Question about Philips Brilliance 107B 17" CRT Monitor
Monitor viewing position
How do you view monitor vertical instead of horizontal once it is turned. It stays in a horizontal viewing position.
  • macktx May 18, 2008
    Samsung syncMaster 204B
  • macktx May 19, 2008
    Thank you. Once I updated nvidia it gave me the option I needed.
The clor is green and have brilante colour
Posted on Dec 07, 2008
  • Philips Master
  • 13,433 Answers
You need to flip the screen 90' depends on your video card. Its in screen properties -> advanced properties.
Posted on May 18, 2008
  • 1 more comment
  • Ekse May 18, 2008
    If the syncmaster didn't come with software of its own then you have to get to the display properties and rotate it.
    Please see this link
    http://www.nvidia.com/object/feature_nvr...
    You might need to download the nvrotate tool but again it depends on your video card is it nvidia? ati? intel? or difrent?
  • Ekse May 18, 2008
    Actually the NVROTATE comes with nvidia control panel if you have the newest drivers. But if your card isn't nvidia then that wont be a option.
    ATI, INTEL, and so on have a little difrent system for this but they are all in the same place
    on desktop right click -> properties -> settings -> advanced ->
    the flipping can be found somewhere in here, if its a nvidia card then its under the nvidia page.
  • Ekse May 18, 2008
    if you post the details about your videocard I can give you better instructions. Also remember to accept my solution as I know this I will solve your problem :-)
    Brigadier General:
  • 3,614 Answers
What model of monitor do you have..?
Explain how the monitor buttons work
Monitor Icon Description of icon function moncont.gif Power - Turns the monitor on or off.
Brightness - Using this button or wheel the user can increase and decrease the brightness on the screen.
Contrast - Using this button or wheel can increase and decrease the amount of contrast on the screen.
Horizontal Size - Allows for the picture on the screen to be stretched to the horizontal edge of the monitor.
Vertical Size - Allows the picture on the screen to be stretched to the vertical edges of the monitor.
Horizontal Position - Allows the picture to move moved horizontally, once in the center the user can then use the Horizontal size to stretch it to have an equal amount of black border on each side.
Vertical Position - Like the Horizontal Position, using this button or wheel the user can move the picture up or down to center the picture more appropriately.
Full Screen - Sets monitor to full screen.
Degauss - This button will degauss the CRT, restoring possible color impurities. After this button has been pressed the degaussing circuit will be activated and then deactivated after a few seconds. Pressing and holding this button for a few seconds may cause your computer monitor to reset all data.
Corner and Trapezoid Correction - Using this button or wheel the user can either round the edges of the picture or move the picture inward like an hour glass or outwards.
Vertical Linearity - Sets the width of the vertical lines.
Moire - Removes or reduces the Moire effect, if any.
OSD Controls - If the monitor contains OSD controls, allows for the OSD menus to be adjusted.
Power Management - Allows the user to define the power management settings through the monitor itself and not the software.
Monitor Status - Displays the current monitor settings such as refresh rate and other settings.
Language - Sets the language on the monitor.
Aug 16, 2014 | Computers & Internet
My crt acer ac512 monitar only centre line view,c"not full view why?
there are several reasons why picture of crt monitors did not display good picture. if your monitor had horizontal line at the center of the screen?...the faulty is in the vertical deflection, check the vertical oscillator also the fusible resistors & capacitors around that section. if there had vertical line at the center of the screen?..check the horizontal deflection, horizontal output transistor also check the YOKE.
Jul 31, 2014 | Acer Computers & Internet
My screen is side ways how do i put it back to normal
Do you have a rotating monitor? There are a few that can be rotated 90 degrees in the plane of the screen for a "portrait view" instead of the standard landscape view, and they will automatically swap horizontal and vertical signals as needed. If you have one of these, the position detector switch is stuck in the wrong position. You may be able to get it unstuck by rotating to the other position and back again.
There are some programs (e. g., Acrobat Reader) that let you rotate the view of the file you have open, but that only affects the contents of the window, not everything on the screen. I'm not aware of a program that rotates the full screen view for the entire system.
Nov 19, 2010 | Computers & Internet
We have a Hewlett Packard F1703 monitor...... Our cat sat on the keyboard and the monitor screen went from a horizontal view to a vertical one. We have to turn the monitor on it's side to view it. We have...
Press CTRL + ALT + Down Arrow Key It will Work if Not then Righ Click on Desktop Screen -> Graphic Properties -> Hot Keys ->Uncheck or Check the option it would be done
May 30, 2010 | HP Pavilion F1703 17" LCD Monitor
Monitor is vertical display instead of horizontal display
the keys ctrl+alt+right arrow should do the trick for you. if not then right click on the keyboard and select properties for options and you will find your graphics software has its own rotational software. good luck with two year old, sounds like you'll need it.
Feb 25, 2009 | Dell Computers & Internet
Fix the monetor view to horizontal view
Orientation can be changed to landscape mode by accessing the video card properties in the windows "Control Panel".
Oct 25, 2008 | ViewSonic P775 Monitor
Hi...there! Kazz,
Go to your toolbars bottom R/H corner and look for the VGA settings icon ( nVidia or ATI). Right click on that...and look for rotation settings, from there just followed the settings... Have nice day!
Oct 10, 2008 | ViewSonic VA902 19" LCD Monitor
Monitor has all in a horizontal position,want vertical
do you mean the task bars? if so click on them and drag them back down to the bottom of the screen
Sep 03, 2008 | Logitech 967437-0403 Keyboard
Monitor display has flipped from horizontal view to vertical view. It is an ACER monitor and computer, with windows VISTA. please help!!!!
Hi Guest!
Try pressing the keys Control, Alt, down arrow. Then try the Control, Alt, up arrow. This flips the image on a lot of Nvidia cards. Good Luck.
Dec 31, 2007 | Acer AL1916W 19" LCD Monitor
Horizontal lines are appearing and moving acrosss the screen of my View Sonic E50C Monitor...
What is wrong with your monitor is that the Horizontal section is going faulty, the lines you are seeing are the Horizontal Retrace lines, usually invisable in a working unit. It is often a faulty capacitor(s) OR a Diode breaking down.. in the area of the Flyback Transformer. Probably time for a new one unless ya can fix it yaself.
Jun 11, 2007 | ViewSonic E50C 15" CRT Monitor
Philips Brilliance 107B 17" CRT Monitor Logo
150 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
