Question about GE GSS20IEP Side by Side Refrigerator
Water pouring slowly
Everytime I press the lever to get some water, it pours out slowly. This occurs ever time I try to get some water and it seems to be getting worse.
  • legend123 May 22, 2008
    Thanks for your help but I found out that the filter needed to be changed. This fridge is completely different from my previous one as it had an indicator on it which notified me when the filter needed to be changed.
Do not know how to hook up rear tube for water and ice dispenser
Posted on May 18, 2008
My 1998nissan sentra 4 cyl. 5 speed transwas running fine stopped at light, engine slowly died will not start tries to but backfires in engine not able to start it again
change your fuel filter and get in the habit of pouring an entire bottle of fuel injector cleaner once a month as you fill the tank , pour in the bottle before putting gas for best mixing... also pour a bottle of %70 isoprophil alcohol in the gas tank to rid of all the water at the bottom if your gas tank since condensation occurs nightly...
All this , because you said "it SLOWLY died"
Dec 16, 2017 | Cars & Trucks
Bunn pour omatic commercial coffee maker will not brew and it leaks
VPR is a pour over "Volume Displacement" brewer. Required to completely fill the inner tank and heat prior to using brewer. BEFORE plugging in unit, water must be poured into upper tray and with brew funnel and empty pot in place. Keep pouring water into top fill tray until water drips out of brew funnel. Plug in VPR and allow it 15-20 mins to heat up. leave the pot as there may be additional water dripping. Remove power if there is any water spilling out from other places like the top pan cover or bottom of machine. With the initial heating done, take a full pot of water and slowly pour into the top filling tray. HOT steaming water should come out of the brew funnel to fill the (empty) pot. Prep is done and the machine can be used to brew a pot after 10-15mins of reheat time.
*** the machine you have needs to be checked for leaks in areas mentioned above. Water should only come out of brew funnel (if not present then the brew head or if that is missing then the brew pipe. All will need to be replaced prior to brewing.) Leaking under machine is an indication of leak(s) in pour tray,tank,tank cover, gasket, probe gasket. This machine like any used equipment should be checked out by qualified tech prior to use. Be aware that coffee vendors sometimes rent or loan brewers to customers.
Nov 08, 2017 | Bunn NHB Coffee Maker
I am ready to pour my cake batter in the pan but the mixer won't release when I push the lever.
THe lever is not moving all the way to release the bowl. Try pushing it harder, wobbling the bowl while yo push the lever, moving the lever back an forth several seems that some of the batter got on the lever release mechanism.
Jan 15, 2013 | Coffee Makers & Espresso Machines
2010 dodge avenger 2.4L motor seemed like I ran out of gas and stalled wouldn't start so I poured gas til it was full then everytime I try to start it it smells like gas n has a hard time starting
Camshaft position sensor. It needs to know which cylinder is needing fuel, so it can fire the injectors at the correct time. It must have failed you. It should not be too difficult to replace or very expensive.
Dec 17, 2017 | 2010 Dodge Avenger
Does not pour the proper cup size. Have the default set to the largest size. Sometimes it pours the proper size, other times it pours a smaller size. Also, the sequence of action seems to be off. Sometimes...
the Keurig is supposed to keep at least 12 OZ of hot watet at the ready...
when you press brew, the pump pushes water into the bottom of the heater... the hot water comes out the top into a clear plastic holder with probes sensing the height of the water... when the proper height is reached, the motors change state... other valves open up and that pur-measured water goes from the plastic holder tank to the arm touching the K-Cup...
Try running vinegar thru the unit and maybe the sensor probes are scaled... otherwise... you may have a intermittent connection and would beed to reseat the low voltage wires from that water height container...
involved taking the unit apart... :(
try the vinegar first.
Seems like internal cables need reseating.....
I posted how to open it... do not do unless its out of warranty... and you have a few hours of time to disassemble it...
May 06, 2010 | Keurig B50 Coffee Maker
Keeps spilling over during brewing
These tanks can't actually be overfilled since all water poured in displaces the exact same amount of water coming out the spout. So, whatever amount of water you pour in, will be the same amount of water that flows to your pot minus the amount absorbed by the coffee grounds and filter.
Your problems sounds like an undersized (Non Bunn) filter, or clogged brew basket. To verify this, try pouring in only half the water for your brew cycle and wait for it to finish dripping, then pour in the rest. If no overflow has occurred, you simply have the wrong type of filter. If overflow begins again, you have a clogged brew basket, since no Bunn can flow too fast for the brew basket to keep up with it.
This is because Bunn filters are manufactured differently than generic store bought paper filters. They will flow faster, brew cleaner and stand up better than normal generic filters.
Remember, Bunn makes their OWN filters for good reason.
They made the first, best paper filters for drip coffee pots, and all others are just generic dioxin gas producing paper.
Mar 05, 2010 | Bunn VPR Coffee Maker
Water is pouring out of where the soap dispenser is. Can anyone help?
its pouring out because the dispenser is getting clogged in somewhere and not letting the water to the drain pump so its pouring from the soap dispenser. Remove the dispenser, pour water into the opening and make sure water can get into the machine freely. Inspect the opening for soap build up.
If water goes down slowly , open the washer door and feel around the bellow for anything blocking the water inlet port into the washer (socks can sometimes get wedged up there and cause a blockage).
If it all checks out ok, make sure the machine is properly leveled and not leaning forward.
Hope that helps!
Jul 09, 2009 | Kenmore 43142 Front Load Washer
Water despenser in door drips water
Hi!!! you seem to have a problem that everybody in the world has..Its normal at there is nothing you can do about it unless you install an antisyphon in the water line kitchen aid has one.Good luck..
Jan 05, 2009 | Frigidaire FRS23H5AS Side by Side...
Coffee on the Countertop!
This is how my husband pours: he holds the lid open with the thumb lever and pours. It seems to work better if you pour slow. (I am always in too much of a hurry:)
Jan 30, 2007 | Mr. Coffee TFTX85 Coffee Maker
GE GSS20IEP Side by Side Refrigerator Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
