Question about DISH Network ViP622 DVR DTV Receiver / 180-Hours Video Recorder
Dish-vip622dvr my dish keeps turning off! right now it is working fine but a few mins.it will make a noise and signal will be lost, it will fire back on and great picture, no bad weather in area! please help
My reciver dont recored and dont pause and take like 12 minutes to turning on, and have a message that a have to add a usb to help organize the programing a recored, o and is to slow that a have to keep presure the channel buton for like 5 seconts to make change
Posted on Jul 20, 2008
My 311 is connected to a dish 100.2. It has worked fine for a while. A few days ago it lost signal. I ran a swith check and it said there was fewer satilites than normal. Well I checked out the dish and it...
firerun1,
When you get the message 836, found fewer satellites than previously detected, it usually indicates a problem with a component between the dish and receiver. Normally a tech needs to be sent out to find the problem and to fix it.
Depending on the number of receivers you have active on your account, you may have a loose cable to that receiver if other receivers are working okay. If you have a switch between the dish and receiver, a port on the switch may be bad. If this is occurring on all your receivers, you'll need to call Customer Service to setup a Tech visit.
I hope this helps.
Ray Calo
DISH Network
Nov 07, 2010 | DISH Network 311 DTV Receiver
We have a satellite dish. We have followed the instructions to hook up our new Westinghouse TX-42F810G LCD Flat Screen, but we continue to get a "NO Signal" message. How can we resolve this issue?
It is possible that the LNB is not tuned to the right slot to track the signal from the source sattellite. So use the right direction to set the parameters, set the dish to the required direction.
If the signals tracked are free channels then you must receive them.
So keep trying to get the dish in the right orientation, get signal after coarse setting and then fine set for tracking the signal without signal splits.
Aug 28, 2010 | Westinghouse Televison & Video
The Sky HD Box keeps losing the signal on every channel except terrestial 1, 2 3, 4 and 5. An error message comes up with 'no satellite signal being received' and codes 28 and 49 and to get the signal...
could be any of the following;
1 dish out of alignment (re-align dish),
2 faulty LNB (low noise block) on the dish (likely) replace
faulty box, even more likely
Oct 04, 2009 | Televison & Video
Fuzzy tv screen that says lost signal (no dishnetwork signal)
Here are a few suggestions,
*Check your connections to make sure none are loose.
*Try checking the Dish box to make sure everything that should be turned on is actually on.
*Also make sure channel 3 is the correct channel by contacting your service provider.
I hope theis solution is helpful. Please take a moment to rate this solution.
Feb 12, 2009 | Televison & Video
Runs for a few minutes then switches off
there is a relay just inside the control panel at the front ,
it allows the mchine to rotate in both directions
by replacing this it should cure the problem
Jan 23, 2009 | Hotpoint TDC32 Electric Dryer
Video works when playing DVD, but not with Dish signal.
I have the same problem.I turned it off for 5 minutes then turned it on and off a few times.
And I hit it to, not recomended
Jan 18, 2008 | Sony KV-27S42 27" TV
Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Jan 19, 2007 | Sanyo DS27820 27" TV
DISH Network ViP622 DVR  DTV Receiver / 180-Hours Video Recorder Logo
365 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
