Bass I have a Leem GA-610D, when I turn the base up and strum my guitar it makes a hissing sound how do I fix it?
  • Graeme Ross
    Graeme Ross May 11, 2010
    Hi sandmanz
    You have to remeber that the amp is only 10 watts, sounds like the output stage is going into overdrive. When this happens, you may get some odd noises from the amp. A 6.5" speaker and 10 watts will always tend to cringe a bit when you try to "turn up the bass".
    How much do you turn it up?
    robotek
  • 1,512 Answers
Hey again, still keen to talk to you about your amp. How much do you turn it up before the problem starts.
Posted on Jun 17, 2008
How can I tune mas bass guitar to A=444hz with a KORG GA-40 ???
You turn it on and there are the two buttons under the power on button. These ratchet the base frequency up and down. In the upper left corner of the display you will see what A is currently tuned to in tiny characters.
Mar 22, 2011 | Korg Ga40 Guitar Bass Tuner W Batteries
I can turn it on and i hear the fan going...but it doesnt make any sound when i strum or anything...please help!
There are some basic things you can try before you suspect the amp. Does your guitar cord work in another amp? Is your guitar sending sound through your guitar cord? Without any thing plugged into your amp can you hear a slight hiss when you turn your controls up on your amp? Here is a link to some things you can do to troubleshoot the problem:http://www.geofex.com/ampdbug/ampdebug.htm Even though the info is for tube amps a lot of it also applies to solid state (transistor) amps like yours.If it turns out to be the amp and you don't feel comfortable working on it and have no one that you know personally to do it you are best served by taking it to a certified Marshall repairman who will have the tools, parts and schematics to help you.
Apr 18, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
My guitar from band hero won strum
have u ever droped or spilled water on it beacuse the inside what makes the strum bar work can break really easy. buy a new one
Mar 29, 2010 | Nintendo Guitar Hero Wireless Guitar - Wii...
I have a Wii Guitar Hero 5 Guitar strum bar squeaking badly.
Easy fix for an adult with average mechanical skills -- take the guitar apart (see below) and lube the strum bar with a bit of petroleum jelly. They SHOULD assemble these at the factory with some sort of lube, but it seems that they don't. Ours started squeaking badly after only two weeks.
<<<DO THIS AT YOUR OWN RISK>>>
First, taking apart your guitar will VOID THE WARRANTY, so if you don't want to do that, contact the manufacturer to see what they'll do.
If you are no longer under warranty (or don't mind voiding it) remove the Wii remote: 1) Remove the Wii remote. Press the UNLOCK lever that's under where the Wii remote sits to remove the two parts that make up the guitar "body". They pop out first at the base near the 4-way directional. Just pop them back in (neck area first) to re-install. 2) Remove the "tuning" block by clicking the switch on the back to UNLOCK and pulling away from the neck. 3) Remove the 10 screws from the back of the guitar. NOTE: one is part of the strap hub on the neck. Also, the two at the very top of the neck are slightly smaller screws, so keep them separate from the rest. 4) Flip the guitar over and remove the tree screws from the cavity that holds the Wii remote. NOTE: one is under the "Warranty Void if Removed" sticker. 5) Using a flat plastic tool (like a plastic putty knife) CAREFULLY separate the two halves of the guitar body. I found it easiest to start at the bottom, where the strap connects. NOTE: (A) the bottom strap connector will come out as you separate the top of the body from the bottom. (B) Work your way to the neck slowly and carefully. You'll get there. (C) be sure to note how the spring loaded clip fits at the very top of the neck, it will fall out when you separate the two halves. When you put it back, the slanted part faces the top of the neck. *** WARNING: there's some wires, etc. inside. be sure not to damage anything as you take this apart. 6) Once inside the removal of the strum bar is pretty easy. Just take out the 4 screws from the circuit board. Next, remove the 4 screws that hold the bushings the strum bar fits into. 7) Once you have the strum bar switch out of the bushings, lube them with a bit of petroleum jelly. I just dipped a Q-Tip into the stuff and twirled it around inside the plastic bushing. Be fairly generous... you don't want to take your guitar apart again in a few weeks. Be sure to put all screws back in (two in each plastic bushing, 4 in the circuit board). Also, the screws were different sizes inside, so be sure to keep straight which screws go where. 8) Now just reverse everything you took apart. Your strum bar will be smooth as silk. Start at the very top of the neck (don't forget the little spring loaded latch--slanted part toward the top) and work your way to the bottom (don't forget to replace the strap holder.)
HINTS: Before you go crazy on the disassembly part, take some digital pictures as you go. Then if you get stuck and can't figure out where something goes you'll have something to fall back on.
We've been using our guitar for a couple of months after lubing it and it still is smooth and squeak free.
Feb 16, 2010 | Nintendo Guitar Hero Wireless Guitar - Wii...
My wii Guitar Hero controller seems to strum of its own accord in the middle of a song... is this a sensitivity issue, and if so any ideas on how to fix it?
You may need to dis-assemble the guitar to ensure that no damage has occoured to the strum bar internally as sometimes when this gets over used it has a habit to randomly strum on its own. Good Luck.
Nov 15, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Guitar hero wii controller plays notes of its own accord
I had the exact same problem on the wii guitar before, and tried replacing it which did no good. Then I realized on the solo part the touch slider was what kept strumming itself, so I turned off the slider and it worked! To turn off the touch slider, you have to go into a song and go to options and turn it off, which will keep it turned off until you change it. I'm not sure why it does it, I guess dust gets on it or something.
Hopefully this helps and have fun! :D
Jul 09, 2009 | Activision Guitar Hero World Tour Guitar...
Strum bar does not work
na man don't listen to that guy i had the same problem and all i did was take of the face plate and blow in the hole near the strummer. you can also get a peice of paper and slide it in there to get i working. hope this helps.
Apr 25, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
Wireless guitar strummer on wii repeatedly breaks
Well the strumming by itself is due to the touch slider strumming by itself. Try going into any song and going into options and turning off the touch slider. This will keep the touch slider off until you change it back, so you don't have to do this every time.
Apr 23, 2009 | Activision Guitar Hero World Tour Guitar...
When playing guitar hero and pressing the corresponding color button, no sound is being made?
Play the tutorial before playing the game. It'll tell you how to play the game. If there is still no sound, it is possible that the strum bar on the guitar is broken, and you will need to have it replaced. You can use the D-pad on the guitar as an alternative to the strum bar, just to see if the guitar works.
Jan 16, 2009 | Nintendo Guitar Hero Wireless Guitar - Wii...
The strum button is uncontrolable
Hey Omega,
Seems like the controller may just be faulty.
The only thing I can think of, is to turn off the console, and then make sure none of the buttons are being pressed when starting it up, and then turn it on. If it's still doing it, I recommend getting a new controller.
-Chad
Oct 14, 2007 | Activision Guitar Hero II for Xbox 360...
280 people viewed this question
 Grubhead
Grubhead
