Question about Bosch Nexxt WTMC 6300 Electric Dryer
Will Not Start
Absolutely nothing happens when I press the start button. This has been happening off-and-on for the last several months but the dryer eventually starts. Today, it ran one load and it refuses to start for anymore loads. Any help is appreciated. Thanks!
  • spitmanmd Sep 14, 2008
    just bought a Bosch and it ran a couple of loads and then will not start. If I get it to it shuts off after 5 seconds.
    Sergeant:
  • 409 Answers
sounds like the touchpad is intermittent.
please provide the complete model # and i will look up more details.
thanks,
Posted on Sep 25, 2008
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
Dryer won't start when start button is pressed and held
check door "close"contact button/switch usually the culprit..
Aug 02, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Whirlpool dryer mod#len2000k01 press tha start nothing happens
First thing Is the circuit breaker, then the door switch.
Apr 07, 2009 | Whirlpool Dryers
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
Maytag Dryer
are you sure the door is completely close?
if the door is not closing the door switch, nothing will happen when you press the start button.
drcool
Sep 17, 2008 | Dryers
Kenmore 110.69912990
Need more info. Check voltage at outlet. Check thermal fuse,
check thermal cut-off assy. Then you have question -what caused the thermal to fail? There are several.
Mar 17, 2008 | Kenmore 73952 Gas Dryer
Estate electric dryer
hi thanks for the question i looked it up and the most likely cause for this problem is the thermal fuse located at the back of the dryer remove back panel and on the air duct you will see a small plastic piece with 2 small blue wires going to it replace this part but also clean all venting to the outside as this will cause this to happen the appliance doc
Nov 28, 2007 | Estate TEDS740JQ Electric Dryer
Flashing "touchup" and dryer won't start
This unit should be on warranty, call back the seller for service.
Nov 08, 2007 | Maytag MED9600S Electric Dryer
Bosch Nexxt WTMC 6300 Electric Dryer Logo
186 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
