Question about Gateway FPD2275W LCD Monitor
Connecting Gateway HDMI TV to Playstaion 3
My 24" Gateway TV does not have inputs for the std. Yellow, white and red AV cable that came with the PS3. Can I just buy and use a HDMI cable to connect my PS3 with my Gateway TV?
  • Gateway Master
  • 1,689 Answers
If your PS3 has HDMI capability and the monitor has HDMI capability, it should work as long as the monitor can match to the specs of the PS3.
I am not sure, but I think the PS3 required the capability of 1080p from the TV set. Make sure that your TV is able to see 1080p.
For HDTV, the standard A/V cable set is of no use. That is why your monitor probably does not support the standard A/V format.
Jerry G.
Posted on May 19, 2008
There are no connections for the red whits and yellow AV cable in the new smart TV can i eliminate this cable and use a USB cable in its place this is for a wii
The usb port in Wii is for input devices (i.e. external HDD, Wii keyboard etc.) and can't use it to output signal going to your TV , its only the AV cable supplied by wii you can use to connect to tv. If the TV has no RCA input (yellow, white & red connections) you can buy AV to HDMI adaptor or AV to VGA adaptor to connect your wii to your new tv model.
Sep 29, 2014 | Nintendo Wii Console
Just bought hisense t36 42" and when I plug my ps3
Make sure you are connecting the red and white connectors to Audio IN on the TV.
You really should be using a HDMI wire though...
Jun 18, 2012 | Video Game Consoles & Games
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
How do i connect a playstation 3 to a philips tv
The PlayStation 3 (PS3) is a high-definition gaming console that supports both standard AV connections and high-resolution connections (such as HDMI). Most of the older Philips TVs come with a standard AV input. Newer, flat-panel Philips TVs include standard AV inputs and high-resolution inputs. To get the best video quality out of your PS3, using an HDMI connection is recommended if the option is available. The PS3 does not include an HDMI cable, only a standard AV cable
Standard AV
  • 1 Turn off the PS3.
  • 2 Connect the flat end of the PS3 AV cable into the "AV Multi Out" port on the back of the PS3.
  • 3 Connect the "red," "white" and "yellow" prongs on the opposite end of the PS3 AV cable into the corresponding "red," "white" and "yellow" AV inputs on the TV (usually located on the side or in the back).
  • 4 Press the "Source" button on the Philips TV remote.
  • 5 Select the "AV" video display mode.
  • 6 Turn on the PS3. The PS3 logo will appear on the screen.
  • HDMI Connection
    Dec 08, 2010 | Philips Televison & Video
    What channel does your t.v need to be on for PS3 to work
    You will need to set your TV to AV INPUT and use the supplied composite video cables (yellow, white and red RCA jacks) to connect it to the TV. If you have a high definition TV you connect the PS3 with a HDMI cable or a component cable (red, green, blue).
    May 08, 2010 | Sony Playstation 3 (PS3) Console
    PS3 hdmi connection works but not std rca AV
    You must set it OFF HDMI while connected to the TV...
    Feb 28, 2010 | Sony Playstation 3 (PS3) Console
    Psp3 no picture on tv tried new usb lead
    So you are using this cable to connect to the TV? On this cable is there only a red, yellow & white connector? This is known as an S-Video or AV cable.
    Can you make sure you are connecting it in the right part of your TV. Once connecting it you will need to select the AV input on your TV or you may need to tune the TV into that input (depending on your TV age/model)
    The best connection for the PS3 would be the HDMI cable which is one lead with one connector at either end (though this is for HD TVs only)
    Hope this helps
    Dec 23, 2009 | Sony Playstation 3 (PS3) Console
    When i plug my hdmi cable into the back of my PS3, it says no input on my TV ?
    you need to connect both the yellow red white cable and the hdmi cable into your ps3 and go the yellow red white av channel
    go to the ps3 settings and change the video settings (ithink) to hdmi and also change the sound to hdmi
    the screen will go blank and then the tv should change to the hdmi av channel if not change to it and accept the changes
    Dec 13, 2009 | Sony Playstation 3 (PS3) Console
    Connecting ps3 to cinema system
    There is no substitute for HDMI. However, the 'digital in' cable connection that you want to use is still digital and will sound almost exactly the same. The differences are barely noticeable to the human ear. Here is a list for you to see the pecking order of each type of connection.
    Audio connections from best to least go in this order:
    1. HDMI (digital)
    2. Fiber optic (digital)
    3. Coax - Digital (digital) <--- The one you want to use.
    4. Component (analog)
    5. RCA/AV (analog)
    Video connections from best to least go in this order:
    1. HDMI (full HD digital)
    2. Component (Blue, green, red, white, red - HD analog)
    3. S-Video
    4. RCA/AV (Yellow, white, red)
    Good luck!!
    Sep 28, 2008 | Sony Playstation 3 (PS3) Console
    Gateway FPD2275W LCD Monitor Logo
    268 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
