Question about Microwave Ovens
Microwave LMV1976ST - broken clips to hold vent hood
  • charknes May 18, 2008
    The parts seem to be a molded part of the whole assembly and so I guess I would need a whole new vent hood. I don't know where to get one
    Genius:
  • 3,422 Answers
HI,
Can you please describe you problem more clearly
Posted on May 18, 2008
  • Priya darshan May 18, 2008
    Do you need any parts for your model?
Samsung microwave oven model SMH1622S exhaust fan will not shut off high fan and low fan will switch but the off dose not work.
On model SMH1622S, I would first check the hood TCO. It should be normally open (infinite resistance on a continuity test). If it has shorted, then the hood vent exhaust fan will stay on.
If that's good, then it is probably a shorted vent relay on the control board, which I can repair.
Details are here, where I also have a video showing how to remove the grille and controller assembly in about 5 minutes.
If you have any trouble getting the grille off once the screws are removed, slide the hood vent grille to the left about 1/4", then then pull it forward. On some models there are L-shaped clips that fit into a slot to hold bottom of the vent.
The Fast Track repair manual for model SMH1622 is here. It will be useful.
If you have other questions, it's best to follow up with me directly.
(FixYa does not notify us directly when follow-ups are posted, so we have to log in to the site to see them.)
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 23, 2017 | Samsung Microwave Ovens
Broken vent door/flap
Go to www.ebay.com Type: make and model of microwave, refine search to vent flap you might get lucky, if no luck, have a handyman come in and fashion a part.
May 09, 2012 | Jenn-Air JMV8186AA Microwave Oven
Cannot remove the grill on my ge JVM1750 according to manual. Found and took out both screws BUT grill would not come out. What else is there to do in order for the grill to be able to come off?
At our Web site, we have a video available showing how to remove a typical over the range grille and control panel assembly in under 5 minutes.
Dec 04, 2010 | GE JVM1750SMSS Microwave Oven
How do i remove the grill on a spacemaker microwave oven
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do you get the front vent off to clean it. My microwave was manufactured in July 1993 and is an under the counter type?
Usually the manufacturer will provide a way for you to be able to remove it IF they would want you to (e.g. for cleaning purposes). If there's no instruction label for that, then don't.
Always check your manual for cleaning instructions. I found a manual of the same model and you can use as a reference for cleaning your unit.
http://preview.tinyurl.com/gexlmanual
Hope this helps.
Nov 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace the control panel on a GE spacemaker 2.0 microwave. Model is JVM2070SK01. How do I remove the power vent to gain access to the control panel?
1. Unplug the microwave or turn off its breaker.
2. Open the door, then detach the control panel as shown in the video at
http://www.microwavedisplay.com and swing it down, but without disconnecting the wires.
They're our favorite supplier.
Aug 22, 2010 | GE JVM2070 Microwave Oven
Our panel will not ''pop'' loose. I feel like I'm going to break it. GE microwave oven JVM 1350BW03 We're trying to replace the door handle.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven
here.
Otherwise, there may be some grease of corrosion making it stick. Check the exploded views and maybe tap upward on it.
May 29, 2010 | GE Microwave Ovens
Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Jun 06, 2009 | Whirlpool GH8155XJ Microwave Oven
How do I replace the door handle on microwave?
Once you follow the youtube instructions to remove the inside cover you are ready for the next step.
Remove the six small screws that are adjacent to the window. After this the front plastic is held in only by plastic clips to the metal door. The plastic clips and the screws together hold this together.
Remove the entire door by lifting up and move it to a flat service. If the top vent cover prevents this just remove the two screws on top of the microwave and pull the vent cover off.
With the door lying flat you can pull the plastic frame out on top and bottom and see how the clips work. Now just work you way around the frame until it separates.
Install handle and reassemble in reverse order.
Sep 03, 2008 | GE Advantium 120 Convection/Microwave Oven
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 18, 2008 | Microwave Ovens
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
