Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Charging the battery on a sansa mp3 player
How do I charge the battery on the mp2 player How do I recharge the battery for my husband's mp3? It seemed to recharge while he was downloading some music. Also, is there a larger set of earbuds for this mp3?
    Problem Solver:
  • 44 Answers
Recharge it by plugging it in to the USB port. your sansa should have come with a USB cable and the ports are pretty easy to find.
almost all types of earbuds or earphones are compatible with the sansa system, so if you just go out and buy some you should be fine.
Posted on May 19, 2008
Change battery sansa ciip
If the MP3 player battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Apr 13, 2013 | SanDisk Sansa Clip MP3 Player
Battery not holding charge
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Jan 26, 2013 | SanDisk Sansa e250 MP3 Player
My Sansa MP3 player will not charge all the way and holds the charge for about 1 hour. What can I do?
Nothing. The rechargeable battery doesn't last forever. That was probably manufactured in 2005. Time to replace it.
Oct 01, 2009 | SanDisk Sansa m250 MP3 Player
Help. i connect my sansa clip mp3 player to my pc it says "connected" then i leave it there for 6 hours while im in computer then its still charging and it never ends.... its supposed to make that? another...
you are spoiling the battery.you should not charge it to 6hr,well 1hr-2hr is very suffiecent.
problem with your battery.so use it and recharge it when it says low battery.
recharge it only 2hr not more than that.
Jun 19, 2009 | SanDisk Sansa Clip MP3 Player
Will not take a charge. took two charges prior but has now stopped
I found this online at www.sandisk.com under warranty and manuals link.
I believe they have an excellent Return Authorization system, that if you truly have trouble with your disk player and it's still under warranty, gather your receipts and get on line to get an RMA. I have successfully returned to disc players that were infact faulty (FAT problems) and received two replacement players. Get on it right away. Look at the manaul online too. IT can be very helpful. I've included the Battery info, and the link for the manual at the end.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
May 12, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Sansa clip wont power up unless hooked up to usb
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Charging
computer.
Clip player.
Sansa
adapters.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
Do you have the USB cord and a laptop? you plug those into each other to charge it or you get the DC adapter.
Apr 30, 2008 | GPX MW3837 MP3 Player
This MP3 player does not have a rechargeable battery. It uses 1 AAA battery which will last for days
Apr 30, 2008 | SanDisk Sansa m240 MP3 Player
Charge batteries...
My M230 uses a AA battery that is replaceable, just remember to power it off BEFORE removing the battery.
Sep 26, 2006 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
60 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
