Question about RCA 14F512T 14" TV
Rca 14f512t cannot get into service menu
I need to adjust the vertical shift on this model, but the sequence given to get into the service menu does not work (menu, power, vol+). Is there another sequence for this model?
Thanks
    Problem Solver:
  • 16 Answers
Try this
Switch appliance to Standby.Press VOL(-)
and PR(-) on keyboard for about 8 seconds.
Posted on Jul 12, 2009
Zenith TV B27A24Z, Vert Size Adjust
To do this adjustment, you should enter the service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Service mode entry, adjust and exit procedure to many popular brand TVs are given.
Feb 27, 2014 | Zenith Televison & Video
Philips magavox model 19pr15
1. To enter the Service Alignment Mode (SAM), press the following key sequence on the remote control transmitter: 0-6-2-5-9-6-Status.
2. From the top level SAM menu, use the Menu Up/Down keys to highlight the Geometry sub menu.
3. Use the Menu Left/Right keys to enter the Geometry sub menu.
4. In the Geometry sub-menu, use the Menu Up/Down buttons to select VAM.
5. Using the Menu Left/Right keys, adjust VSH so that the horizontal bar is properly centered, top to bottom.
6. Using the cursor up/down keys, select VAM from the Geometry sub-menu, and use the Menu Right key to
increase the value to obtain a slight overscan.
7. If other Geometry adjustments are needed, proceed to the necessary adjustment using the Menu Up/Down
buttons.
8. Upon completion of Geometry adjustments, press the Menu button to return to the top level SAM menu.
9. To exit the Service Alignment Mode, turn the set off with the Power button on the remote control.
Oct 30, 2007 | Philips 19PR19 19" TV
Rca 14f512t ur code
026,022,028. Try these codes.For more information http://electrohelponline.blogspot.com/Setup procedure, and setup code list to many popular remote controls are given.Pull up older posts.
Nov 29, 2013 | RCA 14F512T 14" TV
Blue screen rca tv model 14f512t
you will have to take it in to get repaired. might of put a speaker or something megnatic near your tv.
Oct 21, 2012 | RCA 14F512T 14" TV
I need a manual for this model. Thanks
Hi jhbeddy
You may download the manual at this site http://www.retrevo.com/support/RCA-14F512T-TVs-manual/id/402dj485/t/2/.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 23, 2011 | RCA 14F512T 14" TV
Horizontal adjustment
This unit will need to be opened up to adjust that horizontal problem, There are 3 knob looking things in the unit with a phillips head adjust those until the screen moves up. I would not do it if you do not know how I would take it and pay $15 bucks to have it done. If you find this information useful? please rate Fixya if you still dont findit fixing the problem rate 1 knotch below fixya.
Apr 24, 2009 | RCA 14F512T 14" TV
Picture is wider than the screean
There is a service menu that techs can use to adjust vertical and horizontal widths. If it is not an aspect ratio problem then it is likely that it needs to be adjusted.
Apr 23, 2009 | RCA P46921 46" Rear Projection Television
RCA 32" TV
Many RCA's use the following to gain access:
Hold the 'Menu' button while turning the set on.
The code may also be inside the back cover.
Feb 20, 2008 | RCA F32650 32" TV
Vertical Hight needs adjustment 1 inch,
hold vol up and down on tv and serv menu will appear...
Oct 16, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Screen not centerd
If it is a RCA F27649 then it has what they call a bonded yoke, meaning the only adjustments to shift the picture horizontal or vertical are electronic adjustments via the service menu.
Feb 11, 2007 | RCA F27649 27" TV
RCA 14F512T 14" TV Logo
248 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
