-   Same thing. Found it in a new home I just bought. I think it's a remote thermostat for the Heatilator gas fireplace. There is a setpoint adjust wheel inside. It senses ambient temperature and shuts down the firplace if the room gets too hot. Mine was apparently attached to the wall via adhesive strips at some point.
-   same exact thing happened to me - i was guessing it was a doorbell can you get it to work?
-   Guest
Aug 02, 2008
-   found this unit in a home I just bought. I found the following info but can't tell what it is. By the way, it was hanging on the walland there's a small speaker in it.
FCC ID. BJ4-61WDB50RX
CANADA: 1731 101 557A
MADE BY DESA INTERNATIONAL INC.
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my...
(More)
What universal remote should I buy to operate my Hitachi Model # CT-7894BC. I have two IR on my set, and with my current oneforall, I can not get into my menu functions to change anything, what should I do?
the transmitter is installed on the door frame, the magnet on the door(metal door)1. if i manually...
(More)
the transmitter is installed on the door frame, the magnet on the door(metal door)1. if i manually move either component the chime sounds, if they are both fixed(2 sided tape) and i open the door the chime does not sound. is my problem the metal door?
