-   Also had the exact same problem on a 2003 model. Got the board out and resoldered the relay (was darkened and disconnected) problem solved. Jaredwood - for me the trouble spot was obvious once the bottom of the PCB was visible. Maybe your machine has something else, of course since it's been 4 months you've hopefully got it sorted already. Thanks iascott -   Guest
Jan 29, 2009
-   I did have exactly the same problem but thanks a million iascott. I'm far from an expert on this sort of stuff but once I managed to get the board out there the relay had darkened pin and clearly no connection visible - soldered it up, and after another half an hour trying to put all the machine together, hey presto the machine now works again. Fantastic stuff - cheers all! -   SGB_UK
Jan 11, 2009
-   I have the same problem and have removed the PCB but it is not clear what component is the heater relay. There is some slight darkening to the control unit in one corner under a coil like component. There is also some evidence of overheating on a small turquoise 2 pin component. Is the heater relay a black box marked js1-b-12v-h111 and as1311f mo1. Is it known for the relay itself to pack up?
-   jaredwood
Nov 10, 2008
-   Same problem, not heating water or drying dishes. Have checked the heater element and it is OK.-   iascott
Remove the controller from the top of the door. Extract the main PCB from the plastic case. You will probably see a burn mark on the inside of the case adjacent to the relay on the back of the PCB. Examine the back of the PCB for burn marks around the relay pins. Resolder the relay and any damaged track.
LG Dishwasher (LDS5811ST) is leaking along left side of door. Is this common...Is this something a...
(More)
LG Dishwasher (LDS5811ST) is leaking along left side of door. Is this common...Is this something a novice can fix?
i have an indeset idl705 when i turn it on the far left light flashers and the machine does not work...
(More)
i have an indeset idl705 when i turn it on the far left light flashers and the machine does not work tried the reset button but problem is still there????
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
