Question about Nikon Coolpix S220 - Aqua Green 2.5" LCD Digital Camera
My Nikon Coolpix S220 will not turn on. I have charged the battery fully but I have no activity connected to the usb or stand alone
4 Suggested Answers
SOURCE:
Joshi_Z
  • 567 Answers
SOURCE: fully charged battery Nikon coolpix
If your camera is under warranty please contact the manufacturer to see if they will cover the repair, or to determine how much they will charge for the repair.
In case they are repairing it underwarranty, good for you.
However in case there is a high cost assiciated, you might want to try the following steps as a DIY fix.
1. Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on.
If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2. Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
3. Blow compressed air in the gaps around the lens barrels for blowing out any particles that may be in there jamming the lens.
4. Tap the side of the Camera with the palm of your hand repeatedly. Many people have reported that the issue was resolved by just doing this. So, please give it a try.
In case the issue persists, you will have to get the camera serviced or go for a new one.
Posted on Oct 03, 2010
  • 102366 Answers
SOURCE: my nikon coolpix S220 wont
The camera does not contain any charging circuitry and will not charge the battery when connected via the USB cable. In fact connecting via USB actually drains the battery faster because the camera has to communicate with the computer (even if only to say it has nothing to say).
The camera comes with a separate MH-63 charger. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet. Once the battery is charged, you can put it into the camera and try connecting it to the computer.
Better yet, don't connect it to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Posted on Dec 14, 2010
  • 6 Answers
SOURCE: My nikon coolpix s220 will
There is either something wrong with the charging port or the batteries, most likely the batteries. Replace them and the new ones should charge, if they do not then it is a problem with the camera itself.
Posted on Feb 28, 2011
Have an issue with my cameras zoom function. When I take pictures my zoom works perfectly but when I switch to record mode the zoom will no longer work.
Nikon Coolpix S220 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_S220_Troubleshooting
iFixitThe Nikon Coolpix S220 is a compact 10.0 Megapixel Digital Camera. Designed with a 2.5 inch LCD ... If camera is in Video Mode the optical zoom will not work.
Nikon Coolpix L810 Troubleshooting - iFixit
https://www.ifixit.com/Wiki/Nikon_Coolpix_L810_Troubleshooting
iFixitThe zoom function is not working while camera is on; Zoom is not available in ... If your camera does not turn on, make sure that the battery is fully charged. If after a charge the camera still doesn't turn on, your batteries may no longer be able ... modebutton, the playback button, or the movie record button doesn't work, turn ...
Nikon L830 review ' Cameralabs
www.cameralabs.com/reviews/Nikon_COOLPIX_L830/
Feb 05, 2016 | Nikon CoolPix 900 Digital Camera
My nikon coolpix s220 just stopped powering on. i charged the battery, but that didn't help. any suggestions?
If the camera was dropped and it does not turn on with a known GOOD battery the camera must have been damaged. When you dropped it the FIRST time and it worked you were lucky. Cameras do NOT like to be dropped.
Feb 28, 2018 | Nikon COOLPIX S220 Digital Camera
Nikon coolpix s220 - USB device not recognized. The USB is fine since it works with other devices and the USB cord is fine since it works on a different computer. I tried a driver update but I get a...
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Sep 03, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My nikon coolpix s220 will not charge by the usb or the original charger. It now says battery exhausted.
Feb 28, 2011 | Cameras
My nikon coolpix S220 wont charge. I had to buy another USB connector because my son lost his and it does not seem to recognize the camera at all and will not charge
Dec 14, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My nikon coolpix s220 wont charge... do i have to have the original charger???
The S220 uses the EN-EL10 battery. The camera does NOT incorporate any charging circuitry, so connecting it to a computer actually drains the battery. In order to charge the battery, you need the MH-63 battery charger or a third-party equivalent.
If you need a charger, you can order one from your local Nikon dealer or from http://www.nikonmall.com
Feb 21, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Feb 07, 2010 | Nikon COOLPIX L3 Digital Camera
How to set up show battery on nikon cameras s220
The camera will show a low-battery indicator when the batteries start to run down. The only indication of a full charge is the lack of the low-battery indicator on the screen. There is nothing you can set up.
Jan 31, 2010 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Nikon Coolpix S220 - Aqua Green  2.5" LCD Digital Camera Logo
104 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
