Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Wavy picture When we turn on our HDTV Mitsubishi WS-55513 it has a wavy, jittery picture for about the first minute. Then goes perfect and stays that way for as long as we have it on.
  • 2 more comments
  • Sadiekins May 20, 2008
    Does anyone know what could be causing this and how do I fix it? We are pretty electronically inclined if we know where to go to fix it. Thanks in advance for any input
  • bojayhawk Aug 13, 2008
    Mine is also doing this, but then turns off on it's own. Sometimes when we turn it back on the wavy lines are there and sometimes they are not, but it will get progressively worse, then turn off about every 15-20 mins.
  • jaymcfreak Sep 20, 2008
    i have the same problem except my worksfine foe 20 seconds and then the waves start and get worse and then bettetr after a while
  • umuthasucka Mar 25, 2009
    I started off with the same problem and now it's doing it all the time. i have to cut the tv on and off until it clears up. Sometime it works most of the time it doesn't.
This EXACT thing just started happening with my WS-48513. Anyone have any ideas?
Posted on Jun 02, 2008
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Horizontal wavy lines on picture
Sounds like the convergence has failed. This video gives more details
Apr 12, 2012 | Mitsubishi WS-55513 55" Rear Projection...
We got our mitsubishi in 2000. it was working fine and then little by little the picture has wavy lines and you can't see the movie, it has gotten much worse. what can we do?
The wavy lines are caused by the aging of the vertical deflection unit = the defective parts (some capacitors and resistors) must be replaced.
The fix wont be very expensive - the parts will cost less than $25 - but you need a good electronics repair guy to do the job and this is going to cost you.
Remember, it's an old tv that has started to show its age. Maybe it's time to start saving for a new one.
Oct 01, 2010 | Mitsubishi WS-55513 55" Rear Projection...
Have wavy lines in picture sometimes-could this be a faulty wire?
On the signal board there is 4 surface mount transistors. There is one right by the input board (BA09), i would check the corresponding caps and diodes close to it also. I would replace all of the 4 transistors. If this SMT starts to go you will see wavy lines in your picture than it will go away in 3 min or so and get worse over time until no picture is seen. When it totally fails you will have no inputs what soever but you will have an OSD screen and when you choose DTV you will get a scrolling picture.
Nov 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Wavy picture wife said it went all of a sudden
I have seen this several times in my shop. There are bad solder connections on the signal board. I suggest an authorized Mitsubishi repair shop for this.
Apr 10, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Wavy picture
It looks like you have a convergence problem here, probably a defective convergence IC.
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi ws-55513 HELP!!!
Same thing happened to me.On the signal board there is 4 surface mount transistors. There is oneright by the input board (BA09), i would check the corresponding capsand diodes2_bing.gif close to it also. I would replace all of the 4 transistors.If this SMT starts to go you will see wavy lines in your picture thanit will go away in 3 min or so and get worse over time until no pictureis seen. When it totally fails you will have no inputs what soever butyou will have an OSD screen and when you choose DTV you will get ascrolling picture.
Nov 22, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Wavy picture
It is capacitors in your TV set. If you fix it before the set goes out, you will save about a grand. Contact me @ techman32k@yahoo.com
Mar 24, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
354 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
