Question about Hitachi 200GB External USB 2.0 Hard Drive
Is my hard broken before i have got a chance to even use it?
Ihave just purchased a new computer along with a Hitachi 200 gb external hard drive, when i hook it up my computer will not reconize it and i have tried using multiple usb ports
    Problem Solver:
  • 11 Answers
However rare, it is possible that you have a dead hard drive. I would try the hard drive on a different computer (one that has a known good set of USB ports). If that still does not work, take it back to where you got it and get a refund/replacement.
A couple of things you can look at:
1) Do you hear/feel the hard drive "spin-up" when you first turn it on ?
2) Does the hard drive come with an external power supply ? If so, it could be just the power supply that is shot. Check for tell-tale LEDs that would say whether it's working or not.
3) Have you tried different USB cables/USB ports ? Sometimes the front ports do not have enough juice to power a hard drive (if it's drawing power off the USB port). Sometimes switching to a USB port on the back of your computer is enough to solve the problem.
4) Make sure to eliminate as many superfluous components you can from your testing: don't plug the hard into a USB hub, plug it directly into an motherboard USB port (as mentioned above, the ones on the back).
Hope this helps.
Posted on May 18, 2008
I have 2 Hitachi 3 TB External USB Drive External Hard Disks that are not recognized by my Mac OS X 10.6.8. Have I bought the wrong ones?
have you formated your hard drives? are your black or white jumpers hooked to the pins on top of hard drive? if the hard drives are new chances are the jumpers are still in small plastic package.the jumpers are little peaces of plastic with two holes with metal in them. the jumpers go on were it says master if you are using 2 hard drives .the other hard drive the jumper goes were it says slave. if you are using 1 hard drive you put the jumper on cs.
Sep 23, 2013 | Hitachi 200GB External USB Drive 200 GB...
My hard drive is not being recognize
A Hitachi USB external hard drive is a device that acts as portable, removable storage for your personal computer. If you need additional space to house files on your computer but don't want to go to the trouble of installing an internal drive inside the case, a USB external hard drive is your best option. These drives are "plug and play" devices, which means that very little can actually go wrong. If you're having problems, fixing them shouldn't take more than a minute or two.
Check your connections. A USB cable needs to be connecting your Hitachi external hard drive to your computer. Your external hard drive's power cable also needs to be plugged into a functional wall outlet, surge protector, extension cord or power strip. Make sure your Hitachi USB external hard drive is turned to "On." An "On/Off" button is present on the front of the unit. If the indicator light around said button is not illuminated, the drive is "Off" and your computer won't be able to recognize it. Press it to turn it on and then try to access your drive again. Format your hard drive. If your Hitachi USB external hard drive doesn't currently have a file system on it, you won't be able to use it to store data. Open up the "Computer" icon in the "Start" menu. Right-click on your USB external hard drive's icon and click "Format." Click "Start." This will install a file system on your Hitachi USB external hard drive. After this process is finished, you will now be able to use your drive. Restart your computer. Certain models of computers (especially older models) won't recognize new hardware unless your computer boots with the hardware already connected. Leave your USB drive plugged in and restart your computer. Once you do this, your Hitachi USB external hard drive should appear as normal in the "Computer" folder with all of your other drives. Hope this helps.
Jan 06, 2013 | Computers & Internet
Hi there we purchased a maxtor basics 500gb hard drive about 3 years ago. we have had children in that time and unfortunetly our two year old daughter dropped it. we have taken it to a service store but...
If it is the external hard drive enclosure that is broken then yes. But if it is the hard drive itself that is broken then no.
From what happened I'm thinking that it is the external hard drive enclosure that is broken. That being said, you can easily buy one without the hard drive online. When doing this be sure you know what kind of hard drive is in your Maxtor enclosure. This is important because you need to be sure that your hard drive and enclosure are compatible. Check to see if it uses SATA, ATA, or PATA connectors and then buy the corresponding external hard drive enclosure.
Once you have bought your new empty external hard drive enclosure, it is simply a matter of opening up your Maxtor enclosure and moving the hard drive inside to your newly purchased enclosure and connecting it to your computer.
To avoid problems like this in the future, look into "cloud based storage" to back up all of your data securely online.
Mar 29, 2011 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a Hitachi external USB hard disk 320 GB. it was working fine at may laptop but when i tried using it with computer, the Windows cannot detect the USB Drive. i tried it with 2 computers. but its...
i have a Hitachi external USB hard disk 320 GB it was working fine at may laptop but when i tried using it with the computer ; the windows cannot detect the USB Drive . i tried it with 2 computer . but its still the same .pleas help i badly need my files
Dec 05, 2010 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
I have a constant flashing green light and computer wont detect it
First, try connecting the external drive to another computer. If the second computer fails to detect it, chances are that the housing or, the drive inside have failed. Determining this requires a basic knowledge of external drives. If however the drive is rckognized the the second computer, turn off the first computer and strt it up again (not restart). Then plug your external drive to a usb port directly (not to a hub) and, it should be detected.
Nov 24, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
How to use hitachi simpletouch external 320gb hard drive . i pluged in usb to computer and nothing happens. it should automatically open hard drive
Hello
If the HHD gets power and you can feel the drive spinning, you can try these steps and see if your problem is solved. Go to:
control panel
Administrative tools
Computer management
Storage
Disc management
Now you should see your drive in the schematic below. Right click on it and choose the option to change drive letter or paths. Now just assign a new drive letter to the drive, restart your computer and it should work fine.
If you cannot see any power light flickering or feel movement on the drive when you power it up, then there is a other problem. Hope this can help you.
Best regards
Andrea
Nov 03, 2009 | Hitachi 200GB External USB Drive 200 GB...
Hitachi DK23FB-40 not detected
the external hard drive casing may need a driver for some operating systems
and then the unit must be in the on postion
Jul 19, 2009 | Hitachi TravelStar DK23FB (08K1427) 40 GB...
Hitachi 80 GB. USB HDD problam.
If you plug it in and it does not appear, it may be choosing the wrong drive letter.
If that drive letter is already in use it will not appear.
Open the start menu, right click on my computer, then choose manage.
Select (on the left) Disk Management.
If it appears in there.
Find the thumbdrive in the list and right-click and choose 'Assign a new drive letter' . Make it like M or somthing far down in the alphabet.
If that does not appear under the disk management then the disk might be physically damaged.
An urban myth (which does sometimes work) includes putting the drive in the freezer for a day or so.
Also remember it might be somthing as simple as a bad cable or port on the computer. Try to access it with a new cable from a diffrent computer.
Apr 23, 2009 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi external hard drive recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Aug 27, 2008 | Hitachi USB 2.0 to IDE 1.8" Aluminum...
Hitachi 200GB External USB 2.0 Hard Drive Logo
77 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
