Home | Panasonic | DMRES30V DVD Recorder / VCR Combo | Panasonic DMRES30V DVD.
Panasonic DMRES30V DVD Recorder / VCR Combo
Problem for Panasonic DMRES30V DVD Recorder / VCR Combo
By hirst0 on May 18, 2008
machine dead does not display time. Power is there.
Same Problem
Dec 14, 2008
-   I have the same problem, I think it is one of the components on the power pcb too, not sure which one though.-   daz767
Jun 08, 2008
-   Same problem - power cord is ok but no clock display, won't turn on. Was plugged into a surge protector :-( -   ecgb124
Best Solution
posted on Apr 24, 2009
Very Helpful)
Stevie Bee
Rank: Apprentice
Rating: 100%, 5 votes
Send an email to: mikeadams110@yahoo.com and write "Panasonic DMR-ES30V repair brief" in the Subject field. Tell Mike your problem and he will send you his repair guide.
Basically you need to replace two capacitors (C1204 and C1209) in the unit with higher rated 35V/50V alternatives.
Was this helpful?
Yes
No
4 people thought this was helpful
Solution #2
posted on Sep 17, 2008
Very Helpful)
Tech Guy
Rank: Apprentice
Rating: 64%, 80 votes
Was the display dim for a while, then died???
If so the likly problem is the power supply section.
It usualy comes down to one or a number of of capasitors in the power supply if the the machine is going on a few years old, some 2 or 3 years old!!
The power board in most STB (set top boxes) run very hot and these components don't last many years. The more expensive models have built in cooling fans the redice the heat.
So don't stack, cover, put in cupboards where the heat can't disapate or in direct sun light.
Some of these run so hot in the summer, they are to hot for a child to put there had on and leave it there!!!!
The cheapest fix is to take the power board section down to the nearest electronics parts and identify the possable spec of the offending caps components, not all ways the big ones and they might set you back $5 bucks!!
If you are handy with a soldering iorn and solder- wick with the most "MINIMUM of HEAT" remove most of the caps and get them tested on a anologe multi meter that is easier than a Digital meter for the beginer in Ohms setting.
Most will react by shorting the 2 un-solderd ends to gether then tuching the meter leads to the ends then you will see the meter reading drop at a stedy rate or very quickly down to nothing.
If in dout replace, you could ask the guy in the shop to check as some read differantly then others.
The other thing the Ohms or Up on the cap needs to be the same but the voltage needs to be the same or higher!!!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Panasonic DMRES30V DVD
Questions and Unsolved Problems for Panasonic DMRES30V DVD
Do you recommend Panasonic DMRES30V DVD Recorder / VCR Combo?
Answer
Answer
Recently disconnected panasonic dmr-es30veb dvd/combi recorder to reconnect to new tv. Had trouble... (More)
Answer
not working just cuts off no display at all
Answer
Hi guys my dmr-es30veb will ony play 3 out of 6 episodes on a disc, it once played all but now wont.... (More)
Answer
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic DMRES30V DVD...:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 1454
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
