Question about HP Pavilion dv9000z Notebook
Keys are missing, some broken
My 1 yr old 'scratched' off more than half my keys. i managed to snap on some but it's a huge (yet very tiny) project. i don't have the patience. can i replace the keyboard? i have an hp dv9000
You can buy new keyboards for almost all laptops
Posted on Oct 27, 2008
As far as i know it is not possible to buy a complete replacement keyboard for a laptop, however, you can plug in an external keyboard or take it to a shop like PC world and ask for them to replace the keys for you. Generally this isn't an expensive job.
Good luck with that : )
- Deni-YO
Posted on May 18, 2008
Lug on hot wire to starter broke off. where does it feed to?
If your ref to the battery hot wire, that goes to the starter
Nov 22, 2015 | 1999 Jeep Grand Cherokee
Tip
Model Scratch Building
You may not have heard of it but scratch
building is a hugely popular hobby that fans take very seriously.
Scratch building involves building a
scale model but from scratch ie not using a commercial kit or a pre-assembled
model.
What are the rules of scratch building?
There are no official rules to scratch
building. Some people believe that you can only call it scratch building if you
use completely raw materials and don’t have any plans or measurements to work
from. But others are not such purists and are willing to use even commercially
built parts in order to build their models.
What kind of materials are used for
scratch models?
Anything can be used to build scale
models from scratch, such as; wood, plastic, clay, paper or metal.
How do I get good at scratch building?
Most scratch builders start by
practicing on ready made building kits for scale models. Some of these are very
detailed and despite having all the parts, still require a lot of technical
skill.
Once you are good at commercial kits,
you can move on to building from scratch.
How do I scratch build?
You need some kind of plan; either a
prototype to follow or a design of your own that can be transferred into a
pattern so that you can start to cut out the parts and pieces you need for your
project. At the end of the actual building, you then need to ‘finish’ the
piece. This involves trimming, polishing, painting, weathering etc. This is the
part of the process that will take your technical piece to the level of
realistic model.
Good luck and have fun.
on Dec 25, 2013 | Crafts & Hobbies
Screen is foggy and out of focus,blurry..
You may have one of two possible problems here. First..you may have a contaminated tube. This means one of the projection tubes may have fluid that has become cloudy and must be replaced with clean fluid. This would take a bit of patience to do so. It is not easy. The second problem may be that the small signal module may need replaced. Do not confuse this board with the small signal board, which is a tiny board that sits on top of the signal board and easily snaps in and out. You want to repair or replace the signalboard that is located on the floor next to the power supply board [has the flyback on it]. It is the board that contains all the RCA jacks and RF connections, that you are concerned about. Please check the first answer. You will have to disassemble a bit to look inside the projection tubes as they are lit. Thanks for asking!
Aug 08, 2010 | Philips 60PP9202 60" Rear Projection...
My key broke off in the ignition ,how do i remove the lock cylinder
Just an idea - could save a hell of a lot of time and money, but it depends how the key snapped if you can get the glue to stick...
you can put a tiny drop of crazy/super glue on the snapped part of the key, put it in the lock and make it so its perfectly touching the key, you can take the old bit of key out of the lock when it sticks and have a locksmith make you a new key from the two bits... cheaper than an ignition barrell.
use the tiniest speck of glue possible, use a hair or whisker to get a tiny drop of glue onto the key, put it in the same way round it snapped off so the two faces mate together properly - after 2 minutes pull out the key, if it is stuck give it a wiggle and still pull...
any glue that gets in the lock can be removed with nail varnish remover (acetone)
Dont know about how to remove the cylinder sorry...
Jan 25, 2010 | 1990 Jeep Cherokee Limited
Java source code for hospital management system
Sir,
I need a project of Hospital management system. Since client needs project in very sort time so plz send same type of project at my email id that can help me out in database design or full code in a professional way .. Please be in touch with me.
regards Varun kumar
email : er.varunsoft@gmail.com
Apr 18, 2009 | Computers & Internet
Removal of protection screen mitsubishi ws55819 rear projection
you will need to pull the bottom of the unit off, this is just a snap on speaker grille across the bottom... then you will remove the screws across the bottom of the grey frame holding the screen... un plug the 2 plugs going to the control panel buttons, lift UP then OUT and it will come off.. once off, lay face down on a blanket and you can remove the frame screws INSIDE to pull out the protective screen. I took mine off to stop all of the glare problems. Also, while you have the screen off, clean your mirror and lenses since they will be easily accessible.. windex will do the job well, just make sure not to leave a bunch of lint from paper towels!
Jan 12, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Picture jumps after a few hours turned on
I have a 3 yr old 55 inch mitsubishi TV and when I turn it on the green light starts flashing and I must reset the TV about four times before it finally comes on has anyone had this problem if so what solution did you have?
Jul 25, 2008 | Mitsubishi WD-52525 52" Rear Projection...
SATA hard dive replacement
very much possible.insert yr vista cd in yr cd/dvd rom drivethen on yr system go to bios setting make sure first boot device is cd rom. then boot uy system it will ask u to press any key to boot from cd rom. so now press any key on yr key board and the rest is don by the vista all u do is just selct options like language when it ask u or say registration key. then to an extend, it will restart or ask u to press enter to restart. after restarting u dont have to press any key to boot from cd rom again plz take note. if it ask u to press any key dont press after a while it will then boot and continue from where it stopt last. so u just seat back n watch it install.
thank u
do rate this if it worked for u
May 28, 2008 | Computers & Internet
Panasonic TV Remote
open it the keys are on a rubber membrane.
clean the board and the membrane
Feb 02, 2008 | Televison & Video
HP Pavilion dv9000z Notebook Logo
71 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
