Question about Sebo Automatic X1 Bagged Upright Vacuum
Replacing a belt on a Sebo Automatic X1 vacuum cleaner
The roller brush has stopped turning : someone suggested a broken belt may need replacement. How do I take off the top housing? Is it the 4 deep-set screws which allow the top to come off?
  • naomilev Jul 08, 2008
    The Sebo Automatic doesn't run on the floor as smooth as it used to. It needs pushing harder. Can you help please?
    naomilev@lineone.net
  • delboy40 Jul 17, 2008
    The brushes aren't turning and have found one of the two belts ( at rear)have snapped. Is this belt refered to as the brush belt or main drive belt?
    Also which screws need removing in order to fit a new belt
The roller brush has stopped turning, I think it could be the belt, how do I seperate the top from the bottom?
I will await your reply.
Thankyou Val
Posted on Sep 30, 2008
    President:
  • 1,673 Answers
On the front near the bottom is a big push type button, push it in and pull the handle and bag asm. up to remove it from the power head. Then remove those 4 or 5 screws to release the top cover.
Posted on May 20, 2008
Brush light on
Check the belt that turns the brush, either it slipped or needs replacement. You have to unscrew the bottom to take the brush roll out.
Mar 29, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Brush doesn't turn
Sounds like the belt is off/broken.
Jan 20, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
The brush on sebo x4 will not go up or down. Red check brush light briefly flashes
You should try to replace your SEBO roller brush with the softer one. The part number is SEBO 5010GE Genuine Sebo product
Jan 11, 2014 | Sebo Automatic X1 Bagged Upright Vacuum
Our Sebo Automatic x1 will now only pick up with nozzle. Hight adjustment doesn't seem to operate and no green lights display. No blockage found, roller works okay. Help! Wife becoming v. angry.
The belt on the motor shaft is probably slipping off. I have the same problem and that's what I saw when I opened the vacuum. I keep putting the belt back, but it slips off again. The belts aren't supposed to stretch. I am going to call Sebo and take mine to an authorized service place to make sure that it is just a stretched belt.
Jul 10, 2011 | Sebo Automatic X1 Bagged Upright Vacuum
How to change belt on sebo the big drivebelt
There are actually two belts on your Sebo, one that drives the brush, and the second that attaches to the pulley on one end, and the motor shaft on the other. I'm assuming that the belt you need to replace is probably the brush belt, or the belt that attaches to the brush gear on side, and the pulley on the other.
Here's what you'll need to do:
Step 1. Remove the vacuum bag housing so that you are only working with the power nozzle or the bottom portion of your Sebo, this will make it much easier to work with. Turn the vacuum upside down, and remove only the 5 screws that I have circled in red:
Step 2. After removing the screws on the bottom of the vacuum cleaner, separate the top housing from the lower agitator housing, sometimes it may take putting a flat head screw driver in between the white and grey colored housing and prying them apart.
Step 3. You now have full access to the belts on your machine. It's most likely the belt that wraps around the brush gear rather then the belt that's attached to the motor that's gone bad. I have never replaced the motor belt in 8 years of servicing Sebo vacuums. The easiest way to replace this belt is to loosen the pulley system that the belt wrap around. Unscrew the two screws that hold this pulley in place, and remove the brush drive belt from the pulley, and now you can unwrap it from the brush gear as well now with the extra slack in it. Now, if you've been using your Sebo in your home rather then using it commercially in a business, Sebo actually offers a lifetime belt warranty on their vacuum cleaners. The belt is supposed to last as long as the vacuum, and Sebo will actually cover this repair, both parts and labor as long as the machine is being used in a residential home environment. (This is the policy of Sebo America, if you're in the UK please check Sebo UK"s policy).
If you have any further questions on how to replace the belt, please feel free to reply to this repair by leaving your question in the comment section, I'm always more then happy to answer any question you may have.
Thanks again,
Chris Jones
goVacuum.com
Aug 09, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Hi, My Sebo X1 has a problem... The brush has stopped rotating (just after a noise like a jet engine!). Is this a belt problem? What's the best way for me to check. Thanks, MP
It's possible you have a broken belt, although Sebo belts usually last at least 10 years and often much longer. The first (and easiest) thing to do is remove the brush roll and check that it's not damaged where it mounts on the metal drive spindle. If that's OK, place the machine in a position where you can see the drive spindle then, keeping fingers and clothing well clear, switch on and check if the drive spindle rotates. If a belt is broken, the spindle will (of course) not rotate. The ultimate check is to take the cover off and have a look. To do that, first separate the bag compartment from the base, then turn the base upside down and undo the four deeply-recessed screws. Turn the base over, move the suction tubes out of vertical and just lift the cover off. The belts will be exposed and all will become clear (or possibly not!).
If you need guidance on changing belts, you can search on this site, as it's a question I've answered many times here. If you still have a problem, post a reply here and I'll see what more I can do to help. Good luck!
Jun 02, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo automatic X1. After switching on the motor
As sure as possible without actually seeing your machine, the carbon brushes on the motor are worn out. They are quite easy to replace (and not expensive). If you need help with doing the job, just post a reply here and I'll guide you as best I can. If you choose to have a professional do it for you, it should take no more than half an hour's labour.
I hope this has been helpful - please remember to score me! Good luck!
Feb 10, 2010 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Automatic X1 cleaner, toothed belt replacement
OK, here goes... (there may be more detail here than you need, but it's a copy of a solution I wrote for someone else)  NOTE - any use of the words LEFT and RIGHT assume that you are looking from the REAR of the machine.  NOTE ALSO - the machine has two toothed belts, it makes sense to change both while you're at it.
STEP 1. Separate the base from the bag compartment: press the button at bottom front centre of bag compartment and lift bag compartment upwards away from base. Sometimes this is quite stiff and four hands would be useful, you can lever it from behind with something relatively soft (the plastic handle of a dishwash brush works well) but take care to lift vertically upwards, not sideways or you risk bending a metal lever that's hard to get back into shape again. Rest assured that once you've pressed that button there is nothing holding the two parts together other than friction!
STEP 2. Turn the base upside-down and undo the FOUR DEEPLY-RECESSED SCREWS.  All the surface-mounted screws are irrelevant to this job.
STEP 3. Turn the complete base right-way up, release the foot pedal and move the vacuum tubes out of vertical.  The top cover will then lift off.  You will see there are two belts - the pulley device between the motor and the brush roller is the sensor that measures the drag on the brushes and operates the automatic height adjuster to maintain constant drag. To the right of that double pulley is the electronic circuit board - note that it has a sensor that locates within the pulley device, be careful not to damage it.
STEP 4. At the left end of the motor cover, the drive cog is concealed by a small cover. Lift this cover out vertically, noting how it locates in the frame for when you come to put it back.  Next, although not essential, it helps to remove the metal lever because if it falls out when you're not looking you may later be uncertain about how to locate the small coil spring. So slide that lever out towards the motor, noting how the spring locates.
STEP 5. Undo the two screws holding the circuit board (take care the washers don't slip away). Then undo the four screws holding the double pulley. Once that's free, you'll be able to change the belts.
Re-assembly is simply the reverse of the above process.
If you need more help, just ask.  Please remember to rate this response.
Jul 29, 2009 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Sebo Automatic X1 Bagged Upright Vacuum Logo
419 people viewed this question
Top Sebo Vacuums Experts
Jim Parker
Jim Parker
Chris Nomland
Chris Nomland
Are you a Sebo Vacuum Expert? Answer questions, earn points and help others
