Question about LG 52SX4D 52" HDTV
HELP My tv sometimes stays on for 5 minutes,20 minutes,and sometimes even more,but it turns off into stand by mode with the lamp indicator flashing,the lamp was replaced 4 months ago.
  • csnl2005 Nov 09, 2008
    How long should a lamp last?  We had ours replaced approx 1 yr and a half ago.  Our TV right now started intermittently shutting off into standby mode.  Sometimes we get 30 mins, sometimes 5 mins....very irritating especially while watching a good football game!  Any help would be much appreciated, also-- can any TV repair technician replace the lamp or does it have to be an LG certified individual?
I had the same issue. Replaced the lamp and now mine is working. Normally this is a sign that the bulb is out, however - I would say now that either:
1. Your lamp is defective.  2. The balast in your TV is defective.
I would check out - they can help.
Posted on Sep 15, 2008
Sony kdf50e2000 shuts down after 20 minutes, then 3 red blinks
This is the cause; 3 red flashes is bad main logic or power board, check for standby volts if ok replace main logic board
May 06, 2017 | Sony Televison & Video
Samsung HL-R4266W 42 in won't turn on
Initially, have you tried a full hard reset? If not, pls unplug from the mains. Most current devices would reset and revert back to factory default settings (assuming no internal hardware fault) when unplugged for a considerable period of time (from a few minutes to a couple of hours).
Additionally, have you tried powering the unit using another outlet?
Pls post back for any development(s) or even the lack of it.
Hope this be of initial help/idea. Good luck and kind regards.
Thank you for using FixYa.
May 01, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
Reset timer on jvc dla g150c projectorlamp
1 Turn on the MAIN POWER switch to go
into stand-by mode.
In stand-by mode, the STAND BY indicator on the
projector lights up.
2 Press the following buttons on the
projector, sequentially.
1 Momentary press the PC button.
2 Momentary press the ENTER button.
3 Momentary press the EXIT button.
4 Press and hold the HIDE button for two seconds
or more.
* During this sequence, the STAND BY and OPERATE
indicators alternately blink about every approx. 3 seconds.
After completion of the sequence, the STAND BY indicator
alone stays on.
* Buttons must be pressed within 2 seconds of the previous
* When you make a mistake in button operations, return to
the beginning of the sequence.
* To check the lamp time on the menu, press the MENU button
and select “Information” with the cursor button 5 or ∞.
The lamp use time is indicated in the item “Lamp time”.
Sep 30, 2009 | JVC DLA-G150CL Multimedia Projector
Sony KDF-E50A10 50 in. HDTV stays on for 25 - 30 minutes then shuts off by itself power stand by light flashes green and turns back on in about 20 seconds by itself. can you help?
Hi, Lamp of TV getting weaker and requires replacement. This shut off by itself will increase day by day until you put new lamp in TV. Always Buy Sony original lamp and avoid aftermarket/ cheap lamp for TV safety.
Jun 09, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Grand wega on off
it was the very begining of the lamp burnning out , new lamp and tv good as new
wega out
Sep 07, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Flashes orange 2 times every 5 seconds
There is a 20 pin cable that goes from the main board to the light engine that can cause this issue. The other possibility is the door switch or the cable that leads to it has failed. If none of those correct it then the light engine itself is the problem. Hopefully one of the earlier mentioned items is the issue as the light engine is costly. The part number for the cable is LSJA0467 and is available here
Mar 26, 2007 | Panasonic PT-43LC14 Television
Open Questions:
See all LG 52SX4D 52" HDTV Questions
LG 52SX4D 52" HDTV Logo
295 people viewed this question
Computer Repairing
Computer Repairing
