screws BUT grill would not come out. What else is there to do in order for the grill to be able to come off?
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
Dec 04, 2010 | GE JVM1750SMSS Microwave Oven
How do i remove the grill on a spacemaker microwave oven
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do you get the front vent off to clean it. My microwave was manufactured in July 1993 and is an under the counter type?
Usually the manufacturer will provide a way for you to be able to remove it IF they would want you to (e.g. for cleaning purposes). If there's no instruction label for that, then don't.
Always check your manual for cleaning instructions. I found a manual of the same model and you can use as a reference for cleaning your unit.
http://preview.tinyurl.com/gexlmanual
Hope this helps.
Nov 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Broken vent grille for a Whirlpool microwave hood combination
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
HI,
Can you please describe you problem more clearly
May 18, 2008 | Microwave Ovens
Exhaust problem
you got to have make up air from someplace! the microwave cavity is sealed so microwaves don't leak out. [door seal] why would you have a grease filter on a microwave? is this a combination range vent hood AND a microwave exhaust system?
Dec 29, 2007 | Maytag MMV5165 Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
